Calendar days off?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by wrenwren8, Jan 13, 2018.
  1. wrenwren8
    wrenwren8 New Member
    22
    Alden, NY
    I set my charge schedule for 7 am departure every Monday through Saturday. I have only had my car for about a month (Prime Plus). Every Wednesday morning, the car is not charged. I am suspecting that perhaps the days of the week are not correct in the car settings? I can think of no other reason why the car is never charged and ready to go on Wednesday mornings. I have found the setting on the car to selection the Time, but nothing regarding setting the date. Does anyone have any insight?
  2. Elektroingenieur
    2,515
    3,288
    Three Touring
    You can set the date using the multi-information display, under ⚙ > Meter Customize > Calendar.
    Prodigyplace likes this.
  3. wrenwren8
    22
    Alden, NY
    Thank you!
  4. wrenwren8
    22
    Alden, NY
    Unfortunately, I am still unable to locate this setting :(
  5. Elektroingenieur
    2,515
    3,288
    Three Touring
    See pages 181, 205–207, and 231 in the Owner’s Manual (PDF).
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    From looking in the manual, it is set on the small MID display beside the speedometer. Scroll until you see the Settings gear on the display menu.
    Select "Calendar"
    I just searched for the manual on line since I do not own a Prime, just a Gen 4 Prius.
    2017 Toyota Prius Prime Owners Manual and Warranty - Toyota Owners
  7. wrenwren8
    22
    Alden, NY
    I read that in the manual... But when I scroll through the settings, I can't find any calendar....I tried looking through the settings in the apps as well.. I think it may be where ever the diary is located. When I select settings, I can change all kinds of things,,but not calendar,,,I am still struggling with how to get to some of these features...ugh..I shall have to sit in the car again tomorrow and push more things lol...
  8. Prodigyplace
    12,712
    11,848
    Central Virginia
    I do not know what your dealer is like.
    If I were closer to where I bought my Prius I would ask my salesman to help. He would find out if he did not know, but he is a Gen 1 Prius owner so he values Prius knowledge.
    I do not even go near my local dealer unless absolutely necessary.
  9. emek
    emek New Member
    West
    2022 Prius Prime
    In case anyone else has been searching for a solution to this and struggled to find this setting: It's not in the Settings menu in the main display screen, which is where I went but couldn't find what was described. Finally discovered that that the Settings menu in question is in the dashboard screen, in the controls you reach through the < > arrows on your steering wheel, the same place where you go to set the clock, but if, like me, you never used anything there but the clock and climate settings, look again -- there's a gear icon for a completely different Settings menu. Open that, scroll down, and you'll find the elusive "meter customization" menu.
    I also realized the original cause of the date going off, at least in my case: the 12V battery had died while I was away on an unexpectely long trip.
    This is my first post in this forum, and happy to contribute something since I've benefitted so much from it. Thank you all!
