Can Smart Keys be Reprogramed?
Discussion in 'Gen 3 Prius Technical Discussion' started by JohnCleary, Mar 9, 2012.
  1. w1n78
    w1n78 Junior Member
    29
    CA
    Four Touring
    just picked up a 2013 sienna that also has a smart key. i can't start my prius when both keys are with me. i have to put the sienna key on the roof to start the prius lol.
    there's also some interference when i'm in the sienna - "key not found" but i can start her. here's a video i made in my prius
    what should i expect from the dealer?
    52,889
    try to upsell you to avalon.;)
    w1n78 likes this.
  3. retired4999
    2,652
    627
    Eau Claire, Wi.
    Get a small aluminum box to put the other key fob into. Then start car.
  4. alejandrolevin
    alejandrolevin New Member
    Hi Ovni (objeto volador no identificado?)!!
    I live in the bay area and have a prius 2009, if I bring a used key could you help me reset it?
    Thank you,
    looking forward to your reply,
    Alex
  5. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    I believe this has been printed in the manual having two smart keys inside the car. Your prius smart key's battery may be weaker than your sienna smart key too.
  6. w1n78
    w1n78 Junior Member
    29
    CA
    Four Touring
    inconvenience :( for now, i set the key on the roof to start the car. if i have to close the door while the engine is on, i have to set the key again on the roof. otherwise i'll leave the key at home.
    oh? as in 2 smart keys in general? because before we had the sienna, my wife and i bring our prius keys and take them even when we are both in our prius and no interference. a co-worker did mention interference with his key and iphone together in his pocket.
    i was able to stop by a dealership and showed a service rep what was happening. he was stumped, went inside told 2 other reps. came back outside and suggested to make an appointment with the toyota rep that visits them each month and see what he says. hopefully there's a better solution than the roof or leaving the key at home when we use the prius or vice versa with the sienna.
  7. ImeanGreen
    547
    73
    Somewhere out there
    See opening, closing and locking doors section and go to "conditions affecting operation" of your owner's manual.
  8. JimY4
    JimY4 New Member
    I too bought a used key fob for a 2010 Prius. I've taken it to 2 independent repair shops and 2 different Toyota dealers and none of them were successful in getting the car to accept the key. My fob had 3 of the four markings listed above on it: "FCC ID: HYQ14ACX", "IC: 1551A-14ACX" and "DENSO 14ACX" I had thought the important one was the FCC ID but maybe there's more to it than that. The used one has a grey plastic case rather than a black case on the one that came with the car. Just on a lark, I opened the both cases and checked the markings on the large black chip inside each. The one that came with the car was marked "2026" and "100201VC". The used one was different - "2026" and "130514VD" which may explain the difference. I guess it's back to square one on looking for a 2nd fob.
  9. Simonak
    Simonak Member
    Did they reset the SKS when they tryed add the used fob? If not that's the only way to add used fob.
    If you need more info check this post Successful SKS Reset using Mangoose cable and used Keyfob registration | PriusChat
  10. PriusNP
    PriusNP Junior Member
    85
    17
    Anyone do reprogram key in NYC or nearby within 1 hour drive.
    Thanks
  11. michael dale
    michael dale New Member
    atlanta, ga
    Can you tell me what is the name and number of the locksmith you used in atlanta to reprogram your gen 3 prius key fob? I have a used key that need reprogramming. Thanks in advance.
