CVT freewheeling issue
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by idahohacker, Jun 24, 2019.
  1. ChapmanF
    18,894
    'K, but I'd venture that a good way to help new people comprehend it is to start by helping them understand that it is exactly a transmission, performing exactly the function a transmission performs, so there's that concrete context into which to start fitting an explanation of how it does that.
    ... and saying it isn't a transmission just moves the epiphany farther off.
    jerrymildred likes this.
  2. Granny hill hot rods
    Corinth ms 38834
    I agree finally got room in the shop to put it up on the lift I'm tearing it down as I speak testing the 12-volt battery might check the EGR system again LOL if all else fails I'll build a tube chassis and drop the body over on it with a LS in it
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    As usual, my friend, your logic is unassailable. You won me over. (y)
  4. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I would check the rubber insert on the front and rear transaxle mount. My 2010 has 226k on it. There is a definite shudder on ICE start. The front transaxle mount has a crack across the rubber bushing in a spot. It does move quite a bit on ICE start. I’d venture to guess you might be feeling some movement, thereby creating a “shudder” type feel.
    Granny hill hot rods likes this.
  5. Granny hill hot rods
    Corinth ms 38834
    Thanks I will put it back on the lift and check that out,thanks again
