Easiest way to Tint/Black out rear lights?
Discussion in 'Prius c Accessories and Modifications' started by techno-Zen, Apr 30, 2014.
  1. techno-Zen
    techno-Zen Junior Member
    Mesa, Arizona
    I'm going for a White/Black look on my Blizzard pearl Prius. I have black rims, black badges, and pretty dark tints and i'd like to complete the look by doing my rear lights.
    Would plasti-dip be a good method?
    Anyone done this?
  2. GregP507
    GregP507 Senior Member
    3,002
    481
    Personally, I think my PIP is already a bit loud, so I don't plan to dress it up at all.
    What's plasti-dip? Is that like something you can paint on to protect the car, then strip it off later?
  3. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i dont think plastidip will be good on tails since it wont be that translucent. google VHT night shades. or you can always use vinyl tint.
  4. techno-Zen
    Mesa, Arizona
  5. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Consider this carefully.
    I have been behind a few "cool dudes" with blacked out tails lately and the stop lights are almost
    impossible to SEE in the daytime.
    And going down the freeway at night, they look like they have no tail lights at all until you get right up on them.
    OldNo7, fuzzy1 and TheyCmeNow like this.
  6. TheyCmeNow
    TheyCmeNow Junior Member
    77
    25
    Don't be that guy. Head lights and Tail lights exist for a reason. I seen idiots in california who tint both their head lights and tail lights! :mad:
    Chris92057 likes this.
  7. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Please.
    Don't.
  8. icspots
    icspots Junior Member
    Not to come in on either side of the whether or not you should do it debate..... I mean if you're going to do it none of us are going to stop you. As was mentioned plasti-dip is a terrible choice as it's opaque and would sort of defeat the purpose of having lights in the first place.
    Also as was mentioned the real options are pretty much a vinyl film to wrap around the housing, or a spray on product like VHT nightshades. You could also take it to a body shop who could mix a dark paint to be clear and then spray it on. Any of them you do yourself will come out as well as how much effort you put into doing them..... so if you rush they'l look like crap. I mean it's always possible it may look like crap anyway. :) If you're looking for easily reversible then vinyl would be the way to go as you can always just peel it back off. Spray on tints can be removed with competent sanding, but that may be something you don't want to do yourself.
    You could always do a vinyl wrap to see if you like it and then go with a spray on coat later on (either self applied or professionally). Whichever you choose I'd caution you to not go completely blacked out. You can get a fair amount of the "blacked out" look while still leaving the lights completely visible. Even just enough to dampen the chrome accents in the lights can change the look immensely.
    As a last alternate you could put a lot more effort into it, open the housings up and tint the interior pieces instead of the exterior housing. That's probably more trouble than it's worth.... I'm not sure about the prius, however many tail lights are sealed up by melting the edges of the lens cover around the main housing vs. the adhesive which most headlights use.
    mertechperformance and JGriffin like this.
  9. techno-Zen
    Mesa, Arizona
    It doesn't need to be completely blacked out, just smoked. It will cause ZERO safety issues. The light will be visible completely.
    My car came tinted from the dealer and the brake light is behind tints and is visible. What's the difference?
    I know what you guys mean, i've seen cars with BLACKED out tail lights and you can hardly see their brake signals. That's not what i'm going for.
    and no, i'd never do my headlights.
  10. kingnba6
    1,018
    242
    NY
    tint and smoking are two different leaves from the same tree. smoking the tail lights to get rid of all the chrome shiny-ness can be done by using vht spray but very few layers of it
    GregP507 likes this.
  11. acceleraptor
    acceleraptor Member
    229
    75
    Milpitas, CA
    2014 Prius Plug-in
    I'm finding tint films for "smoking" taillights for your model/gen Prius on eBay, searching for:
    "taillights smoke 2010 Toyota Prius Base 1.8L"
    As with tinting of any kind, laws vary from state to state, though often with similar objectives and motivations in mind, and all legality is on the owner|driver's head. I did find this though:
    Tail Light Laws in Arizona | eHow
    Display
    • In Ariziona, a vehicle must have at least one rear-mounted tail light of which the red light is visible from at least 500 feet. The light must not be tinted any other color.​
    Position
    • As stated in Section 28-923, Subsection B of the Arizona State Legislature, the position of a vehicle's tail lamp should not be higher than 72 inches and not less than 15 inches.​
  12. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    FWIW Prius C tail lights are NOT Bake-able. Trust me, I learned the hard way. tried to bake to pop the cover and paint the inside to lose the HIDEOUS chrome on the sides and NON essential parts. MAJOR FAIL.
    HarSherm and GregP507 like this.
  13. koipond
    koipond Member
    198
    40
    I bought a pair of pre tinted tail lights from Garm. I'd be happy to sell (cheap) my stock tail lamps to anyone who wants them. Might work well for someone fo experiment with or use as backups if their tinting attempt fails.
    SCH-I535 ?
  14. hill
    8,747
    2004 & 05 prius tail lights came dark from the factory
  15. mertechperformance
    532
    126
    Nor-caL
    pmed
  16. HarSherm
    HarSherm Junior Member
    31
    Burlington, Vermont
  17. HarSherm
    31
    Burlington, Vermont
    Thanks, Mr. Mertech. You saved me major heartache by this warning! Sorry for your loss.
  18. ufourya
    ufourya We the People
    1,258
    336
    42
    This thread may prove useful:
    Blacked Out Tail Lights | Page 2 | PriusChat
    Even if you put on a little too much NightShades, it can be polished off without too much difficulty until you arrive at the tint you want. I feel perfectly safe and have had no problems.
  19. gmacfan01
    gmacfan01 Junior Member
    56
    I used the smoke plasti dip on my rear lights it works but im not 100% satisfiyed with the look, other people seem to go both ways as well some people like it others do not
