Double vision
Discussion in 'Prime Main Forum (2017-2022)' started by Smithrmark, Oct 7, 2020.
  1. Smithrmark
    Smithrmark Junior Member
    Woodstock
    Hello folks I have a Prius prime limited and I noticed double vision through my windshield
    I talking with my dealer now have anyone else had these issues.
    iPhone ?
    Mambo Dave likes this.
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Is this what YOU see? Or is it a dashcam etc. image? I could almost explain if only seen in a camera if positioned above the HUD glass. Sort of a windshield acting as a beam splitter, reflected back off the smartphone camera, reflected back from the HUD glass. It's a stretch I know.
    Salamander_King likes this.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    You maybe the first 2021 Prius Prime owner posting here.
    I have read sometime ago about someone having similar problem with the view through rear hatch glass, I think when viewed on the rear view mirror, but I can't recall anyone having this problem on the front windshield. That is bizarre. Did you have any type of tint or special coating applied to the windshield? No, I never had that problem on my two PP (2017 Premium and 2020 LE).
    Keep us posted what the dealer says about this.
    #3 Salamander_King, Oct 7, 2020
  4. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    The photo sure looks like it was taken looking forward.
  5. Smithrmark
    Woodstock
    Yes when viewing from my windshield out especially with road signs with the head lights off no double vision and with the headlights on double vision. I never noticed this in any of my cars. Same with oncoming cars head lights and rear tail lights. My eyes are locked into it now and I can see it in the day time I see oncoming cars day time running lights and in the concrete median on the highway I see same cars headlights as two dim little dots
    iPhone ?
  6. Salamander_King
    11,024
    8,977
    New England
    For the 2011 Prius, the problem seems to be happening only to a few people. I wonder if this was caused by manufacturing defects. I did not find any posting of the solution for this problem in these thread, or did they? To be honest, I have not driven my new 2020 PP at night, but I don't think I have noticed anything similar to what OP is describing on my 2017 PP at night. I will check it on 2020 PP tonight.
    EDIT: After reading one of the long thread for 2011 Prius problem, it seems some did solve the problem by replacing the windshield. For OP's case it sure seem to be the case of poor quality windshield that should be replaced under the warranty.
    #7 Salamander_King, Oct 7, 2020
  7. Tips
    Tips Member
    128
    66
    Grand Forks, B.C. Canada
    2020 Prius Prime
    Could it be the head lights? I thought I could see 6 deer but when I got close too them there was only two!
  8. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    IIRC there were discussions about Primes (at least those with Heads Up Displays) having polarized windshields, non OEM replacement windshields often resulted in HUDs displaying double images. I've not seen this phenomenon this in my '18 Premium or '20 Limited (original windshields).
    It's dark here now, but I wonder if one placed a pair of polarized sunglasses against a polarized (OEM) windshield in daylight and rotated them 90 degrees, would there be noticeable darkening, ditto for a non-polarized window (eg: side window or non OEM windshield).
  9. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    My polarizing sunglasses worn normally/not rotated dim the HUD very much. If I rotate them 90° the HUD brightens.
  10. pghyndman
    498
    466
    CT shoreline
    I wonder if Smithrmark's windshield reacts the same. Also if the polarization is similar to ours (vertical, horizontal, or circular)?
  11. Smithrmark
    Woodstock
    iPhone ?
  12. Smithrmark
    Woodstock
    I windshield dose the same thing just confirmed yesterday
    iPhone ?
  13. Washingtonian
    Washingtonian Senior Member
    726
    621
    The night time picture is most impressive. I would recommend the OP park his car at night and take a picture of a nearby light, like the neighbor's porch light from inside the car thru the windshield. Then step out and take the same picture alongside the car. Show that to the dealer. Another thing: The OP says he has a 2021 Prime Advanced. I thought they stopped calling them that a year or two ago.
  14. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    only your ophthalmologist knows for sure
    Ah ha, sounds a lot like an old hair products commercial from last century.
  15. Smithrmark
    Woodstock
    Taking the car in today going to see what the mechanic says
    iPhone ?
  16. Smithrmark
    Woodstock
    Toyota confirmed that my windshield is defected and is covering it under warranty
    iPhone ?
  17. Salamander_King
    11,024
    8,977
    New England
    Thanks for the update. Let us know what the replaced windshield looks especially the night time. I wonder how widespread the problem is?
  18. Smithrmark
    Woodstock
    Still the same problem
    Still in talks with Toyota and the dealership on what the next level of repairs are
    iPhone ?
  19. Db17
    Db17 Member
    188
    92
    Visalia, CA
