Combination Meter no longer available
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by squiddy, May 22, 2017.
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    give this a read,
    Combination meter diy | PriusChat
  2. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    There is a better thread (which in turn links to another better thread) in post #4. I'm sure if the OP was taking this route, he would have said so.
  3. squiddy
    squiddy New Member
    Hong Kong
    Hi all - thanks for all the input and replies.
    I eventually went the scrapyard route - my garage sourced a replacement speedo panel from a newer model Prius which has worked - the graphics/screen itself looks slightly different, but it works, so I'm happy with the result!
  4. eterrestrial32
    eterrestrial32 Junior Member
    Hong Kong
    Hey, I'm in the same boat as you. Would you mind sharing the details of where you got it fixed? Going the route with Toyota is going to be quite expensive most probably so wanted to see if there are other options.
  5. dolj
    dolj Senior Member
    8,633
    4,385
    See posts 21 & 22 and read the linked/mentioned threads.
  6. eterrestrial32
    Hong Kong
    The issue went away temporarily but is popping up for me again so would be great if you could share details on which workshop you found to do it.
