Brake, ABS, & stability control lights all just lit up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Cdubya69, Jan 18, 2015.
  1. Cdubya69
    Cdubya69 New Member
    Peoria, IL
    got in the car (2010 Prius IV, 170k miles) this a.m and the brake, ABS, & stability/traction control lights all just lit-up. Can run & drives just fine.
    Any ideas?
  2. gliderman
    gliderman Active Member
    751
    225
    Pull codes.
    52,826
    12 volt battery?
  4. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Yes. There is a fault somewhere in the ABS braking system.
    In a panic situation or with poor traction, the brakes may not work as you expect......or need.
    Best to get a shop to check it out.
    The battery is an outside possibility but that usually causes various lights to come on that are not related to each other.
  5. Cdubya69
    Cdubya69 New Member
    Peoria, IL
    Pulled the codes. Only one...P1578 yaw rate sensor. A quick "Google" didn't yield much.
    The 12v battery is only 2 years old, so it had better not be that.
  6. bisco
    52,826
    what is that, body lean?
  7. Cdubya69
    Cdubya69 New Member
    Peoria, IL
    From what I've discovered, yes.
  8. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    The repair manual I have suggests the brake booster with master cylinder or the power management control ECU as possible culprits with that code. (It also doesn't associate that code with the Yaw Rate Sensor, though some of the Yaw Rate Sensor codes do mention the brake booster with master cylinder.)
    Honestly, I'd probably prefer a bad 12V battery over one of those, if I were in your shoes... ;)
  9. CR94
    CR94 Senior Member
    2,827
    1,241
    Northwestern S.C.
    Rotation of the car about a vertical axis (as opposed to pitch about a left-to-right axis, or roll about a longitudinal axis).
  10. bisco
    52,826
    thank you, is that part of stability control?
  11. CR94
    CR94 Senior Member
    2,827
    1,241
    Northwestern S.C.
    Probably so. The stability system needs to know when the car is rotating in a way inconsistent with its speed and steering angle, since that would imply skidding.
    #11 CR94, Jan 21, 2015
  12. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    Did you ever resolve this issue?
  13. Cdubya69
    Cdubya69 New Member
    Peoria, IL
    Sorry about that. Yes, I did. The "code reader" at O'reilly said that it was the Yaw sensor. I decided to take it to a dealer to be 100% sure. They stated that it was the drivers side, rear hub and wanted $700 to fix it. I ordered a genuine Toyota part from Advanced Auto part (direct ship) for $220. It was VERY DIFFICULT beating the old one out, but we finally got it.
    All's well (for this concern)
    wukong sun likes this.
  14. TampaPrius.com
    461
    300
    Tampa, Florida
    Thanks
    Found my problem as well. LF wheel speed sensor harness was severed.
    Had codes P1578 and C1465
  15. Culb
    Culb New Member
    Alpharetta, GA
    I just experienced this yesterday after getting an oil change. I don't have an OBD scanner... anything I can do in the meantime to narrow things down before I take it into the dealer? I have read a ton on this board about thigs to do, but I don't have the MFD, so I'm not able to do the 12V test. I've checked the inverter coolant pump and it seems to be running fine.
    unnamed.jpg I have 44K miles on the car... any advice would help. Thanks!
  16. bisco
    52,826
    do you recall hitting any road debris?
  17. Culb
    Culb New Member
    Alpharetta, GA
    I haven't hit anything. I did take it back to the place that changed my oil, and they brought up codes C1203 ECM Malfunction and C1345 Linear Solenoid Unlearned. Checked out this page: ABS Brake Problem: Error Codes C1203 and C1345 | PriusChat. Looks like I'm headed to the dealership tomorrow.
    But, on the way home I did notice something odd: the battery isn't charging anymore. I'll brake, but on the Hybrid System Indicator didplay, the battery only has 2 notches(it's usually only 1 notch from the top) and when I brake, the meter doesn't go into the "CHG" section. Is this battery related?
    #17 Culb, Apr 10, 2015
  18. bisco
    52,826
    sorry, you're above my pay grade.:p all the best.(y)
  19. ChapmanF
    19,009
    The linear solenoid (in the brake actuator) is used in coordinating the amount of hydraulic brake effort with the amount of regen. If the computer is in the state where it needs to learn the solenoid calibration, it might be deciding not to do regen at all until that's done.
    But the battery should charge in other circumstances besides regen braking. Are you saying it never shows charging at all? If so, might be worth having the HV and battery ECUs queried for any codes that might explain that.
    -Chap
  20. Culb
    Culb New Member
    Alpharetta, GA
    So the dealer said it's the 12V battery. They are replacing it for $250 walk out.. not too bad so I took it. They also wanted to charge an additional $240 for: RE CALIBRATE ZERO POINT SENSOR (CODES 1336ZERO POINT CALIBRATION SENSOR UNDONE) and RE CALIBRATE LINEAR SOLENOID VALVE(CODES C1345 LINEAR SOLENOID VALVE OFFSETUN-DONE). I called another dealership who didn't think I needed those done, and frankly that seemed a really high amount for recalibration. And I can always have it done again in the future. Do you guys think this is something I truly need?
    Syed Bukhari likes this.
