Best place to buy MFD?
Discussion in 'Gen 2 Prius Main Forum' started by Artric, Jun 27, 2018.
  1. Artric
    Artric Junior Member
    35
    Deltona, FL
    Hello,
    I need to replace my MFD 86110-47230. It’s too dim to be useful. Basically useless in the sun.
    A while back, someone mentioned a great page where you could look up parts like this and have them ship. Kind of like car-part.com, but better.
    It showed mileage of the cars parts came from and someone mentioned they even had coupons sometimes.
    I’d like to get a bright, working one for less than the $250+ they’re going for on eBay. I’m a single dad paying over $800/mo for care for my two kids and I am not highly paid. Just so you know why I’m frugal.
    Thanks so much!
  2. ITBland
    ITBland Active Member
    433
    272
    New Orleans, La area, US
    Is it just the MFD this is dim, or are all dash lights dim? Do you drive with headlights on during the day? If so, turn them off and see if the brightness improves. All that being said, I bought my used 2004 in Miami and the screen was burnt and the top coating (not the digitizer-the touchscreen that is in front of the screen) was partially melted and brown. I got a replacement for $35 from Pull-A-Part, (I removed it from the junked car myself), but they are not everywhere. Search for “Self-Service” used auto parts or junkyards in your area. Even a regular junkyard may have them for more reasonable prices. Another outfit is LKQPickYourPart.com (I see two LKQ in your area, they have vehicle inventory online, but no guarantee any particular part is still there.) lots of others in your area, grab a screwdriver and 10mm ratchet and go shopping out in the heat! Prices vary, sometimes it may even vary with a different cashier at the same location, since they don’t really know what the MFD is.
    #2 ITBland, Jun 27, 2018
    49,694
    ally express?
  4. Artric
    35
    Deltona, FL
    Thank you! I am pretty sure it was LKQ.
    And my car was a South FL Car as well. It's not dim because of headlights on, dash lights are not dim and I'm not driving with headlights on. It sounds like my screen was much like yours.
    Thanks again!
  5. Artric
    35
    Deltona, FL
    Turns out it was LKQ online that I was looking for. They show three matching my code, but none say available. :(
    I also looked at the local yards they have around me and next to no Prius to scrounge from. May have to do eBay. :*(
  6. peecee
    peecee Member
    67
    39
    Annapolis, MD
    Why not contact Texas Hybrids? They will sell you an updated one (won't tap out at 199,999) and can be set to your mileage. The swap should take about an hour.
  7. ITBland
    433
    272
    The U Pull & Pay has a 2009, no guarantee on the MFD--you might try calling a couple of the full-service junkyards, especially if they specialize in foreign cars.
    @peecee I don't think @Texas Hybrid Batteries does MFDs, just Combo meters (they may chime in), AutoBeYours.com does MFD repair and would probably sell one if they had it (but I think they also sell them on eBay.)
  8. peecee
    peecee Member
    67
    39
    Annapolis, MD
    @ITBland you may be right about @Texas Hybrid Batteries. I just know there are differences. I have a newer MFD that will not work with my 2004. Hey - I'd be happy to send that along if it works for @Artric. I pulled it from a 2008. No guarantees, but it gets out of my garage and into someone who might possibly use it.
    ITBland likes this.
  9. ITBland
    433
    272
    @peecee , Did you find a replacement for your 2004? You can use the 2008 in a 2004 (I'm doing it), you just need to move a few wires in the plug.
    #9 ITBland, Jun 29, 2018
  10. JC91006
    16,493
    8,403
    Which wires do you move?
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,329
    6,005
    Columbia, SC
    have you checked your WTB post?
  12. DangNabbit
    DangNabbit Junior Member
    55
    Where the wild things are
    I
    ITBland likes this.
  13. ITBland
    433
    272
    Luckily, only one small wire needs to be moved, the others are the larger power and ground wires, and those can be freed with a small screwdriver. (I also could not free the Speed wire, ended up cutting it and splicing it to a newly inserted wire in the correct location.)
  14. peecee
    peecee Member
    67
    39
    Annapolis, MD
    The plugs don't even match (at least from what I remember). So I haven't tried to make it work. When I get home tomorrow I'll look again at the newer MFD to see exactly what part number/model it is. Thanks for the link to the how to and excellent write up. I should be able to move pins around no problem!
  15. ITBland
    433
    272
    If you have navigation, then the change is complicated (I have an excellent 2004 Navigation MFD I don't need--we could swap if that's what you need), but if you have a base 2004, here is the most complete list of pin swaps: Will 86110-47230 work instead of 86110-47081 in 2005 Base Model?, and here is how to release the pins: Will 86110-47230 work instead of 86110-47081 in 2005 Base Model?. All of the wires EXCEPT the speed wire are relatively easy to release and move, I gave up on trying to release the tiny speed wire, added a new pin and spliced the wire. (Reportedly you can take a pin from an old computer cd audio cable and place it in the correct spot). Wires connection of back-up camera to MFD !!!. I am using a 86110-47230 in my base 2004 and have added a backup camera (@DangNabbit is working on his base 2008, adding a backup camera).:sneaky: Wires connection of back-up camera to MFD !!!
    #15 ITBland, Jul 1, 2018
  16. ITBland
    433
    272
    @peecee , I looked at your new owner thread (WOW!:notworthy:), and you and I are in the same boat! I also got a terrible 2004 as a project and replaced the entire interior from the Pick-N-Pull and have been replacing other pieces here and there :D. I got lucky and found a nice 2004 premium and got a lot of parts out of it (sadly, it got carted away before I stripped it completely :(). BUT, I did get the MFD out of it and it is excellent! I was using it in my base 2004 (it will just plug right in) until I got the 86110-47230 and re-wired the plug. It is not capable of having a rear camera without an expensive adapter from Coastal added, but it will show your navigation (way out of date navigation) and all of the other functions (except the radio you replaced).
    Edit: Looks like Coastal does not make them anymore, (maybe available used?)
    #16 ITBland, Jul 1, 2018
  17. ITBland
    433
    272
    @Artric, Even if this 2009 Prius still has its MFD, it is a Nav model (I know in 2004/2005, the nav MFD is plug-in compatible with the base model, I don't know if the 2006-09 is the same, but I bet it is, you just won't have any nav function.)
  18. pashko90
    pashko90 Junior Member
    47
    28
    SoCal
    On my prius any of mfd's works. As well, I have exchange with warranty.
