Does the 3rd Gen Prius use CAN-BUS?
Discussion in 'Gen 3 Prius Technical Discussion' started by ImeanGreen, Feb 26, 2012.
  1. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Does the brake light and headlight use the CAN-BUS system for the Gen 3 Prius?
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Their status is reported on the CAN Bus, but they are probably directly wired (via relays for the HLs?). I would have to check the wiring diagram to be certain.
    JeffD
  3. ImeanGreen
    547
    73
    Somewhere out there
    Thanks for checking.
  4. otmezger
    otmezger Junior Member
    Hi JeffD, do you have any possibility to check if fuel consumption is also on the CAN-BUS on the OBD-II plug? Thanks,
    Olmo
  5. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
