Contemplating Dashcam wiring
Discussion in 'Gen 3 Prius Accessories and Modifications' started by krausternet, Jun 22, 2019.
  1. Leadfoot J. McCoalroller
    8,281
    7,793
    Pennsylvania
    2018 Prius c
    Does the power on 2 & 16 chop hard at 45 seconds, or does it ramp down? Some cars use a PWM circuit to create a "fade to black" effect with the dome light; would be good to verify this one.
    I chopped the cable that came with the camera. There were only two wires present, so I only needed a moment with the meter to verify polarity. Then I chopped the two wires I had identified for ignition power in my car, twisted the camera lines onto the supply side and ziptied the camera cable onto the car harness for strain relief about 2" up from the cut point. Then I used gauge-appropriate insulated butt splice crimps to join the supply+cam to the cut ends trailing from the connector. I didn't take a photo of that part.
    I did it that way to avoid uneven lengths in the car harness branch, and to make it very easy for any future technician or owner to figure out my work.
    I do some low-voltage wiring work as part of my job, so I already had tools and parts to make trustworthy crimp connections. If I didn't have a pro-grade crimper, I probably would have soldered it instead. Further detail in this post.
  2. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    12V power (~1V lower than the always present 13V on pin 24) on pins 2 and 16 do a hard chop. They do not fade.
    I'm going to assume that my cigarette lighter to USB cable into dashcam is similar with two wires.
    Your explanation about using butt splice crimps is very clear. I might do that or solder.
  3. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    Well this is a little distressing. I first soldered in wires to splice to the 12V and Gnd. Then I chopped the USB cable that has the mini usb connector going into the camera on one side, and the other side is a cigarette lighter plug going to the cigarette lighter socket. And I measured the voltage across the two wires in the cable, red and black. 5V red, 0V black, not 12V !!!!!!!
    I wonder if the camera can step down the 12V to 5V?
    Otherwise I have to do it. Of maybe solder the USB cable back together and solder the whole cigarette lighter adapter into the spliced wires that I have set up in the ceiling cable.
  4. Leadfoot J. McCoalroller
    8,281
    7,793
    Pennsylvania
    2018 Prius c
    Sounds like the native cable had a stepdown built into it, probably into the lighter connector plug itself.
    I wouldn't trust the camera to knock it down for you.
  5. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    seems that the dashcam vendor on amazon answers questions so I've just asked about this there. I did see that they sell adapters.
    also in browsing I see some suggestions to find 12V->5V converters among electronics junk collections.
    Or build up a circuit with a voltage regulator chip and a few resistors and caps, and small heatsink.
    Alternatively I could wire from the overhead connector where I've just spliced into it to get the 12V and 0V and attach those wires to the contacts on the lighter. It wouldn't be easy to solder to the contacts but I could drill very small holes in the contacts and tap into them, to get that lighter adapter back into the circuit. 2019-07-13 12_31_55-Photo - Google Photos.jpg
  6. Leadfoot J. McCoalroller
    8,281
    7,793
    Pennsylvania
    2018 Prius c
    it's quite cheap to get a 12v accessory, bare leads input and USB out. Chop off that connector and you've got your 5v.
    I'm suggesting it because I know amazon and ebay sell a bunch of variations of this and they're quite inexpensive. The few I've used have worked great.
  7. Leadfoot J. McCoalroller
    8,281
    7,793
    Pennsylvania
    2018 Prius c
    You could probably just bust the 12v-5v converter out of that lighterplug shell and wire it to the drop you've just prepared. Thriftiest way I can think of to do it. It's probably just a little PCB floating inside that shell.
  8. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    Embarrassing to say but I look at the dates of my postings about this and it's been a year. Last summer I did buy a cheap 12VDC to 5VDC converter and it sat on a shelf until now. Today I took it out and tested it. I wired it into my overhead panel and could see that I was getting 5VDC out of the converter when I hit the Power button on the Prius but when I plug in the dashcam that needs 5V the dashcam didn't come on and the voltage dropped to 1V as measured at the output of the converter.
    Another factor: to test if the converter was working, prior to hooking it up the car's wiring, I had a small trickle charger solar panel sitting out in the sun not plugged into anything. I hooked the converter and dashcam to the solar panel and the small panel was driving the camera at 5V. So I don't think the converter is being overloaded by the dashcam. I think the two lines on the 24pin connector of the Prius overhead can't handle the load, which is strange since it can't be much of a current draw.
  9. Leadfoot J. McCoalroller
    8,281
    7,793
    Pennsylvania
    2018 Prius c
    Could be an overload, could be a dud. How much current does the camera demand and how much can the converter supply?
  10. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    I think the inverter is fine and the dashcam is not drawing an excessive amount of power. The inverter is rated for 15 watts (3A x 5Vdc). I doubt the dashcam draws much power.
    When I drive the DC/DC converter and camera from two pins of the overhead panel that are delivering a 12V always on (even with the car's Power button off) the camera works. It shows a solid red LED to indicate charging and by default a blinking blue to show recording.
    I can't seem to find a pin combo that allows me a 12V when the car is on and 0V when off.
    Am I seeing this wrong? Do I want the dashcam to always be powered? It came with a cigarette lighter adapter and the cigarette socket is a switched socket so it seems that the design of the dashcam is designed to work that way. I was using it that way when I first got it. But maybe it is also designed to be charging from the car battery when the car is off and then come on to be recording when the car is moving and I could use it hooked to a solid 24/7 on?
  11. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    I found similar challenges when I installed a dashcam earlier this year. Solved it with no problems since then. Following are my notes from that:
    "Installed the Aukey DR02 dashcam 1080P, 6-lane 170 degree wide angle, supercapacitor, g-senor, clear nighttime recording, bought from Amazon. SKU USA116996.
    Amazon link:
    Opened map light console. 4 pop out connectors, one at each corner, and extra tabs at front. So pry out rear 2 corners, then front 2 corners and slide rearward.
    Searched carefully and found no switched 12V power up there. Only constant 12V and switched 5V. The switched 5V was not powerful enough for the dashcam. So installed with a Duracell 12V to USB adapter on the 12V. Measuring current draw with a clamp meter at the battery (and later confirmed with better accuracy by bench testing with a wired ammeter) shows it only takes about 130 mA recording with the screen off, which is tolerable = will not drain battery. Having the screen on would take an extra 20 mA. And if needed, easy to unplug the cable from the camera. So this records 24x7 at 1080 HD with audio. Seems to get about 9 hours on the 64 GB micro SD card in there now. Loops constantly. 10 minute segments. Attached kind of permanently using the 3M sticker that came with it."
    I later set the dashcam to only record when triggered by the accelerometer. I'm in a fairly quiet neighborhood, and it catches every car that drives past and every person that walks past on the sidewalk. Kind of like an extra security system this way. Main thing though is that the current draw is so low to not be a problem, even when powered 24/7.
    Hey, found some pics I took. Shows the 20p connector, with the constant 12V and ground that I used, along with the switched 5V that had insufficient power (nothing failed, no fuse blew, but when trying to put that 5V directly into the dashcam [via a USB cable I rigged up], it could not maintain 5V and the dashcam would continually re-start):
    IMG_1903.JPG IMG_1904.JPG IMG_1905.JPG IMG_1906.JPG IMG_1907.JPG IMG_1908.JPG IMG_1909.JPG IMG_1910.JPG
    #31 2012 Prius v wagon 3, Aug 5, 2020
  12. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    That's what I found but on a different version of the overhead panel that uses a 24pin connector. I found pin 9 as GND and pin 24 as 12V always present. And yes, the 5V line that is switched dropped too far down when loaded with the dashcam.
    Here are the amp numbers that I read when delivering current to the 12V to 5V converter:
    140mA when the dashcam is on.
    35mA when the dashcam is off and the red LED shows that the dashcam battery is charging.
    30mA when the dashcam is off and the red LED is off. So it still draws power. 30mA is pretty low and probably shouldn't be a problem for battery drain for the short term. Other systems are also on while the car is off.
    Does anybody have an estimate of how much power is being drawn from the 12V battery while a 2013 Prius is off?
  13. Leadfoot J. McCoalroller
    8,281
    7,793
    Pennsylvania
    2018 Prius c
    That's going to be a monkey on your back to go out and start your car to recharge your 12v all the time. Be careful, or plan a switch or disconnect cutout or something so this doesn't take over your car.
  14. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    That's why I'm asking how much the rest of the car is pulling from the battery while it is off. Is 30mA a lot in relation to the overall draw? If it is a 10th maybe I can live with that, but if it is half of what the car normally draws from the battery while not on then I agree, I don't need that hassle.
  15. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    So that I'm not draining the battery when the car is off I decided to just try to neatly run a usb mini b cable on the top edge of the windshield, door post and under the glove compartment to the accessory plug USB adapter. I determined that a 10 ft cable should do it. So I've purchased that. (dashcam came with it but I already chopped that one up in my experiments. $5)
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    We want photos!
