Dead as a doornail
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JIM777, Feb 23, 2018.
  1. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    OP has three problems.
    1) Needs to read 12V battery w/ a load.
    His method of reading the 12V battery is suspect and/or equipment is suspect too.
    Is my inverter coolant pump slowly failing? | PriusChat
    Post #5) How to apply a load.
    Post #8) State of Charge chart, AGM compatible battery chargers.​
    2) Water in battery & spare wheel well.
    START reading from Post #49!
    Water leak...into spare tire area etc | Page 3 | PriusChat
    Assuming this vehicle has not had any body work done, water will most likely be entering from the roof.
    If any body work was performed, you will have to eliminate poor repair as a contributing factor.
    3) STOP filling the gas, when the auto fill feature on the pump clicks off!
    Many people before you kept adding more gas, resulting in EXPENSIVE problems down the road. The bladder limits the amount of gas you can add, b/c seasonal air temps dictate the bladder's flexibility. Summer time, you'll be able to add more, b/c the warmer air temps, make the bladder more flexible. Winter time, the bladder is stiffer b/c the air temps are colder, thereby reducing the amount you can add.
    READ Fahrvergnügen Owner's Manual; it explains this.
  2. JIM777
    JIM777 Member
    162
    24
    Ar
    Just to add a follow-up. Didn't know I had more responses didn't get an email. Turn out pump was at fault at gas station tried different vehicle it did the same thing.
    No 12 volt was due to positive terminal was not tight enough gave it the usual shake and did not move. didn't realize Prius had a plastic pin holding the back side. Took a grinder and open the pinch gap. Seems to be fine now.
    As to water leak tried some caulk in rain gutter not sure it helped yet. Going to do more research.
    Raytheeagle likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Whats a plastic pin holding the backside? Whats a pinch gap lol?
  4. JIM777
    JIM777 Member
    162
    24
    Ar
  5. JIM777
    JIM777 Member
    162
    24
    Ar
    Normally you can grab hold of the battery connector and wiggle it hard back and forth to see if it's making good connection but on the Prius they have one of the plastic pins holding the back part of the connector.
    The pinch point is where the bolt goes through the connector it could not close any further so I just clamped it in a vice and took a cut off wheel through the center to enlarge the gap so it pinched the terminal tighter.
    Thanks to all that responded.
