Car in neutral while running
Discussion in 'Gen 2 Prius Technical Discussion' started by DWJM2513, Jan 12, 2019.
  1. TomB985
    TomB985 Member
    137
    68
    Isanti, MN
    That changed on the third generation for the 2010 model year, all second-generation cars have the belt driven water pump. But they also have an electric water pump circulates coolant to the heater core and back, so the end result is the same.
    There are a total of four water pumps the second-generation cars, three of which are electric.
  2. fuzzy1
    10,652
    Or he lives in a place where he doesn't need to run AC much during a pull-through car wash.
    Or his traction battery is not yet displaying the frailties of advanced age.
    Or he is reasonably good about entering the wash with a reasonably charged battery, e.g. showing 6 bars instead of 2 or 3.
    The low battery issue in tunnel car washes has always been a sometimes thing, especially in hot weather, not a most-of-the-time thing.
    TomB985 likes this.
  3. DWJM2513
    DWJM2513 Junior Member
    64
    24
    US
    Ok just putting this out there. My original post had NOTHING to do with a car wash. Somebody started that aside from what I originally asked.
  4. TomB985
    TomB985 Member
    137
    68
    Isanti, MN
    You were asking about running the car with the transmission in neutral, and this was brought up as an example of how quickly the battery can die. Is that not directly relevant to your question?
    Skibob likes this.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Correct. You question only concerns the electrical destruction of your car battery via N; trying to use N in a car wash involves the physical destruction of the car suspension. (and car wash, in newer generations. Instead of staying in N until the battery dies, newer Prius generations shift back to P to save the battery. So your car is drug through in P, not good for the car wash or car)
  6. DWJM2513
    64
    24
    US
    No not a car wash as I added that I would set the parking brake before I put it in neutral
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Besides which, you never told us the color of your car. What the heck does the parking brake have to do with draining your traction battery?
    If the car is in READY and in neutral, the system will use power from the traction battery which the engine will not replace while it's in neutral. Plain and simple. Everything else is irrelevant. From page 15 of our '07 owner's manual:
    "Be sure to put the hybrid transaxle in “P” when parking.
    In “N”, the hybrid battery assembly is not charged, even if the gasoline engine is operating. You cannot run your vehicle if the hybrid transaxle is left in “N” for a long time because the hybrid battery assembly will be discharged."​
    RTFM. It's just that simple.
    #47 jerrymildred, Jan 14, 2019
    Skibob, TomB985 and Prodigyplace like this.
  8. Prodigyplace
    12,706
    11,846
    Central Virginia
  9. Leadfoot J. McCoalroller
    8,225
    7,727
    Pennsylvania
    2018 Prius c
    To write it another way:
    1. All on-board electrical generation in a Prius is done by the transmission.
    2. The Prius transmission cannot ever physically disengage gears.
    3. So the only way to neutralize the engine's output is to cut the electrical power between the transmission and the rest of the car.
    TomB985 likes this.
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Threads in forums like this tend to "wander" a bit.
    You got your answer very early in the thread so I didn't feel too bad about a hi-jack.
    Especially since it was essentially the SAME situation that you were asking about.
    Skibob likes this.
  11. jerrymildred
    11,517
    14,164
    Tampa, FL
    Thanks for catching it. Glad I saw it in time to fix the typo. (y)
  12. Mendel Leisk
    42,148
    Above is quote from: Car in neutral while running | PriusChat
    Above is quote from: Car in neutral while running | Page 2 | PriusChat
    @DWJM2513 , could you respond to my question; was that your objective, simply to keep the engine running? Does anyone know if that's true: the engine won't shut down in Neutral??
    And as I said above, putting the car in Maintenance Mode is the way to go.
    TomB985 likes this.
  13. DWJM2513
    64
    24
    US
    When the engine starts back up, it lunges the car forward and Ive read other forums that say that is normal but in my mind it's pushing against whatever is keeping the car in place (parking pawl) and just the wear on the engine everytime that engine fires back up (starter, dry piston walls until the oil gets pumped up there) and I'll take a video later tonight and post it on here where the engine won't shut off when in neutral
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It is true, the engine starts and stops with the help of the Motor/Generators. As they are unpowered in N, the engine can neither start nor stop in N.
    (This dates me) I think of an online conversation like cigarette smoke, at first it is a straight line, then it wanders wildly.
  15. DWJM2513
    64
    24
    US
    I 100% agree about the way you think with the cigarette smoke. Like I up above, someone out of the blue brought up a car wash and it went haywire from there with the arguing
  16. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Honestly just do what you want at this point, it’s obvious you don’t want to listen to everybody on this site telling you not to do it. One thing I would like to add about your oil theory is that that only happens when the car sits for longer periods of time. The oil clings to the parts quite well in between the few minutes the engine is idle. Let us know what happens though. So many people request information but never share the results around here.
    To everyone trying to convince him. The system has a moron warning system, hopefully he figures it out from that.
    jerrymildred likes this.
  17. DWJM2513
    64
    24
    US
    Damn bud someone must have pissed in your cheerios this morning. Just asking a question and it's assholes like you that has to ruin the entire post from saying shit like that. You wanna be butthurt from someone asking a stupid question? Get the hell off any forum out there. Especially mine
  18. Mendel Leisk
    42,148
    Maybe something's up with his transmission, lurching?
    Still, this is a scenario I never encounter: any time I'm shifting into gear I've got my foot on the brake. (n)
  19. Leadfoot J. McCoalroller
    8,225
    7,727
    Pennsylvania
    2018 Prius c
    Yeah I'm also curious about this 'lurch,' whether it's just the normal bump from an engine start, or something else?
  20. TomB985
    TomB985 Member
    137
    68
    Isanti, MN
    I felt a lurch as well, and it's very normal. The engine is started from the sun gear of the planetary gear set, in the ring is attached to the final drive. Which means there’s also a torque applied to the final drive whenever the engine is started.
    Remember that these cars have a very well established reliability history. The engines are almost unheard of to fail without permission. The exception to that, of course, is when they are run out of oil or overheated. That would not apply in your situation, and there are enough 500,000+ mile cars out there to dispel the myth that starting and stopping causes undue wear on the engine. Likewise, transactional failures are exceedingly rare, and I've never heard of a failure in the parking gear.
    Battery failures happen, though and idling in neutral is just asking for one.
