Best way to get 12v lighter socket in the trunk?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mediahound, Apr 28, 2014.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    What's the best way to get a 12v lighter socket in the trunk?
    I want to install a car DVR in the back windshield but not on all the time, only hot when the car is on, like the front lighter socket.
  2. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    You can see what I did for the 12v socket always on in the hatch.
  3. mediahound
    903
    155
    I don't want it to be always on though.
  4. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Yes, I was trying to show the mounting option but I was being clear mine was always on.
    Mine is for the electric tire pump I use for the kids bikes.
    Once mounted you can use a relay to trigger it from an accessory that is on with the car.
    Some people do that for the stereo amps that are hooked up directly to the rear 12v battery.
    my2cents
  5. sadie72
    sadie72 Junior Member
    45
    Chicago
    What kind of relay?
  6. DimitrisTS
    DimitrisTS Junior Member
    27
    49
    Thessaloniki
    This is what I did. I put a switch and also a voltometer.
    #6 DimitrisTS, Jul 30, 2020
    Xterra72 and sadie72 like this.
  7. xliderider
    xliderider Senior Member
    7,901
    3,130
    Honolulu, HI
    11.8VDC? Isn't that low, shouldn't it be about 12.8VDC?
  8. DimitrisTS
    27
    49
    Thessaloniki
    Yes. Probably I need a new battery. It gets that low after about 24h of sitting.
    There is though a dashboard camera always active.
    xliderider likes this.
  9. sadie72
    45
    Chicago
    What dash cam do you have?
  10. sadie72
    45
    Chicago
    I was just told by an electrician that hooking up a switch will keep the outlet off until flipped, but I'm not sure what type might be appropriate.
  11. sadie72
    45
    Chicago
    Thanks!
    I got this one now KDLINKS-R100. I've had it several years.
    I placed the rear camera up front allowing complete interior coverage. I did this to protect me as a rideshare driver.
    The downside is that interior camera does not record IR at night.
  12. sadie72
    45
    Chicago
    I just found this 12V set-up
    DimitrisTS likes this.
