Brief rattle/knock at cold start
Discussion in 'Gen 4 Prius Main Forum' started by Teewin, Mar 11, 2017.
  1. Teewin
    Teewin Junior Member
    Chicago
    Just picked up a 2017 Prius 4 for the wife a few months ago. I did a quick search to look for knocking rattle issues on a cold start but didn't find anything pertaining to gen 4s only 2010 and 2011 models saw this behavior. When left sitting overnight in our garage temps around 30 to 40. When I first start her car, as soon as the engine kicks on I hear a 1 to 2 second rattle noise which dissipates and doesn't happen again, even if I shut the car off and restart it. Anyone experiencing this? Oil level is half on the dipstick btw
    Michael Wood likes this.
  2. Mendel Leisk
    42,299
    How many miles on it, new purchase? I would think oil would have been at full mark when delivered to you; was it higher before?
  3. Teewin
    Chicago
    Yes new purchase, oil is the same, 2200 miles on it. Seems unlikely to cause a rattle even if the oil was at the bottom mark on the dipstick...
    #3 Teewin, Mar 11, 2017
  4. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    No rattle here, at 10000mi // 17000 since June 2016
  5. priusgto
    priusgto Active Member
    194
    231
    Northern Arizona
    Mine had the same rattle at cold startup with genuine Toyota oil but not with Mobil 1. Mobil kept it quiet for about 6500 miles, then the rattle started again. I changed the oil at 7k, again with Mobil 1, and all is quiet again.
    See this thread,
    Only Mobil 1 For My Prius | PriusChat
  6. Chippingawayatlife
    Chippingawayatlife Active Member
    159
    116
    San jose
    Can you upload a video so I can listen to see if I great something similar?
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I can often hear mine start first time in the morning, I wouldn't call it a rattle though - just slightly more noise than if it's hot. Much less noise than say a "normal" starter motor. Or my previous diesels starting.
    Chippingawayatlife and RCO like this.
  8. bisco
    52,804
    congrats and welcome!
    just sounds like a normal toyota engine anomaly. 'snafu'. enjoy the mpg's!
    pilotgrrl and Tande like this.
  9. Teewin
    Chicago
    Yeah it hasn't reproduced the noise. But I will post it once I am able to get it. Seems the Prius won't reproduce the noise when I have the camera on and ready to record...funky how that works. No wonder Toyota service can NEVER reproduce any customer issues... Haha
    Josem3 and RCO like this.
  10. Chippingawayatlife
    159
    116
    San jose
    I see. Yea I've always wondered about the pronounced noise and vibrations the engine makes during the first two cold turns. But like Alanclarkeau mentions, it's probably the lack of starter sounds that drowns out everything I'm not used to. I'm thinking as long as it pumps in oil before combustion, I'm at ease.
    Teewin, RCO and alanclarkeau like this.
  11. Oregon123
    Oregon123 New Member
    Oregon
    2019 Prius
    2019 with 5k same issue. Did you ever figure out the reason?
  12. alanclarkeau
    7,045
    7,593
    That's noisier than mine - though to be honest, I've never listened from outside. Maybe check with your dealer.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Does it have 0w20 oil in it, thicker at cold oil such as 5w20 will not circulate as quick.
  14. dy/dx
    dy/dx Junior Member
    26
    United States
    My 2017 Prius has a rattle noise at start-up coming from the timing chain cover. Does anyone have an idea what is causing this noise? Is there a tensioner I can replace from the outside?
  15. -Yousef-
    -Yousef- Junior Member
    25
    Saudi Arabia
    I occasionally have the same rattle on start-up on my 2017 as well and it's been like that since new , now at 35km and I'd think it's a normal characteristic of this engine.
    Tande likes this.
  16. dy/dx
    dy/dx Junior Member
    26
    United States
    Thank you Yousef for your response. It sounds like a metal to metal clatter with no oil lubrication for a second and then goes away. It only happens when the engine sits for a while. Do you have the same experience?
  17. -Yousef-
    25
    Saudi Arabia
    Yes usually when the engine is cold as I notice it more during the winter months.
  18. RidiculousMPG
    RidiculousMPG New Member
    York, PA
    2021 Prius
    XLE AWD-e
    Did anyone ever get a definite answer/solution on this? I have 2021 awd, 3,000 miles, so it still has oil from factory. When gas engine first starts, occasionally i hear this brief rattle/clicking noise from engine compartment for about 1-2 seconds (if you were not paying attention or had radio up you probably wouldn’t notice it). A little disconcerting……
  19. alanclarkeau
    7,045
    7,593
    Just think - if you had, say a Corolla NON-HYBRID, and turned the key - you'd hear the whine of the starter motor and the ICE starting up - and wouldn't notice that momentary rattle/clicking for the racket from the starter.
    I occasionally hear it, but it doesn't worry me.
  20. alanclarkeau
    7,045
    7,593
