1. Gotsqueeze2345
    Gotsqueeze2345 New Member
    Dallas Texas
    I’ve read on many threads about brake issues but none of them replicate what I’m experiencing.
    I just bought a 2007 Prius and it has 250,000 miles. Under normal driving conditions the brakes are a lot weaker than any other car. It’s apparent as soon as you try to stop the car in reverse from backing out of a parking spot (Or during any braking situation). When I apply the brakes I can feel the car swing towards the front passenger tire, leading me to believe that the front passenger brakes are applying all the stopping force to that one tire.
    When I apply more than 50% of the pedal (a quicker stop than normal) that front passenger tire will skid (lockup) and at higher rates of speeds will smoke the front passenger tire.
    I don’t see any lights on the dash nor do I get any codes when using a code reader. Even when the tire locks up (not sure if there is a difference between locking up and sliding/skidding) I get no lights signaling a problem.
    I know that some will say I need to brake early or it’s my driving habits but this is an issue that makes the car unfit to drive safely even when using all caution.
    When I have to quickly stop the car I have to basically do what I assume ABS normally does. I have to pump the brakes as quick as possible resulting in the car locking the tire up multiple times when attempting to stop the car.
    I took a look At the fuse panel underneath the hood and noticed that the ABS relay had been taped up as if maybe the relay had gotten hot or had to be rigged up to attempt to repair it.
    I was going to start there but didn’t want to throw a bunch of parts at it and be stuck at square one. I also thought it might be the tire speed sensor and it not sending the signal that the tire is locked up. I figured i should see some type of light on the dash but none are illuminated.
    hope I have this in the right section. Let
    Me know if you need more info. Thanks in advance for any help, much appreciated.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,103
    6,967
    Texas Hill Country
    Sounds like a basic hydraulic problem that a good brake inspection should id. Failing a solution there, your brake by wire booster/master cylinder/abs/brake-ecu would be suspect. However it is far more likely to throw codes.
    Valiant V likes this.
  3. Gotsqueeze2345
    Dallas Texas
    Thank you for the response , much aopreciated and have a follow up for today that might help..
    II decided to remove the relay and see if the car responded differently. Once removed and restarted , the dash remained black bc of its other issue with the display. But I’m not sure if that even has anything to do with the CEL, ABS or whichever light illuminated. But the car drove exactly the same , actually a little better but I think the tire roration and proper air adjustment as per car jam and a brand new tire. It still would lock up when applying more pressure than it took with the older , not so new tire.
    I went to buy the relay and I guess it has to be picked up from a Toyota dealership and I will be doing this tomorrow and begin throwing parts at it till something sticks..
    I figured relay first , since it’s visibly an issue.
    Then go ahead and pay Toyota to tell me what’s the actual issue is.
    Also I took the car to a local mechanic that has no experience with hybrids and their braking systems.. I’m assuming that is my other issue but the mechanic is a long time friend and was free but checked the system overall and I couldn’t explain the braking system to him in English so I left with hopes the relay solves the issue.
    thanks again for any suggestions .
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    Does the ABS warning light work normally went you furst turn the car on? (ie, comes on as a "bulb test" then turns off).
    Sounds like you should begin with a complete inspection of all the base braking system components - pads rotors calipets and hoses - as well as the rear brakes. Look for obvious stuff like rusted or seized caliper pins or pads stuck in the brackets. Also should have the car in neutral and have someone lightly press on the brakes and see if the left front applies at the same rate as the right.
    If any wheel is locking up without the ABS light activating, I might wonder what's going on with the system, might need Techstream to look at ecu data to figure it out.
  5. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    At 250,000 miles - the first question should be "what service have the brakes had in the past quarter-million miles?"
    Sounds like the LF wheel brake is doing nothing, and/or the RF wheel brake is "grabbing".
    Pulling off the front front wheels and looking at the discs, pads, and calipers may answer your question.
    Once you've addressed the most obvious things - then you can dig into the esoteric stuff like p[inched hydraulic lines and the like.
    I am curious what's going on with the ABS - but you need to have a basically function brake system before you can do much with that.
  6. ChapmanF
    19,025
    I'm kind of wondering whether the electronically controlled brakes are operating at all.
    If the system is fully in hydraulic fail-safe mode, that only works the front brakes, which would explain the rears being out of the game, and from there it only takes a problem with the LF caliper to leave all the braking to be done with the RF.
    Ordinarily that would lead to a bunch of dash lights, but the funky relay situation already suggests the DPO might have noticed some issue with the brakes, and taken some steps to suppress the usual warnings. I'm not positive, but it's possible (I knew somebody with an old SUV who decided "I used to drive cars without ABS anyway" and decided not to fix them, and just drove it that way for years).
