car does not READY
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, Nov 11, 2017.
  1. franken1313
    franken1313 Member
    216
    27
    US
    I don't think the 12v is low. I'm also getting a p lock abnormal message on the screen
  2. franken1313
    franken1313 Member
    216
    27
    US
  3. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    "A new AGM battery, fully charged, should measure ~12.9V. 12.1V is discharged."
    #23 kenoarto, Nov 12, 2017
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    YES, the solution!!!! What more information could you possibly need?
    Sorry, just feeling frisky today I guess....
  5. kenoarto
    398
    Chicago, IL
    Let's start with a proper 12v battery test.
  6. franken1313
    franken1313 Member
    216
    27
    US
  7. dolj
    dolj Senior Member
    8,565
    4,352
    Wellington, New Zealand
    So, you are unplugging that wire loom and then replugging? If so, it is not "a wire", but "a group of wires".
    That icon at the top right is the HV battery warning icon. It means there are HV battery DTCs set by the HV battery ECU.
    The problem with using a generic code reader is, the Prius has 11 or more ECUs and the generic reader can read 1 ECU, the PCM. You are not therefore getting a complete picture of what is wrong with your car. JC is on the money, IMHO, you have at least a HV isolation leak which prevents you car from restarting until you do that reset by pulling that plug.
    #27 dolj, Nov 13, 2017
    kenoarto likes this.
  8. franken1313
    franken1313 Member
    216
    27
    US
    How do I find the HV leak?
  9. dolj
    dolj Senior Member
    8,565
    4,352
    Before you go any further you need to read all your codes from all the ECUs to confirm what problem you actually have.
  10. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Y don't youvkust follow what most folks here have being saying? Get a hybrid compatible scan tool, and get the codes over here. I think that would help, instead of talking about the 12volt battery thing.
  11. franken1313
    franken1313 Member
    216
    27
    US
    Which would be the best scan tool?
  12. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    weak 12 volt battery
  13. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    If you've got a laptop, you can buy a Toyota tech stream for some few dollars on eBay.
  14. kenoarto
    398
    Chicago, IL
    How about charging the battery to 12.9 v?
  15. franken1313
    franken1313 Member
    216
    27
    US
    I have charged it to 14v with a generic battery charger
  16. franken1313
    franken1313 Member
    216
    27
    US
    It's a brand new battery. I just replaced it days ago bc of this problem but a new 12v didn't fix the problem
  17. kenoarto
    398
    Chicago, IL
    SFO and SpaceCityHybrids like this.
  18. SpaceCityHybrids
    38
    52
    Houston
    Voltage leak somewhere. The Prius won't show the ready light when the 12v line is oscillating or noisy.
  19. SpaceCityHybrids
    38
    52
    Houston
    Best bang for buck route is an ELM 327 OBDII sensor with bluetooth or wifi and the Torque app on an Android.
    You can pretty much get all of the Toyota ECUs with Torque.
  20. franken1313
    franken1313 Member
    216
    27
    US
    I have the obd2 Bluetooth & the torque app & I am getting no codes
