Code scanner that can get INF codes?
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Oct 18, 2025.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    I've screwed with a laptop for 6 hours trying to get techstream to work.
    I bought the most expensive Innova scanner I could find, still won't do INF codes.
    Are there any scanners on the market that can?
  2. Leadfoot J. McCoalroller
    8,205
    7,709
    Pennsylvania
    2018 Prius c
    Brian1954 likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,525
    1,006
    South Central PA, USA
    I also recommend the Autel AP200. It costs about $60 at Amazon. You need to create an Autel online account and have internet access to set up the Autel app on your phone or tablet.
  4. PriusCamper
    PriusCamper Senior Member
    13,288
    5,372
    Pacific Northwest, USA
    Have you tried installing the windhorse driver packet? OR maybe its xwindhorse?
  5. Prius92
    595
    122
    Iowa
    Ended up getting the thinkdiag scanner, should be here later tonight.
    Not having ABS sucks. Had to stop quickly and the wheels locked up.
    Also noticed lack of regen braking when the abs is out, in fact even at a stoplight without the AC on the battery slowly drains, I'm not sure why it draws more power when it's out.
  6. PriusCamper
    13,288
    5,372
    What were your symptoms leading up to the problem? Last person I loaned my laptop with Techstream to thought it was ABS and it turned to be a bad booster pump and when they replaced it with a used one the used one turned out to be bad too and they had to buy another one. Hopefully the pump you hear when you first open the car door hasn't been working more often than normal? That's an expensive symptom/hassle when it finally fails.
  7. Prius92
    595
    122
    Iowa
    The seal on the wheel cylinder accidentally popped off changing brakes and lost about a teaspoon of fluid, must of put air into the line.
  8. Prius92
    595
    122
    Iowa
    Well darn, now it won't be here until Tuesday. Apparently my local Amazon warehouse was out of stock.
  9. PriusCamper
    13,288
    5,372
    Oh, in that case you don't need to wait for a device to fix it... Simply read up on here about how to jump the two pins on the OBD2 port with a paper clip to read the blink codes and while doing that hit the brake pedal 8 times and the error code will clear and you're done!
