Combination Meter no longer available
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by squiddy, May 22, 2017.
  1. squiddy
    squiddy New Member
    Hong Kong
    Wondering if anyone here can help me...
    I have a Gen 2 Prius, and the Combination meter is shot..
    I'm based in Hong Kong, and my model is a European NHW20R.
    Toyota says that the part I'm looking for (83291-47150) is no longer available, so I was wondering if anyone here has any idea on where I can source one, or if the combo meter from other models will work? i.e. Other 2003-2009 models from other markets.
    Any help would be great!
  2. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    You should be able to get a used one from a car dismantler/wrecker, but trying to obtain one with the correct distance in the ODO could be an issue. You can use a 2006-2009 but you will need to replace the light cluster as well. A 2004-2005 should just drop in.
    Can I ask what is wrong with your current one?
  3. squiddy
    squiddy New Member
    Hong Kong
    Thanks for the quick reply.
    I think the dismantler/wrecker route will be the way I have to go.
    The problem with the current one is that my speedometer lights have stopped working - from my research it seems to be a fairly common issue with this model.
    Is there anyone out there who has experienced this combination meter & light cluster replacement previously?
  4. dolj
    dolj Senior Member
    8,633
    4,385
    There are quite a few people in the US who have had this problem, if you want to search.
    Also, even though it talks about a slightly different problem, click on the "Combination Meters that stop at 299,999 miles, Who's affected and what you can do about it." link in my signature for the background.
    You may also find this link: "T-SB-0172-09 Combination Meter - Intermittent Display" of interest. The last page has information about repairing, if that is your skill set.
    See also the "Similar Threads" below.
    #4 dolj, May 22, 2017
  5. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    have you checked e bay in your area? I found this service listed but have not used it.. REMAN 06 - 09 Toyota Prius Combination Meter Instrument Cluster Display EXCHANGE | eBay
  6. squiddy
    squiddy New Member
    Hong Kong
    Thanks - I'll keep reading to see what I can find out.. I think what I'll ultimately need to find out is if I can install a slightly newer combination meter from the US market (which seem to be readily available) without screwing my car up!
  7. squiddy
    squiddy New Member
    Hong Kong
    Thanks - I have checked eBay but i can only seem to find parts for American cars - does anyone have any idea whether or not these are transferable across models?
    Does anyone know how different are they from model to model/market to market?
    Any help here would be awesome - this is a great forum, thanks all for your input so far
  8. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    I would pursue repairing yours. Apparently it's not a difficult repair, and the repairs seem to be robust. Did you look for repair shops on eBay? If you can't find an onshore shop, consider overseas air freight.
    You should be able to find someone to dismantle the car. If you're decent with tools, it's a couple of hours of somewhat tricky DIY, with an airbag removal included. The car will be down a minimum of a few days including shipping time. But you'll retain your odometer setting and you know it'll be compatible.
    The car will still drive without a functioning meter. You may need to hold the "start" button up to three seconds to turn it off. I think there's something about the rear hatch not working, too.
  9. Beachbummm
    1,160
    392
    how about ebay in a European country,or try this,with the car off next to the 12 volt battery is a black box, unplug the wire harness going to it (I think its a white plug) leave it off for about a min and plug it back in..see if that gets it working. .
  10. squiddy
    squiddy New Member
    Hong Kong
    Thanks --- Yes pulling the wire harness and replugging gets it working again, and is what I've been doing for the last few weeks as a temporary solution -- Ideally I'm hoping to fix it!
    I'll dig deeper on ebay.. really proving to be a challenge at the moment!
  11. dolj
    dolj Senior Member
    8,633
    4,385
    Is Hong Kong metric or do they use British imperial unit?
  12. squiddy
    squiddy New Member
    Hong Kong
    Metric - Km/h speedometer...
  13. dolj
    dolj Senior Member
    8,633
    4,385
    In that case you could also consider Japan, Australia and New Zealand as a sources also. Is your car a RHD too?
  14. squiddy
    squiddy New Member
    Hong Kong
    Yes - RHD - I hadn't thought of Aus/NZ - thanks for this!
  15. franken1313
    franken1313 Member
    216
    27
    US
    I have the same combination meter problem. I've been disconnecting the wire harness. White plug for months now
  16. andrewclaus
    993
    326
    Golden, CO
    Someone here once broke the wire off the white plug doing that. The harness is not made for switching duty.
  17. franken1313
    franken1313 Member
    216
    27
    US
  18. Patrick Wong
    18,210
    6,517
    In that case, why not unbolt a battery cable?
  19. franken1313
    franken1313 Member
    216
    27
    US
    I've tried that before. It doesn't bring back the combination meter
  20. Beachbummm
    1,160
    392
    dizzyharper likes this.
