Completed Head Gasket Replacement
Discussion in 'Gen 3 Prius Technical Discussion' started by TAPnAR, Feb 9, 2024.
  1. MrDan
    MrDan Junior Member
    38
    Pomona
    I'm wondering the same thing , I've read reviews saying that it comes with incorrect gasket sizes, or even missing gaskets
  2. Mendel Leisk
    42,332
    If I'm ever in that boat, I'll be getting the Toyota kit, wouldn't entertain getting anything else. As far as I know there's been a head gasket revision too. Part number for the kit is in the attached. It also has part numbers, for revised pistons/rings and head bolts:
    Carall and bobby515 like this.
  3. Professorman
    Professorman Junior Member
    Hampton, VA
    What are the extra seals needed that are not included in the Fel-Pro kit?
    I have a leaking timing chain tensioner. Is that replacement gasket already in the Fel-Pro kit?
    PriusCamper likes this.
  4. Mendel Leisk
    42,332
    I keep looking these up, then losing the info. Tried again this morning: there’s apparently head gasket replacement kit, and an engine overhaul kit. I gather the latter is the former but with extra gaskets. It’s more costly, but not by much, and has everything. Maybe.
    anyway, just tapping away on my phone this morning, took some notes:
    Engine Overhaul Gasket Kit: 04111-37316
    Priuschat Ref, post #2:
    2013 Prius Two Head Gasket Set Part Number? | PriusChat
    Toyota USA listing:
    Engine Overhaul Gasket Kit #04111-37316 | Autoparts.toyota.com
  5. Tombukt2
    Tombukt2 Senior Member
    13,853
    2,515
    Durham NC
    Well I imagine the overhaul engine kits going to have the oil pan gasket and the head gasket so you can pop the Pistons out re ring etc . But theyres always a few funny small gaskets and or o rings left ? On every lot I've put hard regardless of brand of engine or make of gasket set even the cheap crap like evergreen same
  6. Mendel Leisk
    42,332
    The 2 gasket kits:
    Engine Valve Grind Gasket Kit: 04112-37254
    (Head end only)
    (More complete)
    Quote from @Elektroingenieur if I'm not mistaken:
    As illustrated in catalog Figure 11-03, Engine Overhaul Gasket Kit, the 04111 Gasket Kit, Engine Overhaul includes everything in the 04112 Gasket Kit, Engine Valve Grind, plus these items:
    16271 Gasket, Water Pump
    15609H Ring, O (For Oil Filter Bracket) (Quantity 2)
    16326 Gasket, Water Inlet Housing, No. 2
    11302A Seal, Oil (For Timing Chain or Belt Cover)
    11401L Seal, Engine Rear Oil
    12101B Gasket (For Oil Pan Drain Plug)
    (those last numbers obviously no part numbers, they're ref no's within catalog, but descriptions helpful)
  7. Tombukt2
    13,853
    2,515
    Durham NC
    Isn't Toyoda fipg for oil pan? I always buy a real oil pan gasket no exceptions.just had to do this for a 4G93 bishi engine
  8. Mendel Leisk
    42,332
    Yes.
