Dreaded P3006 Leak Detected DOC 20%
Discussion in 'Generation 1 Prius Discussion' started by DRACO, Jun 2, 2018.
  1. DRACO
    DRACO Member
    362
    77
    Rancho Palos Verdes, California
    2002 Prius
    So MIL had code P3000 & P3006, DOC over 20% (36%) serviced (cleaned) and replaced Bus Bar ( could have cleaned it but why bother at $114 )
    Code popped up again but not DOC at 20%
    Prior to service CEL cleared on its own and ran great
    So I am thinking it may be the HV ecu just work out or faulty sensors and or solders due to high mileage?
    Anyone else experiencing this?
    Tia
    Jim
  2. dabard051
    dabard051 Tinkerer-in-Charge
    247
    92
    Rochester, NY USA
    2002 Prius
  3. DRACO
    DRACO Member
    362
    77
    2002 Prius
    Hey Thanks for your Post
    My bad sub code is 123, I have a techstream
    The thing is I installed a new from dealer bus bar ergo the better DOC
    It is just odd that with a DOC 20% it still trips the Triangle of Death
    One thing to note is when I did place the new bar on after cleaning all the terminals I accidentally arced the battery bank 1 and may have compromised a sensor on the back side, I cleaned the spot weld on the bar but I suspect it may have been damaged. I will find out with the new one once I receive it.
    Good call on connection to the HV ecu,I will check the connection for corrosion prior to install.
    I am leaning towards bad ecu if new bus bar fails
    Jim
  4. dabard051
    247
    92
    Rochester, NY USA
    2002 Prius
    much depends on the age and driving/thermal history of the battery pack.
    DOC? do you mean SOC (State of Charge)?
    Here is some more reading:
    Gen 1 Prius Battery Failure, P3006 - Luscious Garage | Hybrid Specialists
    and this (old, but informative)
    Gen1 Codes P3000 sub code 123 | PriusChat
    DTC P3000 INF 123 says "battery system", fuse, battery cooling system, power cable.
    I'd look to see if the battery cooling fan is properly operational; the rest is inspections.
    If you have the battery pack out, measure and record ALL the battery voltages with a DMM.
    If the highest-to-lowest differential is too big, that may set a code. But I think it's a different subcode.
    If the fan is okay, running...
    It may be time to consider a whole new battery pack. Your time is worth money, too.
    Best of luck...
    #4 dabard051, Jun 3, 2018
  5. DRACO
    DRACO Member
    362
    77
    2002 Prius
    Yeah I have to admit I did it quickly
    I will check all the connection this thing me around
    Actually I can remove and reinstall on 2 hours
    The cleaning takes forever