    If it were my car, I might start by trying to get the blink codes from the brake ECU. If you can. That would quickly indicate which dash lights do or don't work, and whether the ECU is alive and responding and has anything to tell you.
    If it really has been doing fail-safe mode for who-knows-how-long, the rear brakes probably haven't moved in a while and may need some old-fashioned elbow grease to get working again, and the same may apply to the LF caliper, whatever the reason is that it isn't doing its share.
    So part of this puzzle will definitely involve getting the wheels off and taking a look down there.
  7. Gotsqueeze2345
    Dallas Texas
    Thanks for all the input. Here is what I now know...
    Checked the “normal” braking system and only thing that could be a an issue is the rear brake pads were pretty worn but still had some meat left on them. But I will be replacing them now that I’ve seen that it’s time. My buddy said that he wanted to adjust the rear brakes bc of them being as worn as they are but I read somewhere ( on here I think ) that they automatically adjust themselves and don’t need to be adjusted (I would assume under normal conditions but couldn’t hurt to try?)
    I went to the dealership with my relay and the parts guy asked me where I had gotten it from ( on the fuse panel ) and I showed him and he said originally the car didn’t come with a relay in that spot and that the relay was an aftermarket one that might have been added for an alarm or whatever but not a factory part. I made sure I showed him the correct spot on the fuse panel so I guess that explains why I noticed no difference in the brakes with it plugged in or out. That was a let down as that was the cheapest route out of this mess.
    I went and checked to see what lights come on when starting the car and I guess I don’t know where the brake lights are but they don’t illuminate when the car is started (key turned to on position or start).
    i bought a Bluetooth code reader that you use an app on your phone but the damn thing doesn’t want to keep a connection, make a connection or get the data from the car. Not sure if it has something to do with the push button start, maybe it’s bc the dash is blacked out right now or just another issue yet to be resolved . I think im going to go borrow a friends code reader that I can just plug in and not have to mess with pairing the device.
    I will update with better info as soon as I find it..
    Again thanks for taking the time to offer your advice.
    much appreciated
  8. Mendel Leisk
    42,347
    ^This.
    Toyota USA recommends an in-depth brake inspection every 30K miles or 3 years, whichever comes first. It's spelled out, albeit pretty subtly*, in the Warranty and Maintenance Booklet; a paper copy came with the car when new, and you can download pdf versions from Toyota Tech Info (and "Toyota Owner's" site?)
    Toyota USA says nothing about brake fluid change, but Toyota Canada says tri-yearlly or 48K kms, whichever comes first.
    * Every 5k miles (or 6 months) says to "visually inspect" the brakes, which presumably takes place during wheel rotation. But at 30K, 60K and so on, they omit the "visually inspect" phrase, and instead mention inspection of "Brake linings/drums and brake pads/discs": It is very ambiguous, but you can glean they want you to get serious every 30K:
    #8 Mendel Leisk, Jul 11, 2021
  9. ChapmanF
    19,025
    I am still thinking this car may have a basic electrical issue going on, which would be kind of orthogonal to anything you would learn from the recommended physical brake inspections.
  10. mr_guy_mann
    4,118
    2,014
    NJ-USA
    I might consider NOT replacing the rear brakes until you have some direction on the rest of the system (don't add another variable to the equation) . The rear brakes do maybe 20% of the stopping on a front wheel drive car like this. If you have at least 1 mm of lining on the shoes , that's good enough short term.
    Maybe adjust them if needed- the self adjusters often do not self adjust. As long as the brakes don't drag afterwards.
    Now on your dash, press the power button twice without pressing on the brake pedal. Tell us all the warning lights that you see on the dashboard, to the left and right of the speedometer.
  11. Mendel Leisk
    42,347
    Or just post a pic.
  12. Gotsqueeze2345
    Dallas Texas
    No lights ever come on related to the brake system. Never. Only light that is illuminated is the check engine light, which was because the catalytic converter was stolen. Prior to that it had no check engine light on.
    This is now what I know or better yet think I know...
    I’ve gone to 2 dealerships and Asked for the hydro booster relay since that is what DTC my code scanner keeps reporting. I will include pics of the data that was pulled from the code scanner and a picture of the missing relay ( the one that was on the cAr had been taped back up and can’t find the correct replacement relay part number bc Toyota says that the spot on the fuse box that I removed it from was not a factory spot for a relay and was actually empty from the factory).
