Cold cranking amps
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by jrrsims, Oct 23, 2018.
  1. Mendel Leisk
    42,332
    Ours, a few days back. It's a 4.5 year old Optima yellow top, rated 450 CCA:
    The 2.5 was maybe 250??
    padroo, ztanos and TMR-JWAP like this.
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    $200 is cheap for these batteries compared to some of the prices I've seen. Him charging for an hour of work isn't really that bad considering he has to take the rear seat apart to replace the battery underneath it.
    But as mentioned above, advance/napa/auto zone/pep boys will do it for free... they may just not be as experienced with it as they probably don't do it as often on the C, so you may end up having to buy some clips when they're done.
  3. Mendel Leisk
    42,332
    I forgot about that. Yeah best to leave it to someone experienced.
  4. padroo
    padroo Senior Member
    2,763
    2,253
    Mendel , I have the same tester and have a battery for my whole house generator I need to test.
    Found the battery dead when the generator didn't start when we lost electric.
    I will have to read the directions again, it's been a while.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    The same considerations apply as for a (non-hybrid) car battery application.
    The generator should have a battery "tender" built in and you need to check that voltage after you get a new battery.
    The new battery needs to be fully charged BEFORE being installed.
    Since the generator is "out of sight, out of mind", this is an excellent place for an AGM battery........since a conventional battery will go dry if not checked often.
    Do you run the gen to exercise it once a month or so ??
    You really should......for several reasons.
    IF......this is a conventional wet cell type battery and you look in the cells and they are bone dry......there probably is not much point in trying to test it.
  6. padroo
    2,763
    2,253
    The generator has a built in battery charger and it isn't working. I have heard of problems of over charging and I will find out when the repair guy shows up, it is under a 5 year warranty. We will see how good the warranty is soon.
    This is the second battery and Kohler recommends replacing them every 4 years. The original didn't last that long but I did take a lightning strike and who knows what happened to it. I was thinking about an AGM battery but if this one is bad I will get it replaced under the three year free replacement. The original battery was 15 days over the three year warranty, the luck of the Irish. The battery is in my garage and has been off the charger for over 24 hours. Now I need to check it's voltage and use my tester like Mendel has to see if it is good and see what the CCA is.
  7. Mendel Leisk
    42,332
    The Solar BA5 has 3 options, OK, CHARGE and FAIL. Any battery that's been sitting a long while will likely be a CHARGE case, basically: it seems viable, but needs a recharge to be sure.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    I suspect that the generator company probably scrimps on it's battery charger.
    It might be a cheap, unregulated "trickle charger" which will eventually "boil" a conventional battery dry if you don't check it often.
    If that is the case, a good battery tender could be connected in it's place.
  9. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Before I would replace that, I would put a trickle charger on it and see if that will charge it.
    Adam Ming and ztanos like this.
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    Even if it does, if the battery stayed at 10 V for more than a couple of hours, it likely still needs to be replaced.
    Even if it does appear to charge up again, it might not HOLD the charge very long.
  11. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    But without a recharge, the owner won't know. Better to have the data than just toss in a new battery that might not be needed.
    I have rescued a few "dead" batteries with a Battery Tender.
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    It depends mostly on the battery's age and how it was treated in the past.
    IF.....it is 4 years old or more
    OR it lives where it is VERY hot for much of the year
    OR there have been other "episodes" of deep discharge..............
    Then the odds are against getting much more useful service out of it and it might leave you stranded out on the road somewhere.
    It is a gamble that many people shouldn't take.
  13. Adam Ming
    Adam Ming New Member
    This is exactly what I needed echo'd back. A new recommended battery is around $100 at Walmart and I'm seeing a 12v simple SLA Mighty Max Battery for $14 from Amazon. I've ordered it and hopefully, it'll do the trick. I'll update in a couple of weeks.
    PriusCamper likes this.
  14. PriusII&C
    PriusII&C Active Member
    432
    147
    San Jose, California
    Is this to replace your auxiliary battery? What is its Ah capacity? Looks like it is not an AGM battery.
  15. Mendel Leisk
    42,332
  16. PriusII&C
    432
    147
    This one is an AGM battery. You are right @Mendel Leisk, with 1.3 AH, it barely can last 10 minutes for a pair of typical headlight bulbs. Better to avoid staying at ACC and/or IGN-ON mode long. Good luck!
  17. Adam Ming
    Close, "
    ML1.3-12 - 12 Volt 1.3 AH, F1 Terminal, Rechargeable SLA AGM Battery
    Well I guess the alternator will be spinning away then ‍♂️
    Just ordered a "NOCO GENIUS1, 1A Automatic Smart Charger, 6V and 12V Portable Automotive Car Battery Charger, Battery Maintainer, Float Charger, Trickle Charger and Battery Desulfator with Temperature Compensation"
    In hopes that it may salvage my old SLA
    #37 Adam Ming, Oct 23, 2022
  18. CR94
    CR94 Senior Member
    2,827
    1,241
    Northwestern S.C.
    Huh? There is no alternator.
    A 55 A-hr MightyMax (or other-brand equivalent) general-purpose AGM like PriusCamper suggested would work well, assuming it can be made to physically fit and is vented. So does my $65, 35 A-hr one. But, you have to be joking about using a tiny $14, 1.3 A-hr version.
  19. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    The dealer doesn't have the Liberty to tinker with something to see if it will work or be reliable. It is demanded and utterly expected that a dealer will guarantee something to be 100% reliable when it leaves their facility. You went to the people that operate by the gold standard. If you wanted to tinker you should do that yourself. But you need to understand a dealership doesn't have that Liberty. Cars break. When cars break it's because parts wore out. We replaced parts. That's what we do. You went to the dealership with broken parts. They install new ones. That's how this works. You want to tinker with something and have it unreliable and leave you stranded on the side of the road that's on you but the dealer cannot do that. That's why you got a new battery.
  20. Adam Ming
    If there is no alternator then how does the SLA get recharged or not run out then?
