Blend door malfunctioning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AlphaTangent, May 4, 2024.
  1. AlphaTangent
    AlphaTangent New Member
    GA, USA
    I've recently purchased my 2nd prius, a 2006 classic, but I'm having problems with the hvac blend door. It won't stop blowing to the face vents, barely blows to the floor when selected and won't blow to the windscreen I'm guessing it's the actuator but which one? I've read there are 2 under the right side and one on the left but the sources in finding are giving different suggestions for the location of the problematic actuator. The lower left actuator seems to only move on half the raceway. I don't see much movement on the upper, and I haven't put eyes on the third on the right. Any help would be appreciated.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,017
    NJ-USA
    The lower actuator on the left side of the HVAC housing is for temperature control (aka the air mix or blend door control).
    The upper actuator is for air outlet control (mode control, or dash, heater or defrost vents).
    That third actuator is for the air inlet door - fresh air or recirculation.
    FYI, all 3 should move the linkage lever about 90 degrees full travel.
    AlphaTangent likes this.
  3. AlphaTangent
    GA, USA
    Appreciate the assist! The upper actuator is most likely the issue it sounds. Is there a way to replace it without disassembly of the dash? Or is that the easiest way? There seems to be a control module of some sort in the way atm
  4. dmc
    dmc New Member
    Mechanicsville, VA
    Hello! I’m brand new to Prius Chat. We got a quote from the garage of $970 to replace the HVAC mode door actuator. It won’t switch to defrost the windshield. Is it possible to replace this myself or is it as labor intensive as the garage says…having to disassemble a lot of the dash? Any tips, advice, or feedback would be greatly appreciated.
  5. ChapmanF
    19,041
    I'm sure the lower actuator on the left side can be replaced without disassembling the dash, and probably the upper one too, if you are determined and patient and look for the posts by yitznewton in this thread:
    No, that wasn't a mouse in the heater | PriusChat
  6. dmc
    dmc New Member
    Mechanicsville, VA
    Thanks ChapmanF, yitznewton, and other posters. All the info was extremely helpful! I discovered that my mode door actuator is actually functioning, but the arm that goes from the actuator to switch the door from floor to vent to defrost is not attached to the actuator! For the time being I was able to easily rotate the door to defrost, which is what I needed it set to in order for my 2006 Prius to pass inspection. Even though I didn’t “fix” the actual problem, I saved $970 by investigating further with the help of all you! Big time THANKS!
    Brian1954 likes this.
  7. ChapmanF
    19,041
