Changed evaporator in 05 and now blower motor doesn't work
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gmcneil05, Sep 5, 2015.
  1. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    So the evaporator in my dads Prius had been leaking for a while so we finally decided to bite the bullet and change it. Everything came apart fine. Changed the evap and expansion valve. Put it pretty much back together except for glove box and a pillar trim pieces. Push power button twice to make sure all the flaps and blower motor works as it should. Well the blower motor doesn't come on. I hear the relay click when you turn the fan on in the mid. No power at the fan though. I checked just to be sure. I've looked all over for loose wires/plugs but have yet to find anything. I started the car up and everything works fine except the blower motor. Any ideas as to what it could be?
    #1 gmcneil05, Sep 5, 2015
  2. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    open it up, set the fan on medium speed, push the fan with a finger, (or a stick if you are afraid to use your finger) see if it wants to spin after you poke it.
  4. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    I have tried that but the fan is not getting any power. I checked with a bolt meter.
  5. ChapmanF
    15,929
    As it's almost certainly something that happened in the course of your work, a careful retracing of steps ought to find it. The wiring diagram manual on techinfo.toyota.com will identify all of the connectors on that path that you might have touched, in case you missed (or just partly-reconnected) any while reassembling.
    -Chap
  6. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    I've rechecked all the wiring and everything is plugged in. Is there any way that the computer would not let the fan come on since the ac system is not charged. I would not think that to be the case but I don't know what else to do. Maybe just go ahead and charge it and see.
  7. ChapmanF
    15,929
    I would not either. If it were me, I'd be in there with my multimeter checking all the connections that look like I made them back up.
    -Chap
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,810
    Clearwater, Florida
    The motor leads connect to Blower Motor Controller B3 which is really close the 12 volt port right below the glove box. Its rather small controller. The B+ that feeds that controller is via 40 Amp Fuse "HTR". Drive signal to that controller comes from controller AC A7 underneath the center kick panel close to the floor.
    Good Luck.
  9. edthefox5
    10,096
    4,810
    Clearwater, Florida
    Not an ac guy so not sure if the blower motor is prevented from turning on if any parameter is not met with the ac system.
    Some ac guys will come by soon.
  10. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    Thanks. I'll follow your schematic tomorrow and hopefully find the problem.
  11. edthefox5
    10,096
    4,810
    Clearwater, Florida
    Good luck. Have seen very few evap coils replaced under the dash here so I feel for you. Very big job. Hope I helped.
  12. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    Well it ended up being a loose plug in the panel left of the column. Only had one larger blue wire in it. I don't even know why it was loose cause I didn't unhook anything else from there but anyways it's fixed. Thanks for the help.
    valde3 and bisco like this.
  13. Patrick Wong
    18,200
    6,479
    How did you decide the evaporator was leaking?
    Was this visible via the use of dye or compressor oil leaking out?
    Can you post photos showing the location of the leak?
  14. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    Well 2nd gen Prius I've found have a issue with evaps leaking with age. I had a friend with a freon sniffer detect a leak out of the vents inside the car just to make sure before I tore it apart. Once I did there was a light coating of oil on some of the vent ductwork and oil in the case around the evaporator. I actually have 2 07's in the family that both need the evaps changed but I've been leery not having any instructions of previous people doing it. But now that I've done one I should have done it along time ago. Wasn't nearly as difficult as I expected. The next one I do I'll be sure to take pictures and make a nice write up.
    valde3 and Patrick Wong like this.
