Driver window control can't move Rear Passenger window up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Cloudx007, Apr 21, 2017.
  1. Cloudx007
    Cloudx007 Junior Member
    Southern CA
    Having a bit of a strange issue on a used 2010 Prius I just purchased.
    The drivers side window control panel can move the rear passenger window down (all down), but not up. Clicking to move it up is unresponsive. When it does go down, it goes all the way down, doesn't stop when letting off on the button. The window works just fine and dandy using the switch on its door.
  2. Cloudx007
    Southern CA
    I've tried moving the window down, then up and holding for 10 seconds.
    Also tried a variation of that where (from down) I move it up +hold for 6 seconds, then back all the way down +hold 2 seconds, then back up and hold for +2 seconds.
    Didn't do anything.
    I would have edited this into the original post instead of double posting but I cant find an edit button. Am I blind? o.o
  3. Dyjital
    Dyjital Member
    84
    51
    Oregon
    2023 Prius
    XLE AWD-e
    Check this as well:
    Right Rear Power Window Quandary... | PriusChat
  4. Di Get
    Di Get New Member
    Baku
    is there any solution? I have the same problem. I can move the rear passengers window down (all down), but not up.
  5. shmuk
    shmuk New Member
    usa
    hello
    i have same problem, front windows working perfect, the rear windows just going down but not going up by the driver door switch.
    how did you solved this problem?
