Blown Head gasket rebuild....@297k
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 8, 2017.
  1. Mendel Leisk
    42,368
    He roughly summarized here:
  2. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Is this going to be a DIY head gasket job? If yes, please add a camcorder to your list:p
  3. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    150k when misfire started and now it's close to 160k. Very minimal oil consumption, like 1 qt in 15k miles. Was using M1 synthetic 0w20 and changed every 10k and later used M1 extended synthetic and changed every 15k with oil filter changed every 7.5k. Engine is not abused like my '95 Integra GSR which reliably pull to 8k RPM or clutch dumped at 4k RPM everyday for 300k miles.
    amos likes this.
  4. leeb18c
    272
    202
    SF Bay Area
    Thanks. I wish he listed the brands and part numbers to save me some time. :)
    Yes. All DIY. Hopefully, I don't need to pull the engine out since I don't have engine stand or cherry picker. It'll be about 2 weekends job and see what I can do with photos but probably not video.
  5. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    :D:D:D@NutzAboutBolts Wanna take videos to add to your collections if leeb18c permits? LOL just kidding:ROFLMAO:
  6. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    Oil sucked into combustion from under throttle body intake catch filling over time from EGR?
    Can thru butterfly or after removal
    It's also all over valves waiting to get sucked in
    #246 Tbkilb01, Sep 7, 2017
    iskoos, danlatu, RMB and 1 other person like this.
  7. Mendel Leisk
    42,368
    Could it in fact be coming from PCV? I'm thinking next time I'm under there for and oil change to pull both ends of the PCV hose off, and maybe it'll drain out? Not sure. (n)
    danlatu likes this.
  8. Tbkilb01
    218
    187
    Louisiana
    Pulled mine off and it drips our both ends
    Way too short
    Needed OCC to keep out of intake catch. Will check results pretty soon
    Going on 10k oil change..,oil still at F mark!
  9. leeb18c
    272
    202
    SF Bay Area
    I saw some oil there when I cleaned the intake manifold but it's mostly dried up sticky and no chance of going up. In hindsight, I don't think one needs to do it. I should look into installing a catch can but it'll be hassle to remove every 2 years for smog check.
  10. leeb18c
    272
    202
    SF Bay Area
    I think I'll order Beck/Arnley 032-3038 head gasket kit, 016-1075 head bolts, copper spray and grey RTV for now. Let's see if I need anything else after opening up. Maybe I'll also change valve stem seals while I have the head off.
  11. amos
    amos Active Member
    376
    285
    los angeles
    Smog?
    Never had to smog my car just pay dmv fee. They cant smog check it....
  12. Mendel Leisk
    42,368
    If you're ok with OCC down near the current hose location, ok with accessing from below, and it's air-tight version with tight connections:
    Maybe smog check inspection won't even notice it, and you're not polluting any more.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    How long have you owned your Prius? Our 2010 was smog checked in 2015 for registration. It will have to be smog checked this December as well.
    FYI(y).
  14. amos
    amos Active Member
    376
    285
    los angeles
    Mine is 2013. Never smogged. Bought it 2014. All registration renwal made through dmv web. Never asked to provide a certificate
  15. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    My bet is you'll need it in 2018;). Not that it is hard to pass (y).
  16. amos
    amos Active Member
    376
    285
    los angeles
    Im just waiting for rhe newer shape gen4 models to become affrdable. My car runs great now after dealer did the gasket but as you and other prius owners know. The ride is very noisy. Lots of outside noise. Driving l.a to vegas once a week with all these trucks to my right kills my ears. Will be glad to get rid of it begining 2018
  17. Jose Reyes
    Jose Reyes Junior Member
    63
    Anaheim
    I dont like the look of the gen4 prius. I suggest you take a look on groupon or craigslist. You should find a smog place for 20 dollars or so.
    amos likes this.
  18. runnyeggs
    runnyeggs Junior Member
    31
    NV
    Just the title got me. 297,000 miles???? I've never kept a car pass 170k. I'd be extremely happy if I can keep my 13 up to 200k with just regular syn oil changes.
  19. runnyeggs
    31
    NV
    Yeah the back is kinda fugly. Not sure how they drive as far as road noise is concerned.
  20. runnyeggs
    31
    NV
    Have you tried getting quieter tires and maybe sticking more foam, like dynamat, into the door panels?
    amos likes this.
