check engine, (!) and VSC light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by aanimate, Oct 7, 2009.
  1. vlalra
    vlalra Junior Member
    KY
    I am getting the same p2601 code after changing the pump.
  2. vlalra
    KY
    In addition my Engine continually runs.
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    What are your codes? No one can help you until you post the codes
    SFO likes this.
  4. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    You probably have TWO separate problems.
    1) DTC P2601 points to the CHRS (Coolant Heat Recovery Storage) pump. You say you replaced the pump and refilled the reservoir.
    1a) Which pump did you replace? There are four pumps that move coolant in the Gen2 Prius: engine, inverter, CHRS, and heater.
    1b) Did you properly purge all the air out of the engine cooling loop, assuming you replaced the CHRS pump?
    1c) Did you check the radiator, after it has cooled for hours, to make sure it is full?​
    2) You MOST likely have a dying HV (High Voltage) battery. You reported common symptoms associated w/ a failing HV battery:
    2a) you can hear the HV fan from the back seat
    2b) engine runs constantly
    2c) dash is lit up light a Christmas tree w/ all kinds of warning lights​
    As has been said many times over, get the codes read. MORE IMPORTANTLY, get the codes read w/ a Prius capable code reader. Universal OBD2 readers, auto parts store readers, and many other readers, will NOT read ALL Prius codes. The dealer or an independent shop specializing w/ Toyota will be your best bet.
    If you purchase miniVCI w/ Techstream from Amazon ($25+), you will have dealer capable code reading ability. Techstream is the official diagnostic and maintenance software written for Toyota/Lexus, and used at all Toytoa/Lexus dealerships. Installation is easiest on a Windows 32bit OS laptop (XP, Vista, 7). If you don't have one, ask friends/family if they know someone in IT. This person will likely have such an obsolete laptop laying around, and can likely give it to you for free. Mac install possible, just search. B/C the software is hacked, this laptop top should only be used for vehicle diagnosis; NO email, banking, bill payments.
    SFO likes this.
  5. vlalra
    KY
    How do you bleed the air?
  6. exstudent
    2,214
    905
    Torrance, CA
    Kindly research repair procedures first! Look before you leap. You will save yourself time/frustration.
    READ in ENTIRETY to LEARN how to bleed engine coolant loop: How to replace engine coolant pump and thermostat | PriusChat
    PAY ATTENTION to posts #22 and #42 as well as the surrounding discussion in the following thread discusses how to change engine coolant. Changing engine coolant | Page 2 | PriusChat
    Read Post #5, how to get into Inspection Mode.
    To cover all basis, Inverter Coolant Loop bleeding: How to Replace the Inverter Coolant Pump | PriusChat
    Skibob likes this.
  7. MichaelH1313
    MichaelH1313 New Member
    Indiana
    hi did you ever get this figured out. I have an 05 Prius with 160k miles. Thousands put in it and the exact same issue. Last time is went to dealership was 6 months ago and they put car in pressure chamber and patched all water leaks and now I turn car on and yellow check engine, VSC and (!) is on. Fan blowing hard in back when on and hybrid battery bars go full green and up and down. 12v battery brand new and Hybrid battery somewhat new. Hopefully I can get some help it’s our only vehicle with 4 kids and thousands sunk in.
    #27 MichaelH1313, Jan 27, 2021
  8. dolj
    dolj Senior Member
    8,555
    4,346
    Wellington, New Zealand
    The first thing to do is have the codes read, which are more than likely going to be hybrid system codes.
    Was the "somewhat new" hybrid vehicle battery actually some kind of "rebuilt" battery?
    SFO likes this.
  9. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Would love to see a picture of the the pressure chamber, or just the patch job :whistle:
  10. David Ingram
    David Ingram New Member
    Mine did the same thing, Codes came up were: P0A93, C1241, C1256, C2121, C2122, C2124, C2177, B1421. I replaced the Inverter Coolant Pump and reset the codes by disconnecting the battery. Going to drive it now to see if it changes anything. Guys, do you feel I did the right thing and is there anything else to check?
  11. dolj
    dolj Senior Member
    8,555
    4,346
    This does not cause any trouble code lights to come on and is not a trouble code per see. It just means that at the time the car was scanned the passenger-side solar sensor does not detect bright sunlight. If that is the case, then there is nothing further to do in relation to this code. If you were in bright sunlight, you might want to investigate further.
    These codes mean:
    No Signal from Transmitter ID1, ID2, and ID4 (respectively) in Main Mode
    The tire pressure warning valve and transmitter constantly sends radio waves to the tire pressure warning ECU.
    Under the following conditions, the tire pressure warning antenna and receiver is unable to receive the signals from the tire pressure warning valve and transmitter, and a DTC is output.
    • Areas, facilities, or devices that use similar radio frequencies are located in the vicinity of the vehicle.
    • Devices using similar radio frequencies are used in the vehicle.
    DTCs C2121 (Blink code 21) to C2124 (Blink code 24) can only be deleted by the tester.
    DTC Detection Condition
    These DTCs are detected when no signals are received for 51 minutes or more after a vehicle speed of 5 mph (8 km/h) or more is detected and no signals are received for 12 minutes or more
    Trouble Areas
    • Tire pressure warning valve and transmitter
    • Tire pressure warning antenna and receiver
    • Tire pressure warning ECU
    • Wire harness
    This code means:
    Abnormal Change in Output Signal of Rear Speed Sensor RH (Test Mode DTC)
    The speed sensor detects wheel speed and sends the appropriate signals to the ECU. These signals are used to control the ABS control system. The front and rear rotors have 48 serrations respectively.
    When the rotors rotate, the magnetic field emitted by the permanent magnet in the speed sensor generates an AC voltage. Since the frequency of this AC voltage changes in direct proportion to the speed of the rotor, the frequency is used by the ECU to detect the speed of each wheel. When foreign matter adheres to the speed sensor tip or sensor rotor, or the rotor teeth are chipped, these DTCs are output. An abnormal waveform input from the sensor determines these conditions.
    These DTCs may be detected when a malfunction occurs in the connector terminals or wire harness of the speed sensor circuit.
    DTCs C1275 (Blink code 75), C1276 (Blink code 76), C1277 (Blink code 77), and C1278 (Blink code 78) can be deleted when the speed sensor sends a vehicle speed signal or the test mode ends. DTCs C1275 (Blink code 75), C1276 (Blink code 76), C1277 (Blink code 77), and C1278 (Blink code 78) are output only in the test mode.
    DESCRIPTION
    The accumulator pressure sensor is built into the actuator and detects the accumulator pressure. The skid control ECU turns on the Brake Control warning light and sounds the skid control buzzer if it senses a decrease in the accumulator pressure.
    This one would be one to watch. Post back if it comes back and we can give you more info on it.
    If you want to troubleshoot any of these codes it would be best to follow the diagnostic and repair procedure in the repair manual. For more info see the wiki information here.
    Raytheeagle and SFO like this.
  12. KPV
    KPV New Member
    India
    How it ended finally, Exactly the same is happening with me now.
  13. KPV
    KPV New Member
    India
    What happened at the end, as I am facing same issue now.
