Buy new/used FOB for Prius 2 in 2022
Discussion in 'Gen 2 Prius Main Forum' started by Victorio Mo, Nov 8, 2022.
Tags:
  1. Victorio Mo
    Victorio Mo Member
    123
    31
    Folsom, California
    I need replacement for my Prius 2 (have old key). Do you know where I can buy good now, on ebxx saw only shells. Also saw couple of good videos how to program it without any special tools.
    Appreciate you feedback.
    Most recent post here about key replacement was back in 2010, probably something got changed -)
    Thanks
    Dai
  2. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
    Many on eBay just look harder.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    Again, many listings on amazon and ebay for Gen2 key fob.("2007 prius key fob")
    Be sure to order correct type for your car (SKS or not).
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Yes. I can provide a link to what I've purchased and programmed successfully, but need to know if you have SKS or not.
  5. Victorio Mo
    Victorio Mo Member
    123
    31
    Folsom, California
    Thanks all for help.
    I don't know know yet what is SKS, will try to do my home work. My fob doesn't have any sliver logo and no any markings on the outside.
    JTDKB20U877671371
    Thanks
  6. mr_guy_mann
    3,966
    1,914
    NJ-USA
    SKS - fob has silver logo, car has black rubber button next each exterior door handle and tailgate handle. There is a click (on-off) push button to disable SKS under the steering column (usually next to the "TPMS reset" button (if equipped).
    SKS lets you keep the fob in your pocket, walk up to the car, and it will unlock when you reach for the handle. You car start the car without putting the fob in the dash slot. You can lock the car by pressing one of the black buttons on the outside.
    Also has normal remote lock and unlock buttons on fob.
    Non SKS has black logo and only has remote buttons on fob, and you have to put the fob in the dash slot to turn the car on.
    The two fobs are not interchangeable.
  7. Victorio Mo
    Victorio Mo Member
    123
    31
    Folsom, California
    Thanks Mr all ALL for help !
    I have SKS, without Silver Logo though, probably shell was changed.
    I always get into the care and drive having it in my pocket.
    Found few sellers they ask what is my FSD #... I will figure out.
    #7 Victorio Mo, Nov 10, 2022
  8. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Get this. I've used 2 of them and they have been flawless. They include instructions on how to program it.
    For 2004 2005 2006 2007 2008 2009 Toyota Prius Smart Prox Remote Car Key Fob | eBay
    sorry, I changed the link. This is the one that had instructions included, which worked very well. The other link was one I bought later where it didn't include instructions, but the instructions I had from the previous purchase worked perfectly also.
    And the silver logo back plate is available for purchase from Toyota if desired. Plate only, not the complete case. I think they're around 15ish bucks.
    Genuine Toyota Cover Transmitter H 89751-47010 | eBay
    #8 TMR-JWAP, Nov 10, 2022
    tacopyro, Toyota2, SFO and 1 other person like this.
  9. Victorio Mo
    Victorio Mo Member
    123
    31
    Folsom, California
    Thanks TMP- and all !!!
    Does anybody care about cutting physical key for 2nd FOB, probably it will be never be used.
    I also got friend who can spare same type of used key from his dead Prius, will try to program it to see if this will work.
    #9 Victorio Mo, Nov 12, 2022
  10. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    I would verify that the physical key works properly, then have the new blank cut to match. Mostly because, if I didn't, I know darn well I would end up needing it! Probably only a few dollars at a local key/lock business.
  11. Another
    1,818
    515
    Naples, Florida
    My local locksmith charges $2 to cut a Prius blank
  12. Victorio Mo
    Victorio Mo Member
    123
    31
    Folsom, California
    Florida is super nice to have $2 cut, I'm in San Francisco, will check tomorrow how much they charge.
    Looks like it's a huge market for FOB, they Seller that was was recommended by TMR ran out of them.
    v
    #12 Victorio Mo, Nov 13, 2022
  13. Another
    1,818
    515
    Naples, Florida
    Check a local ACE Hardware to cut the key
  14. Victorio Mo
    Victorio Mo Member
    123
    31
    Folsom, California
    I got one with SKS, saw several versions for self programming with and without old unit, can anybody share which one worked for you ?
  15. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
  16. Victorio Mo
    Victorio Mo Member
    123
    31
    Folsom, California
    Thanks, I bought one recommended by TMR above (seller = extra-partss ) for 85$.
    https://www.ebay.com/itm/362891411684
    Seller pointed me to this video how to with old remote, which is only for basic programming
    When I asked they replied that this all i need.
    I went thru first part of programming (with cradle) and it didn't work, will try again.
    Thanks
    #16 Victorio Mo, Nov 21, 2022
  17. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Did you get it to work?
  18. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Did the FOB not come with instructions?
    The one I purchased had a small instruction sheet that was essentially 'the chicken dance' and it worked perfect for complete programming.
