Bladder oddness
Discussion in 'Gen 2 Prius Main Forum' started by Aardman, Jan 8, 2013.
  1. Aardman
    Aardman New Member
    This is my first post here. I'm sure it will be far from my last.
    We got our feet wet with a used 2006 Prius that, other than having 150,000 miles on it, had no other issues we could detect. If another vehicle hadn't made an improper left turn right in our path, causing us to T-bone into it, totaling our Prius (even though we were going less than 20 mph), we would still be driving it.
    With our insurance payoff & a little extra, we found a really nice 2009 touring. I had it checked out at a Toyota dealer and we purchased it on the basis of the clean bill of health they gave it.
    Well, they didn't check the CD changer apparently, as it fails to load any disk inserted into it, but that's another matter.
    Of more concern was when I went to fill it up I couldn't even put six gallons of gas into it (the fuel gauge was on it's last bar). Not knowing about the 'bladder' problem, I assumed the gauge was at fault. As it turns out, I wish that were the case.
    I've barely driven it 30 miles and I've already lost a bar on the fuel gauge.
    Our 2006 would take about 10.5 gallons on a fill up & wouldn't start losing bars until nearly 70 miles. We usually drove around 450 - 480 miles on a tank. We only purchased it this past September and it's been pretty warm here lately, plus we kept it parked in our heated garage, so the bladder tank wasn't really exposed to any cold weather.
    The 2009 had been sitting outdoors in a lot for about a month and we've had some really cold weather lately. I'm assuming the exposure to cold has had some influence on the bladder, causing it to shrink.
    Is there any way to inflate this bladder some? I mean, not being able to put even six gallons in the tank is pretty severe. Would topping it off continuously help stretch the tank out some? I'm really looking for a solution here, short of replacing the whole tank, which will probably cost an arm & a leg.
    Any help, observations, suggestions appreciated.
    BFAyer likes this.
  2. Patrick Wong
    18,210
    6,517
    There is no way to "inflate" the bladder.
    You may find that another fuel pump at your gas station may work better. Also try inserting the fuel pump nozzle with the handle "upside down" to see if that helps.
    Topping it off might help. After the pump first clicks off, you might try forcing in another gallon or two, especially if you are about to embark on a long trip where you'll quickly draw down the excess fill.
    However that practice may damage the fuel vapor control system if liquid fuel enters the components, so that is at your risk.
    [email protected] likes this.
  3. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    Overfill the bladder and it might flow fuel back out the fill hole when you remove the nozzle. I've seen it once and will not do that again. It's winter now and the bladder will be smaller. I would not worry about it. It will be fine in the summer.
  4. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    Aradman where are you? I too have a 2009 and live in PA. I have that problem during the winter months. My fuel bars drop quickly. My last fill up I had three bars remaining, but I could only put in 6.629 gallons - and that's after the the pump clicked off and I forced in an extra gallon. During the summer months I can drive 100+ miles before the first bar will drop off the fuel gauge. The most I've ever put in during the summer months is 8.8 gallons, and that was filling up at 1 bar. -- I think it's just the way the car is... I wish there was a conversion kit! I'd be willing to spend $400-$500 to have an acurate fuel gauge!
    danboy likes this.
  5. turnbowm
    turnbowm Junior Member
    So. Calif.
    When low-vapor nozzles were implemented in California several years ago, I was unable to get a complete fill even in warm weather. After researching (and experimenting), I concluded that the station pump nozzle was shutting off early due to pressure buildup in the tank. The solution for me was to put the pump nozzle on slow fill (first click) and to pull the pump nozzle seal (rubber) away from the Prius tank opening during the filling process. Using this method, I have filled up numerous times since without premature pump shut-off!
    KK6PD likes this.
  6. Aardman
    Aardman New Member
    Thanks for the suggestions.
    I live in Kansas City and the last week or so the weather has been fairly warm, if you call upper 40s warm. Normally it's a bit chillier than that in the winter here and we usually will get at least a few weeks of consistently below freezing temperature.
    However, the Prius sits in our garage, so you would think the bladder wouldn't notice any cold temperatures. Certainly our 2006 never had a problem anything like this and thought it too stayed in our garage there were plenty of trips we took with it when the weather was below freezing the last month we had it.
    I can live with a certain amount of this kind of inconvenience, but when I can't even get six gallons in the tank when the fuel gauge is down to one bar, that seems to be a bit more than what many are describing here.
    The car DID sit in an outdoor lot for over a month, with the tank nearly empty all that time, and we had a quite a bit of cold weather during the period it was sitting outside, so I'm hoping the bladder didn't become permanently shriveled.
    When the pump shut off at 5.5 gallons, my jaw dropped and my first assumption was the fuel gauge was defective.
    I'll try filling it using slow fill and see if that helps some.
  7. fuzzy1
    10,707
    Do verify for yourself that it really is a Touring model, don't simply trust the seller's word. The fraction of used Prii labeled as Touring is much larger than the fraction Toyota actually built.
