Coolant Temperature Hack. Better MPGs!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by TheForce, Aug 19, 2008.
  1. Flying White Dutchman
    4,376
    313
    do you now how many Nox is produced when you burn that 0.8 in a bad way ( more ) and what you produce when burning 1 gallon in the normal way? ( less )
    i think you need to burn only 0,25 or 0,5 a bad way to come close to the 1 gallon of normal burn looking at exhausted stuff like nOx etc etc
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    I personally applaud jtcsd, Bob Wilson, The Force, ccdise, Ken@Japan and many others who are pursuing innovation. In my book, they are heroes with enough courage to continue their quest to make all of our lives better despite the naysayers trying to berate them for their work. I hope this post will embolden them to continue their projects and keep all of us informed of the progress.
  3. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Mr Big
    Could you make one me?
    I will pay the necessary cost and fee provided I get DIY instruction setup and general operation procedure.
    Meg&Bear likes this.
  4. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    Yes, if someone make it a product with instructions, I will be one of the customer for sure
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Check out my review of an excellent product here:
    A Prius ECT Spoofer MCU Controlled | Page 4 | PriusChat
    and contact the OP directly if interested. Good luck!
  6. afacanyedi
    afacanyedi New Member
    I have a very short commute to work, less than 10minutes. I was bothered with the low MPGs, sometimes down to 36MPG for the tank. That initial warm-up cycle was the issue. Thanks to Bobwho and others, my MPG is above 50 even for <10min commute =). I just applied this hack. I am still experimenting with the resistor pot, gradually reducing the resistance to reduce warm-up cycle. The engine still does go through it at least for 10seconds, sometimes it feels like the engine stalls right away. No big deal. I am positive my average MPG will be higher than 50 for the tank.
    Meg&Bear and wjtracy like this.
  7. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    Are other folks using this trick? and does it seem safe with the passage of time? Any downside, I presume more emissions.
  8. 2009Prius
    2,705
    512
    63
    I have been using this one
    since 2011 without any problems.
    Under rare conditions (several very short trips in the morning in one occasion) the way-too-smart Prius would think something is broken since it expects the temperature to change but does not "see" it due to the spoofing. If that happens then the logged DTC can be easily cleared.
  9. mrbigh
    3,686
    699
    Long Island, NY
    I'm using improved CCDISCE's temp hack for the 2008 for quite some time now, over a year, with out a problem.
  10. Abarnabe
    Abarnabe Active Member
    169
    100
    Netherlands
    can this hack be applied to a 3rd generation Prius?
  11. LukUsc
    LukUsc Member
    69
    26
    Poland
    Could You send some link with description this version?
  12. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
    I am pretty sure it applies to Gen3.
    I recall one PriusCat member from WV selling a used white ~2012 PiP here for $21000, and he had installed it.
    Back in 2012 WV had $7500 credit + $2500 Fed credit, that guy probably paid $16000 for the new PiP, so he was making a killling. Shortly after his sale, used PiP prices dropped a lot, I forget why (market forces).
    I am a sucker for nice white PiP but I managed to hold my powder dry.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    If this was a good idea, car makers would be on it like dogs on a squirrel.
    It is NOT.
    Running the engine "cold" encourages sludge buildup......and we all know what a bane sludge is. :eek:
    It also encourages carbon buildup in the exhaust system.
    It also reduces lubrication efficiency.
  14. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
    Certainly this hack is at your own risk, but I am not aware of any documented maintenance issues. It just speeds up the gen2/gen3 progression to warmed-up stage, which is slow due to California standards.
    I feel like my 2020 RAV4HV does NOT need this hack, since the low-MPG-while-cold-issue seems to have been solved by Toyota. Amazing the MPG's Toyota hybrids can achieve these days, even for larger cars like RAV4 and Sienna.
