Crashed 2012 prius fixed, now wont start, NO READY light? HELP
Discussion in 'Gen 3 Prius Technical Discussion' started by ferraribuyer, Nov 25, 2012.
  1. ferraribuyer
    ferraribuyer Junior Member
    30
    MN
    I had front end accident, airbags deployed. I fixed the car, had to disconnect the traction battery and 12V battery while body work was done. I plugged both back in and the car wont start. Battery is charged. I had to replace the park position motor because it was stuck in neutral. I can get N and P. The ready light will NOT come on. Any suggestions? The connections are good on batteries. I tried jumping it, its not the 12V battery.
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The HV disconnect safety plug has to be slid into position after insertion or a Prius will not go into "Ready".
    JeffD
    [email protected] likes this.
  3. ferraribuyer
    30
    MN
    The safety plus is pushed in and slid to the right to lock position. No codes on OBD2 either. When I try and start all lights light up on dash but no ready light. I shift to D it goes into N and says on dash when tryin gto start push park. I put it back into park same thing.
    52,912
    brake switch?
  5. ferraribuyer
    30
    MN
    brake switch good. Light turns green on power button when brake pressed and brake lights work. I did replace the sks module and key from a used car because I had no key when I bought the car. it locks unlocks but maybe that has something to do with the immobilizer?
  6. ferraribuyer
    30
    MN
    I put in new battery, still no luck. I swapped the sks module with my other prius and found that the other car did not start either. So it most certainly the sks module or immobilzer. I am having a key guy come tonight and program a new key. I will see soon.
  7. ferraribuyer
    30
    MN
    Key wasnt fully programmed now it starts but have some weird issues of it dying 15 seconds later. Have p3190 code and 261c code
  8. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
  9. Jin
    Jin Blizzard PRIUS 2010, Nav+ solar roof
    174
    West Virginia
    Curious, when you start the car, did you make sure the break is press before you start the car?
  10. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    Try and get someone to scan the car with the factory diagnostic tool "Techstream" software. You won't see all the possible errors (especially the hybrid specific stuff) with a generic OBD2 scanner.
  11. ferraribuyer
    30
    MN
    now it starts and runs but has p314a code?
  12. 3prongpaul
    956
    735
    P314A-828
    Inverter Coolant Pump Speed Signal
    - Wire harness or connector
    - Power management control ECU
    - Water pump with motor assembly
    - IGCT No. 3 fuse
  13. ferraribuyer
    30
    MN
    perfect thanks it was the fuse runs great!
  14. PriusConversionExpert
    PriusConversionExpert Toyota Prius Conversionist
    17
    San Carlos, CA
    The fuse most likley blew because of short during body work/accident. We see a lot of body shops bring the prius's through our doors due to simple situations like this. Glad you found the issue.
    I have a recommendations for you. It may be wise to carry some spare fuses in case there is some short to ground etc... that happens over bumps or turning etc... due to a damaged wire or connection. If the fuse blows again at least you have the option of limping to a shop or home for further inspection.
