Build Hybrid Battery Maintenance Gear For Under $100
Discussion in 'Gen 2 Prius Main Forum' started by PriusCamper, Mar 25, 2021.
Thread Status:
Not open for further replies.
  1. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    SFO likes this.
  2. chickenhawk
    chickenhawk Member
    261
    96
    CA
    #62 chickenhawk, Nov 10, 2021
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Not that I'm aware of, but then neither does the Prolong.
  4. chickenhawk
    chickenhawk Member
    261
    96
    CA
    so far here is BOM minus anmeter/voltmeter (still looking on ebay.. as Aliexpress ship might get stuck in harbor) , the fan power supply I will use ATX power supply i have lying around, and will look for the diode/resistor in my parts bin
  5. alftoy
    1,132
    519
    Order from Digikey, Aliexpress, beware of knockoffs. EDIT: OK looks like a Digikey BOM
    LPC-100-350 MEAN WELL USA Inc. | Power Supplies - External/Internal (Off-Board) | DigiKey
    chickenhawk likes this.
  6. chickenhawk
    chickenhawk Member
    261
    96
    CA
  7. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Odd, even the freebie (no longer free) from HF does 1000V DC. Have you tried the big box stores/web (lowes, HD, etc), many start at $10.
    Which metroplex in CA are you nearest, as the country and the state are both fairly large.
  8. chickenhawk
    chickenhawk Member
    261
    96
    CA
    Yes I noticed one of the poster used 2 HF multimeters that they were giving out for free back in the days. I guess i can use my spare FLUKE meter and pickup meter from HF I'm Los Angeles county.
    HF
    7 Function Digital Multimeter
    #68 chickenhawk, Nov 10, 2021
  9. alftoy
    1,132
    519
  10. chickenhawk
    chickenhawk Member
    261
    96
    CA
    #70 chickenhawk, Nov 17, 2021
  11. chickenhawk
    chickenhawk Member
    261
    96
    CA
  12. chickenhawk
    chickenhawk Member
    261
    96
    CA
    The cheapest meter at Harbor Freight is no longer an option now because they are using different parts in it therefore the max voltage it can read is 250V DC !! Do not buy the ones in the stores anymore as they don't carry the previous model Item #98025 anymore that can read up to 1000V DC.
    I ordered the digital meter in the OP off eBay, it says it located in USA but just noticed after I placed order that the Ebay seller is probably lying and is shipping from China :mad::mad: Hate these people that say they are US base when they are not. In the mean time if I probably use my Fluke meters.
    ydpplqbd and SFO like this.
  13. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    Thank you for finding this fuse holder & fuses at Digikey!
    I just received my order & the fuse holder is perfect.
    Screw together ends hold 5mm x 20mm fuses. 16ga wire leads.
    Here is the Digikey p/n in text form (so a search engine can find them).
    Digikey p/n - Description
    F1468-ND - Littlefuse Inc Inline fuse holder = 350V/10A
    486-1768-ND - Schurter Inc Ceramic Fuse, 2.0A, 300VDC
    486-1800-ND - Schurter Inc Ceramic Fuse, 2.5A, 300VDC
    486-1773-ND - Schurter Inc Ceramic Fuse, 3.15A, 300VDC
    alftoy likes this.
  14. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    @alftoy was wondering about a fan speed controller for Gen 2 packs... This is what @fach is using:
    SFO likes this.
  15. christian cox
    christian cox Member
    115
    ohio
    Can the INSIGHT grid charger be used on the Prius hybrid battery?? It seems like if you left it charging it would eventually get the Job done?
  16. alftoy
    1,132
    519
    You say you built a grid charger without noticing post #3 pertaining to using this build on an Insight vs Gen 2 Prius?
    How important is it to buy and install a "Grid Charger" | Page 2 | PriusChat
    Post #3
    Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
  17. PriusCamper
    13,455
    5,430
    Grid charger needs to be higher voltage than the pack when fully charged. So an insight charger would work on a Prius C, which only has 20 modules instead of 28, but it wouldn't work on a standard Prius pack.
    SFO likes this.
  18. christian cox
    115
    ohio
    PriusCamper likes this.
  19. PriusCamper
    13,455
    5,430
    it's the amount of push that counts... a tiny push with less than 1/2 an amp will dissipate as heat rather than an explosion in each module once it's fully charged as long as you have cooling to take that heat away.
  20. christian cox
    115
    ohio
    I recently watched a guy on you tube that charged his hybrid battery with a 12v car battery. And it seemed to work fine as long as you keep your eye on it. So it seems to line up with what your saying. 12volts charging time get a SOC OF at least 8volts. heres the link-
    #80 christian cox, Apr 10, 2022
Thread Status:
