Converting headlights to LED
Discussion in 'Gen 2 Prius Main Forum' started by Berch1943, Apr 21, 2021.
  1. Berch1943
    Berch1943 Member
    146
    Arizona
    I seen many videos on Youtube how to do this. Some of them show how to replace it directly. Others shows you bypass the ballast by tapping into the cable that connects to the ballast. So which is the correct way to do it? This is the bulb I'm looking at and I'm not sure if its compatible.
    #1 Berch1943, Apr 21, 2021
  2. tangerino
    tangerino Junior Member
    82
    WA
    #2 tangerino, May 2, 2021
  3. ydpplqbd
    ydpplqbd Active Member
    542
    250
  4. tangerino
    82
    WA
    Which LEDs did you end up ordering? I see so many options recommended and not sure which to go with. I want something much brighter so I can drive safely on dark rural roads (my halogens don't let me see far enough at highway speeds), but I'm not sure I can trust the lumen ratings on what I see on Amazon/eBay. Plenty of options on Amazon for $25-35 that seem solid. I suppose any LED would outperform a halogen by a mile?
    Also not sure if I should worry about going too bright for fear of blinding oncoming traffic (but I suppose the low-beam position would matter more there)
    @Berch1943 OP did you end up ordering the $10 one you linked off ebay? or something else?
    EDIT: I went ahead and ordered a SEALIGHT Laxmas L2 from Amazon:
    Hoping it doesn't cause too much interference with the radio signal from my Bluetooth FM transmitter.
    #4 tangerino, May 12, 2021
  5. Berch1943
    Berch1943 Member
    146
    Arizona
    I just ended up buying this one on Amazon
    because the one on eBay I wasn't happy with. The brightness was poor that even the halogens looked better.
  6. PandaPanda
    PandaPanda New Member
    Four Touring
    Thank you for the post. Something I know I will need to do soon as well
  7. tangerino
    82
    WA
    I just installed the SEALIGHT Laxmas L2 and can confirm it's nice and bright and the beam pattern seems to be good. Was a bit tricky to install but I was able to even keep the original gasket intact. Hoping it holds up well going forward. For $18 after coupon (still available) it was a good deal and I'd recommend it if you're looking at an upgrade!
