Dirty wheels
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Sgt Bill, Aug 10, 2021.
  1. Sgt Bill
    Sgt Bill Member
    42
    35
    St.Louis Mo.
    Hi Sgt. Bill here;
    Have a query , how often should your alloy wheels under your plastic wheel covers be cleaned.Has anyone had problems with them getting damaged from brake dust or other dirt that cannot be seen due to the covers?
  2. PtPri
    PtPri Junior Member
    91
    40
    Lisbon, Portugal
    Luxury
    Regularly. At least as soon as you see buildup.
    Try never to allow reddish deposits to accumulate, that can really eat your wheels finish.
    Also, when deep cleaning your wheels, remember to also clean their inside, as well as the plastic covers and their backside.
  3. Mendel Leisk
    42,343
    Easiest way to stay on top of this is if you’re doing your own tire rotations, or swapping between reg and snow tires (on separate rims). Having the latter case I wash/wax the loose rims, each time they’re off.
    PtPri likes this.
  4. Sgt Bill
    Sgt Bill Member
    42
    35
    St.Louis Mo.
    Thanks for the info as soon as the temp here goes down( now 97 with humidity added 110) I’ll clean them.
  5. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Duplicate post
    #5 pghyndman, Aug 11, 2021
  6. pghyndman
    498
    466
    CT shoreline
    Alternatively, you might consider taking the plastic wheel covers off for good and plonking some center caps on in their place. The stock wheels, sans covers, look pretty decent and stay much cleaner:
  7. PtPri
    PtPri Junior Member
    91
    40
    Lisbon, Portugal
    Luxury
    You still have to deep clean the wheels, regardless! :cool::D
    But yes, it's a lot easier and less finicky.
