Cruise control (CC) - re-engaging NOT working every time ???
Discussion in 'Gen 2 Prius Main Forum' started by ksor, Nov 20, 2012.
  1. ksor
    ksor Junior Member
    46
    Aarhus V, Denmark
    Let's say we are driving 70 with CC set to that speed.
    Of some reason you press the brake and slow down to 63 and want to re-engage the CC to former speed 70 - pressing it UP does NOT allways work !
    IF the braking results in a speed of - let's say 50 - I could understand it will not re-engage because of the rule that if the speed falls under 10 below the CC-set speed the CC will dis-engage ... so maybe that's why it won't re-engage in this situation !
    ... but MOST of the time it won't even re-engage if the current speed is HIGHER than 10 below the set CC speed !
    Can you see this problem on YOUR Prius too ?
    (Mine is a Prius 2008)
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Only when the speed drops before re-engaging. Otherwise I have never experienced this in my 2006.
    Tom
  3. Patrick Wong
    18,200
    6,479
    I am not aware of such a rule. When you apply the brake pedal, the cruise control will immediately disengage.
    If you find that the restore mode of the cruise control is intermittent, I would say the most likely cause is a faulty switch.
  4. ksor
    ksor Junior Member
    46
    Aarhus V, Denmark
    IF the switch should be the cause then the functionality "stepping up" the CC-speed by shortly pushing the lever UP should be un-stable too - but it isn't - I can increase the CC-speed by tepping the CC-lever UP and feel the car in fact IS accelerating - and it accelerate by every up-ward tapping.
  5. ksor
    ksor Junior Member
    46
    Aarhus V, Denmark
    My manual states what I interprets that when you'r driving with CC - let's say set at 70 - and you'r facing a long and steep raise in the road where the speed of the car is forced downwards - even though you ARE driving CC - and the speed continues to fall and falls below - in this case - 70-10=60 then the CC will be disengaged caused by the "rule" I'm talking about.
  6. qbee42
    18,058
    3,074
    Northern Michigan
    There is such a rule on the Gen II, although I don't recall the exact speed delta. It's listed in the manual.
    Tom
  7. CBarr31
    CBarr31 Active Member
    434
    225
    Charlotte, NC
    If your Cruise light is blinking on the dash this is a brake issue not a cruise issue. Do a search on here for "blinking cruise light" and it explains it further I believe. Or I am sure Guru Patrick knows of this.
    As for the delta dis-engaging the cruise I have never experienced that and find it hard to believe it ever would. I have climbed some major hills with the cruise inlcuding up I-40 near Old Fort and up "7 mile hill" on I-77 on the NC/VA border and never had cruise dis-engage. Granted the MPG's fall well below 20 but the little engine just hammers away.
    I had the cruise light blinking issue and it went away when I clean and adjusted the brakes but came back a month or so later. It didn't go completely away until I had the brakes replaced around 200,000. I haven't seen it with this set yet and they have 117,000 on them now.
    I hope this helps.
    Chris
  8. CBarr31
    434
    225
    Charlotte, NC
  9. ksor
    ksor Junior Member
    46
    Aarhus V, Denmark
    My CC light on the dash board is not blinking - it's stable and shows nicely the state of the ON/OFF switch of the CC lever.
    Strange what brakes and CC has to do with each other :confused:
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    One of the brake switches disables CC when you hit the brakes - right :)
  11. qbee42
    18,058
    3,074
    Northern Michigan
    The Gen II Prius uses a double pole switch on the brake pedal. One pole lights the brake lights and disengages CC, the other allows the Prius to shift into D.
    Tom
