Drive Modes
Discussion in 'Prime Main Forum (2017-2022)' started by MikeDee, Dec 6, 2016.
  1. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    The confusion is understandable. Toyota has my order, so I don't feel too bad in getting ahead of myself a bit.
  2. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    The fraction of the battery's overall capacity that's portioned off for EV usage.
  3. EV-ish
    602
    278
    SW US
    That will vary by SOC and your route and driving behavior. I'd like to hear specifics too.
    E.g., in a regular Prius the amount of battery contribution was highly influenced by SOC with the car trying to keep SOC in ~ 60% range. I don't know if Toyota changed the control parameters for HV mode in the Prime but their past announcements that Prime will preferentially use the battery during low power situations makes me think there are programming changes. It would make sense since the car may have ~ 10x the battery to use.
  4. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I can tell you about the PiP (I think the Prime will be principally the same).
    When I select HV while there are still EV miles available, this SOC (EV miles) are registered as the target to keep for later EV use.
    EV-ish likes this.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Let's just say the Prime uses 15% to 85% of the battery. I suspect it's a little bit less, but let's just suppose.
    The Ev range would be something like the 25% to 85% range, and the 15% to 25% range would be the Hv range.
    Note that I'm not claiming those numbers are accurate, just the concept.
  6. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    You are probably not far off with the numbers too. With the PiP it was found (by external equipment) that the EV portion is 85% to 23-24% SOC and the HV from there to 17-18%.
  7. EV-ish
    602
    278
    SW US
    That suggest 5.4 kWh useable in EV mode(s), and 216 Wh/mile for a 25 mile range. If my arithmetic is correct it matches the 133 MPGe rating although I am not sure if the MPGe is a combined city/highway number
  8. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I estimated 5.7 kWh useable for EV in another thread, it depends on charging losses (I estimated 10%).
    Someone reported lately (cannot find it) 6.3 kWh from wall for empty to full with L2, this confirms the 5.7?
    EDIT Found it:
    Vegas Trip in the Prime | PriusChat
    #48 giora, Dec 7, 2016
  9. Trollbait
    12,799
    It is how the EV mode on the PiP and Energi's work. The difference is in what acceleration rate and speed threshold triggers ICE use between the models. The Prime's EV mode is still a blended EV one, but the thresholds are high enough that most people won't trigger them in regular use.
    The Prius ICE warms pretty quickly, and it will go through the warm up cycle upon first firing so that it and the emission system will be warmed up for the next use.
  10. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Ford's had EV Auto in the Energi since 2013.
    #50 fotomoto, Dec 7, 2016
    Trollbait likes this.
  11. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Prime's EV mode is EV all he way! what you are describing here is EV auto.
  12. Lee Jay
    5,850
    4,036
    I had the engine start in Ev mode during a test drive. High throttle position and a small amount of remaining Ev range did it.
  13. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Yes, I should have said: all the way provided certain basic conditions are met. I assume it may also start when battery temp is extremely high and full throttle.
    Protecting the battery is the highest priority.
    #53 giora, Dec 8, 2016
  14. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Is there any difference to the liftbacks ev capability when driving the Prime in hybrid-mode ?
  15. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Liftbacks (with EV button) have two kinds of EV drive:
    1. without selecting EV, only at very low speeds and throttle displacements. Some call it 'golf cart mode'.
    2. with EV selecting, a bit higher speeds and throttle displacements.
    PiP (and I assume also Prime) does not have option 2. You cannot switch to EV drive from HV unless the battery SOC is raised into its EV portion (like regeneration in long downhill and of course while charging from external source).
  16. Trollbait
    12,799
    How much more ICE use does it have compared to the EV mode?
    The Prime has a top speed of 84mph in EV mode. Presumably, the car can go faster with the ICE. This and the use of the ICE at times of low charge and high battery temps mean that EV mode really isn't EV all the way.
  17. fotomoto
    5,639
    3,815
    So. Texas
    Just depends on how much throttle one uses. I don't use Ford's Auto mode much (almost never) because when driven efficiently (like I do) it will use up the batt completely before engaging the ICE even up to highway speeds. So I typically stick with EV Now till about 45mph and switch to EV Later (hybrid mode) above that when traveling on the highway on trips longer than the EV range.
    Bottom line: EV Auto doesn't seem to have very sophisticated software algorithms. I suspect the Prime will have more advanced programming.
    Trollbait and giora like this.
  18. martydallas
    martydallas Member
    106
    84
    Dallas, tx
    Lee Jay, I thought you had posted a link to the PDF of the Owners Manual. would you please point me to it. I am ready :) to put it on my ipad :)
  19. martydallas
    martydallas Member
    106
    84
    Dallas, tx
    Lee Jay likes this.
