DTC P1150 Troubleshoot Revisit
Discussion in 'Gen 2 Prius Technical Discussion' started by NortTexSalv04Prius, Apr 13, 2018.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Hello
    I have read several threads in the forum about the OBD DTC P1150.....
    and also done some other preliminary background
    First and /or to begin
    DTC P1150 as applied to a 2004 Gen 2 Prius
    Coolant Path clog heat storage system CHS
    Engine preheat coolant storage
    Possible causes found on initial search
    CHS
    sensor
    ecm
    flow control valve
    clog path .....many places to detect on this one (radiator core, heat core, HV inverter/converter circulation path,
    If anyone has any real feasible solution and a path for troubleshooting this I am grateful for help
    FYI also unsure about vehicle elapsed time without being operated in 2 year period
    #1 NortTexSalv04Prius, Apr 13, 2018
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Has this vehicle been sitting unused for two (2) years?
    How many miles on this vehicle?
    Was this a 'salvaged' vehicle?
    What device did you use to retrieve that P1150 DTC?
    Have you read and or tried what was suggested in this thread?
    CHS Temp Sensor and P1150 | PriusChat
    Raytheeagle likes this.
  3. NortTexSalv04Prius
    915
    115
  4. NortTexSalv04Prius
    915
    115
    YES
    Hard to say on that maybe could be the timeline
    Bosch loaner from Oreily auto part and scangauge 2
    FYI
    further vehicle is drive able
    However any long distance creates 200 plus coolant temps on scanguage
  5. NortTexSalv04Prius
    915
    115
    My first possible focus is locating clog coolant path (maybe inverter /converter HS) or (heater core)
  6. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Another PC member recently had a coolant blockage issue, and finally reported it as a clog in the lower radiator: Constantly Overflowing Coolant | PriusChat
    If you're still stuck it tracking the problem down, here is the "path for troubling shooting" that DTC P1150:
  7. NortTexSalv04Prius
    915
    115
    hey thanks
    some how I got the first page only
  8. ChapmanF
    15,557
    It will keep the troubleshooting simpler to remember that the HV inverter/converter cooling loop is completely separate and has nothing in common with the engine loop; this code's about the engine loop.
    (I know we covered that on the other thread already, but just to keep things clear for others who might find this thread later....)
    -Chap
    NortTexSalv04Prius and SFO like this.
  9. NortTexSalv04Prius
    915
    115
    GOING TO GIVE A BIG SHOUT OUT FOR CHAPMAN
    THANK YOU
    THE SENSOR SEEMS TO BE THE ISSUE
    THANK YOU MR C
    SFO and Raytheeagle like this.
  10. NortTexSalv04Prius
    915
    115
    Ended and SFO like this.
  11. NortTexSalv04Prius
    915
    115
    THANK YOU AGAIN
    SOMEHOW WHEN I STARTED TROUBLE SHOOT ONLY GOT ONE PAGE PRINT OUT
    THANK YOU SFO
  12. NortTexSalv04Prius
    915
    115
    Okay sad return and will be creating new thread