    For you bladder refill problems, besides experimenting with slower fill speed and topping off, see also this thread: It only took 6 gallons this morning... Refill inconsistencies seem to be very common in Gen2, I even experienced it on a rental unit in warm weather.
  8. Daves09prius
    680
    161
    Gettysburg, PA
  9. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    211
    San Diego, California
    I like my car but I dislike the fuel bladder. That is the thing that I would most like to be changed.
    Daves09prius likes this.
  10. Aardman
    Aardman New Member
    Thanks for the suggestion. What's the simplest way to verify that it really is a Touring? I mean, it's certainly 'tricked out' with just about every feature in the book with the exception of a sun roof. Leather seats, blue tooth, nav, CD changer (that won't recognize CD's), security, BU camera & etc…
    I'll try resetting the inclinometer & see if that helps too, thanks.
    Frankly, I'd like to reset quite a few other things as well. Is there a list here anywhere that has all the 'Easter Eggs' used to reset different features? I'd like to reset the main display as I suspect it isn't calculating the fuel economy accurately.
  11. Daves09prius
    680
    161
    Gettysburg, PA
    Have you tried disconnecting the negative battery terminal to reset the computers?
  12. Silver bullit
    608
    211
    The differences are in what the Touring Edition adds to the Prius. Here's a list:
    • Sport-tuned suspension
    • 16-inch wheels with alloy rims
    • A larger spoiler
    • High-intensity discharge (HID) headlights and fog lights"
    Link HowStuffWorks "Prius and Prius Touring Comparison"
  13. nickb
    nickb Junior Member
    45
    Soprano State
    That's why Toyota left the bladder fuel tank. On paper it has some great advantages but it has real world problems. I got stranded with my 2005 Prius in 2010 when I went from 3 bars to none in minutes.
  14. Aardman
    Aardman New Member
    After checking everything out, yes, it is a Touring. Nice to know the dealer knew what he was talking about.
    No, I've not tried disconnecting the battery. I'm surprised that resets the computer. I would think the computer would be equipped with a small battery to prevent such a thing when the main battery is replaced.
    I would like to reset the computer, though. On our 2006 I could easily push the consumption up over 50 mpg with my sedate driving habits, and the consumption averages would be especially volatile for the first ten miles or so when I would do a reset (which I did every time I filled it up). On this 2009, with the same driving habits, it takes real effort to push it up to 45 mpg and it'll drop like a rock whenever I accelerate much at all, and, when I reset it, the averages change much less dramatically then they did on the 2006. Tonight we were keeping our eye on the energy display while running some errands and I was keeping the MPG well over 50 for most of our trip, yet whenever we would look at the consumption it was barely moving & when I arrived home it said I averaged 43MPG. On our 2006 the same driving habits on the same trip would've given a reading over 50MPG. I'm assuming / hoping the computer is keyed into the driving habits of the previous owner and if I reset it, that'll help.
    With the combination of this bladder goofyness and the contrariness of the computer, how can I calculate my true mileage with any accuracy? I'm hoping I can put more than 5.5 gallons in it on the next fill up, but that's going to throw off my mileage calculations if I do. We averaged a little under 50 mpg with the 2006 and I would think I ought to be able to get comparable mileage with this 2009. Actually, I would think I could do even a little better.
    I certainly don't expect worse mileage which is what I'm 'seeing'. When the toyota tech checked the vehicle out before I purchased it, he gave it a clean bill of health, found nothing wrong with it at all, not even any minor issues. I was expecting him to find something, but other than a handful of recall items that need to be addressed, nothing.
    Hopefully I'll be able to get everything normalized eventually.
  15. fuzzy1
    10,707
    To determine real MPG, keep a fuel logbook. I put the numbers into a spreadsheet, but others use Fuelly online or any of numerous smartphone apps. The only real way to overcome the bladder variation is to average together many consecutive tanks. Keep track of the car's displayed MPG too, so you can compare against the fuel pump calculation and estimate the display error. After that, the display should be a good indicator for short trips. Most Gen2 owners have found the display to be fairly good, better than the later Gen3s.
    The wider tires on the Touring will cost a few MPG. And since the original tires are likely gone, you need to check the current tire model against the lists of Low Rolling Resistance models. Non-LRR tires will cost some MPG. Note also that new tires will temporarily cost some MPG until they are worn in.
    What is your tire pressure?
    Is the battery original, or a replacement? If it is getting weak, it might depress MPG. And in the cold and moderate portions of the U.S., MPG is lower in winter than in early fall, due to temperatures, fuel blend changes, and wetter roads.
    Also, read through the post linked below If you post answers to this thread, we will have more clues to suggest other factors.
    Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new
    HaroldW likes this.
  16. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Aardman - My 2006 only takes 8 gals in winter and never reaches 400 miles per tank
    In summer yes I can usually get 9.o maybe 9.5 gals and can sometimes exceed 450 miles per tank.
