Charging fan?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by SR-71, Nov 10, 2019.
  1. SR-71
    SR-71 Member
    98
    108
    NC
    After my '17 Prius Prime Advanced charges I sometimes hear [what I'm guessing is] a battery cooling fan noise, in the rear of the car. Eventually the fan noise stops. Is this normal?
    52,854
    its not the cooling fan, its another system doing an evaporations test
  3. SR-71
    SR-71 Member
    98
    108
    NC
    bisco - Interesting. So this is a normal operation for the car? Reason I ask is, I've had the car for 3 years and have only heard this fan noise a few times.
    vvillovv likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Actually, what you're hearing is most likely the battery charger cooling fan. It's pretty loud and I'm not sure I've ever not heard it when it's charging. When it's done charging the battery, the charger shuts off and so does its fan. The battery fans themselves might run while charging in warm weather, but I'm not sure they would be loud enough to be heard over the charger fan.
  5. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    I am pretty sure it is the battery charging cooling fan that you are hearing. My 2017 used to ask me if it was OK to use it while charging. I don't remember seeing the message on my 2020 model. But I do hear the fan when the weather is warmer. When I am vacuuming the car I often clean the vents for the fan in the back seat area.
  6. Tideland Prius
    16,680
    There is a fan there. You can touch the plastic piece below the rear seat and you can feel where it's cooler (where the fan is) and where it's warmer (away from the fan).
    Sometimes I hear the fan run first before I see the car start charging (blue blinking light), especially if you plug it in right after driving. (a distance that uses at least half the battery charge)
  7. bisco
    52,854
    if its running while charging, it may be the charger fan.
    if its running several hours after driving, its the evaporations check
  8. Silverfun
    Silverfun Junior Member
    Central Florida
    2018 Prius Prime
    Four Touring
    I just picked up an 18’ Advanced and noticed a fan noise in the rear of the car after charging to 100. Turns on sometime after unplugging the car. It is not the charger cooling fan as I check that under the rear seat, I know what that sounds like and I can’t hear that from outside the vehicle. Almost sounds like battery cooling fan but I can get it to stop if I start the car to ready mode and shut it down.
  9. Silverfun
    Central Florida
    2018 Prius Prime
    Four Touring
  10. jerrymildred
    11,517
    14,167
    Tampa, FL