    The missing relay is The spot I’m pointing to in the picture of the fuse box. AD5D7F6F-E169-487C-8132-1382A298DD2E.png CEDCB0C9-7153-406F-816B-8E64B049A97B.png EAB67E6A-1F7F-4FAB-92B3-484AC875CAB0.png AD5D7F6F-E169-487C-8132-1382A298DD2E.png CEDCB0C9-7153-406F-816B-8E64B049A97B.png EAB67E6A-1F7F-4FAB-92B3-484AC875CAB0.png
    If you look at data I noticed that the front right tire seems to be off on all the readings. Starting off by reading the car is traveling 1 or 2km
    While sitting in park.
    I was stupid and didn’t read about bleeding the brakes being an issue and my buddy of course bled the brakes as if A normal brake system. When he was about to close up the line after bleeding it some air pump or whatever kicks in to make the brakes work and I assume pumped more air into the brake system.
    I then tried to bleed the brakes with the code scanner (HT200 by Autel). The app always stops working or responding when I turn the car off ( part of the instructions for bleeding the brakes. I’ve even tried by not turning the car off and the app on my iphone loses Bluetooth connection with my phone and the VCI, everything has to started over from the beginning. I thought it might be a security feature that is blocking it from reconnecting once powered off and back on. I thought about trying with An android phone and see if I have the same connection issues.
    I also included a picture of the rotors, is that how they’re supposed to look ?
    Thanks again for all the input, hopefully I did dig too deep in the wrong direction.
  13. Mendel Leisk
    42,347
    There's enchroaching rust on the rotors, into the area swept by the pads. Not terrible, but might want to spring for new rotors; if they're original, 250K miles is a lot.
    addendum: pic of ours (2010, gen 3), around 90k kms, and pampered west coast BC. Cobwebs hmm…, it hasn’t been that long, energetic spiders?
    Second gen brake info, including rotor specs, in attachment. With a dial indicator (with magnetic base) and 0~25 mm micrometer, you can check against spec. Still, new rotors probably simplest/cheapest, at this time. Brake bleed info attached too, might help.
    #13 Mendel Leisk, Jul 27, 2021
  14. BuildingInspectorBrian
    BuildingInspectorBrian Junior Member
    32
    Tacoma
    Replacing brake fluid and bleeding brakes on a GEN II Prius without Techstream | PriusChat
    Moisture in the brake fluid can cause similar problems with your braking system as well. Bleeding the brakes on the gen 2 without techstream is a pain in the butt(I just did it a few weeks ago), but it's not more than a two man two beer job. It should only take you about 90 minutes.
    This is a quick and cheap process to eliminate one of your variables.
    Also, if you noted your bluetooth scanner was having connection issues.
    Hybrid battery diagnostic and repair tool for Toyota and Lexus (priusapp.com)
    click on the "what obd2 to buy" I purchased one from amazon through one of the links provided. Was in hand in two days and worked great with the DrPrius app (I think the one I purchased was about $13, well worth it).
  15. esskay
    esskay Junior Member
    82
    @Gotsqueeze2345 Not sure if this will be helpful to your situation, but here's my saga of replacing my brake actuator: Need advice: Brake, (!), ABS, VSC lights on | PriusChat. Part way through this process, I removed a bad replacement actuator I got on eBay with the original brake actuator (which was going bad). Given I had removed/replaced actuators twice at this point, there surely was air all throughout the system that shouldn't be there. I didn't have Techstream at the time, so I tried doing a non-Techstream brake bleed process that was posted on PriusChat (I think someone else linked it above).
    Then I took the car for a test drive, and the brakes were totally wacky, notably including the left front tire locking up for no particular reason... which is what you seem to be describing.
    I eventually replaced the original brake actuator with a brand new one, then ran the full Techstream bleeding and initialization procedures. The Techstream bleeding process is really long, runs various solenoids, and has lots of steps to bleed the entire system. After all this, my brakes are back to normal.
    So perhaps you have air in weird places in the brake system... or your brake actuator is going bad.
    Maybe you could try using Techstream to run a proper full brake bleed process.
  16. BuildingInspectorBrian
    32
    Tacoma
    Just as an additional note, bleeding the brakes the non techstream way simply required re-initializing the diagnostic mode several times throughout the procedure. If you have any experience bleeding brakes it's actually quite simple. My 2005 Prius with only 132k miles on it had horrible brake fluid in the lines. I'm quite glad I screwed up the rear drum install(didn't get the spring on the shoes quite all the way and ended up having springs, shoes and clips all over the driveway(many colorful words were heard to the heavens) which forced me to bleed the brakes. I was kind of shocked the fluid was in such bad shape(I've purchased used vehicles much older with more miles and not seen such awful looking fluid). Given the mileage I wouldn't hesitate to essentially do a full service on the vehicle.