    Sounds like your 2006 may have had a better bladder than most.
  17. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Aardman,
    Greeting from Texas. I note you are in KC. With that said, you are pretty much in the dead of winter. Just as a reminder you have several things working against you right now that will affect mileage on the Prius. That would be the following: cold temps first and foremost, followed by the bladder which is not real flexible right now (already mentioned). Those things you really cannot control and must just live with it.
    Things you can look for and change for the better. Check the 12 volt battery. Check the air pressure on the tires. Pump them up if they are anywhere close to the door sticker. Check the type and brand of tires on the car. Are they true LRR tires? Change the oil and filter in the ICE, run synthetic as this will help to improve mileage. Make sure the oil level on the dipstick is less than full. Check the air filter, if it is dirty, change it. Practice Pulse and Glide when you can do it safely without impeding the flow of traffic.
    I understand you have already owned one Prius so everything I mentioned should be second nature to you.
    Concerning the computers on the Prius. If you do disconnect the battery, pretty much everything goes back to default. Now whether that will help your mileage may be another story.
    As other's have mentioned, please ignore instantaneous mileage for the most parts, concerning trips. You need to look at the bigger picture. In other words, what the MPG is over several tanks. Run a spread sheet or use Fuelly.com or something similar. Ignore individual tanks as the bladder does not always stretch the same time when you refuel, which will make it look like the MPG changed for some reason. Try to get into the habit of filling the same way every time. It seems the bladder is best filled if you fill at the slowest setting on the handle. When the pump stops, hang up the nozzle. Also you may have better luck if you loosen the cap halfway, then go inside and prepay. When you come back out, then take the cap off and refuel, OR loosen the cap half way, then check your oil and fluids before you begin to pump the fuel in if you are using a credit/debit card. It seems that the bladder will fill a little more consistantly if you allow the system to vent a little bit before pumping the gas in.
    For the most part, you should find the MFD reading should be within a couple of miles if you run the guessgage down to two or three pips AND if you reset it once when you refill. It seems the MFD reads a little higher than actual mileage, and if you make note of the figure each time you fill up you should see a trend over time. If you see crazy numbers, ex: MFD reads 53, MPG was 36, then next tank MFD reads 45, MPG was 54 etc. you then know that the bladder did it's thing (not expand/collapse normally).
    The '09 has a EPA estimate of 48 City and 45 Highway. Remember that your mileage may vary. Click on my fuelly link in my signature here on PC, and that will give you an idea of how our Prius is doing over time. Yours will probably be similar or better depending on how you use the Climate Control. If hover your mouse over the little yellows squares, you can read the notes for each fill I have recorded on Fuelly.
    Good luck to you and I hope the info helps.
    Ron
  18. N.J.PRIUS
    N.J.PRIUS Member
    140
    50
    Fort Lee, NJ
    2013 Prius Plug-in
    I had the same thing happen to me. I always go to the same pump at a certain gas station and had never had a problem. I went to fill one day and the usual pump that I use was not available. I typically fill when I am on the "blinking light." Most fill ups are 9.5 to 11.74 gallons.
    I was stunned when the person filling the tank said it was full at 5.87 gallons! In N.J. we have attendants to pump fuel. Again, the next time I went back to fill after the "blinking light" came on my usual pump was again being occupied. I went to the same pump as before and this time only 5.99 gallons could go into the tank! This time I pumped the fuel. I didn't know what to think, but knew something wasn't right.
    The very next time my usual pump was available and I pumped the usual 9.47 gallons! I knew then that the problem was with the pump and not my Prius. The other pump apparently was much more high pressure causing the premature click-offs! I have not had any issues since and will not fill up at that one problem pump. As Mr. Wong suggests, try a different pump. I hope this helps!
  19. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Ditto....... enjoy the Guess Gauge!
    It takes a bit to get used to, once you realize it has quirks, and you learn them and how to live with them, you will be fine! I just fill up when there is two pips, top the tank, it's about 8 gal, if I push, have done 9. I have never filled to double digits however!
    Wait until summer. Your new car will be normal, in livable temps, fill ups will be easier to figure out!
  20. Aardman
    Aardman New Member
    Thanks everybody for the suggestions.
    I've put a measly 120 miles on this fill-up and the gauge is down by half. It is a little disconcerting, but I'm getting used to it.
    I have an appointment with a Toyota technician on Monday who says the there's a few other things besides a combination of the bladder / gauge that could have caused the low fill up. I figure it's a good idea to at least let him look into them.
    Since the measly 5.5 gallons I put in on my first fuel-up made the gauge say I was full, my plan is to sock a spare gallon of gas in the in the back and drive the car until I either hit 400 miles or run out, whichever comes first. Consensus seems to be that there is no way the bladder can shrink to the point where I can only put six gallons in, so my assumption is I have more fuel in the tank than the gauge is telling me.
    I'll know soon enough - It'll be interesting.
