Driver's side door handle
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by 4rpr15, Sep 16, 2017.
  1. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    Has anyone noticed that the driver's side exterior door handle makes a louder sound when the door is opened? It almost feels like something is loose.
    All of the other handles have a smoother opening and no sound.
  2. Mark57
    2,945
    2,740
    OK
    I just now tested all 4 of mine on my 3 day old Prime and there's no difference in sound.
    Let the dealer check it out to be sure.
    4rpr15 likes this.
  3. 4rpr15
    1,056
    375
    WI
    I tried it again and maybe it's in my head. :) I had a Highlander before so these handles are much smaller and not as quiet as the Highlander door handles. How do you like yours? I drive 18 miles to work and have 10 Mike's to spare. I can't wait to see how little I actually have to go to the gas pump.
  4. Mark57
    2,945
    2,740
    OK
    I love it, but it's only my 3rd day. More of a mileage workout coming in the next few days. It's a massive improvement over my 2010 Prius II. So far it's all been EV, I have not even tested the engine yet. ;)
  5. 4rpr15
    1,056
    375
    WI
    Awesome! You have driven less than 30 miles each time you drive ? Or after 30 miles your averaging mainly EV miles?
    The dealer put door guards on mine and I'm noticing that the driver's side door tends to pop open when I open the door from the outside. It also has a louder knocking noise vs all of the other door right when it opens up so I gotta take it to the dealer for some warranty work.
  6. Mark57
    2,945
    2,740
    OK
    Right, all my drives have been less than 30 miles round trip, so far. That will change this week with road trips @ 90 and 250 miles. I actually get to see if the engine runs. :p
    Good luck on the dealer trip. Probably minor stuff.
    4rpr15 likes this.
  7. 4rpr15
    1,056
    375
    WI
    Dealer says the handle feeling/noise is normal. It’s isn’t though. I tested out Gen 4 Prius’s on the lot and they all open smoothly. Mine has door edge guards so I’m wondering if that has something to do with why only the drivers door feel like it pops open like it’s jammed on something when I pull on the handle. The sound it makes also makes me believe something is wrong with it. It has a loud popping sound.
  8. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    I have door edge guard on mine. Not exactly sure what you mean by lauder noise, but I don’t feel or hear anything out of ordinally from my driver side door handle.
  9. 4rpr15
    1,056
    375
    WI
    When I pull on my handle I feel the door pops open vs opening smoothly as the other doors do.
  10. Salamander_King
    11,024
    8,980
    New England
    That sounds more like issue is with door hinge area rather than the handle. In any case, I'm not feeling anything unusual.
    4rpr15 likes this.
  11. 4rpr15
    1,056
    375
    WI
    Anything I can try myself to fix it? Dealer wants to remove the door panel next time I come.
  12. Salamander_King
    11,024
    8,980
    New England
    If it is an older car out of warranty, I may try something simple like lubing door hinge. But since it is a brand new car, if I am in your shoes, I would let dealer take care of it. It may be as simple as lubing hinge, but could be much more complex. I own Sienna minivan, and it had a factory recall on door with popping noise, not sure if that is similar to your problem though. It was something like welding of door hinge arm to the door frame was defective and tend to come off. I would not be able to fix that problem if it wasn’t done by professional. Goof luck.
    4rpr15 likes this.
  13. ct89
    ct89 Active Member
    323
    266
    New England
    Anything visually obvious about how the door aligns when closed? Are the outer edges aligned with the rest of the body. If so, I would look to something providing pressure on the inside like a door panel that is not pressed in all the way or the rubber buckled or such.
    I just tried all four of my doors and could not notice anything different or unusual. If I very carefully opened them with minimal handle pressure, they only "popped" open an inch or so. If I slowly closed them, they each made it to about a 1/4" of closed before any notable resistance. Basically engaging the first latch but then requiring a bit of force to get past that last 1/4" and fully close.
    I would recommend getting the dealer to understand what they are trying to fix. They must understand the problem before I would have any faith that they can fix it. Exploratory surgery by a dealer with no experience and no idea of what they are looking for would make me nervous. Once they can acknowledge the problem, I would feel better about letting them try to fix it. If they can't, ask to talk to a toyota rep.
  14. 4rpr15
    1,056
    375
    WI
    I wonder if I can post a video on here and if I can, will you be able to hear what I hear.
