ECU / Red Light Issues. No Start. - New Prius Owner
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cpd, Apr 2, 2020.
  1. cpd
    cpd Junior Member
    ATLANTA
    I got a new (used) prius a couple weeks ago. Apparently sold by a weasle. It's never started reliably, and the red triangle light comes on / off. Jumping it would start it though. I replaced the low voltage battery. It started 4 more times, then won't start at all. Not even with a jump. Also, the red triangle + CEL, and several other dash lights stayed on now.
    The toyota dealer gave me a very vague diagnosis.
    I was told 2 parts and 5 hours labor.
    Part 1: Hybrid Battery Computer - ECU -
    Computer Assembly, Battery - $960
    Part 2: Hybrid Computer - ECU
    Computer, Hybrid Vehicle - $544
    Labor - 5 Hours @$130 / HR
    I'd really like to get some feedback before I spend $2500. Honestly, after like 2 hours on the web, I can't even figure out what the parts are that they need replacing.
    I'm skeptical that these both actually need to be replaced. And even so at 5 hours, for 2 jobs, it's probably something I can DIY with some direction.
    Below are screenshots from the written estimate.
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Welcome to PriusChat!!
    Did you pay the dealer for this repair estimate, if so they should've supplied you with the retrieved OBD2 codes (DTCs) on the paperwork.
    Many find using a toyota hybrid compatible OBD2 scanner as helpful when diagnosing a problem, as it may help save time and money.
    Have you already checked the 12v battery for voltage, and again the 12v voltage at the jump points under the hood (driver side), and also be sure to check the battery cables attaching to the 12v battery and to the body (negative ground strap).
    Please post the DTCs (OBD2 codes) here and we can offer additional guidance.
    51,155
    how many miles on her?
    SFO likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    You came to the right place.
    Explain what you mean by 'it started 4 more times'. Does this mean you successfully drove the car 4 seperate times? or that you heard the engine spin for several seconds and then turn off, 4 sererate times?
    I'm curious if the battery depleted itself trying to start the engine....... but there are many possibilities. We need actual codes, which will most likely only be able to be read by a prius/hybrid aware code reader
    No surprise, but if you paid a diagnosis fee, they owe you the code printout.
    Again, you came to the right place. If needed, I have every computer you may need.
    The important first step is the codes.
    Is there any chance at all that you connected the 'jump' backwards, even for a second? If so, this almost always blows the large fusible link in the underhood fuse box, plus a couple or three fuses. The fusible link that blows is under the clear plastic cover, directly below the underhood jump point as seen below.
    #4 TMR-JWAP, Apr 2, 2020
  5. cpd
    cpd Junior Member
    ATLANTA
    Guys, thanks for the great feedback. From what I've gotten so far, I take it that what you guys also don't get much from the dealer writeup?
    As for answering your questions:
    No codes were given by the dealer. I'll call and ask today.
    Can I get a link to a recomended prius compatible code reader? If I keep this car, I figure I'll want to have one.
    100K miles on it.
    Started and drove 4 times. Drove from the dealer (they put a new 12V in). Lights came on in my driveway (10 miles). Stopped. Drove around my neighborhood. Stayed on. Went on a highway ride, and they went off. Went to the park (came on), stopped at a freinds on the way back. Wouldn't start or jump.
    Definitely didn't connect the cables backwards.
    #5 cpd, Apr 3, 2020
  6. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Most here will use a mini-vci cable with Techstream (same software the dealer uses) on a windows device (or emulated).
    If you would rather try using an OBD2 adapter, then read up on some of the options here : Hybrid battery diagnostic and repair tool for Toyota and Lexus - Once you have an OBD2 adapter, then try one of the apps like : Dr Prius/Dr Hybrid, Hybrid Assistant. I've successfully used some cheapo OBD2 bluetooth adapters ($2 shipped) before, but wouldn't recommend it.
    Hopefully the dealer will come clean with the DTCs that you've paid for. Is the vehicle is still parked at the dealers?
    #6 SFO, Apr 3, 2020
    Raytheeagle likes this.
  7. cpd
    cpd Junior Member
    ATLANTA
    Codes / Parts
    Feedback from the Dealer. They said the want to replace the following two computers with part numbers:
    89981-47212 - HV Computer
    89890-47092 - Battery Computer
    Codes:
    P3000
    P0ac0
    P0afa
    P0420
    Tsb-0166-09
    Code Reading
    I've looked at the vci cables on amazon. It looks like it'll take til the end of May for one to get here. Which won't do me a lot of good near term. I'll probably want to find one eventually, but I'd very much like to get this resolved sooner.
  8. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    The P0AC0 is: Hybrid Battery pack current sensor circuit range/performance and trouble areas are:
    1. HV battery assembly wire harness or connector
    2. Battery current sensor
    3. Battery ECU
    The P0AFA is Hybrid Battery System voltage low and trouble areas are:
    1. Junction block assembly (a busbar module on the battery)
    2. Number 2 wire frame (a wire harness used in the HV battery to sense module voltages)
    3. Battery ECU
    Most likely the P3000 is just the hybrid system letting you know that the battery ecu is throwing out a fault signal.
    The P0420 is catalytic converter efficiency below threshold.
    Personally, if it were my car, my suspicions fall completely on the HV battery and its ecu. Something is going on with it. A good visual inspection by a knowledgeable person would probably resolve it. That's no surprise, whether it's original or a typical rebuilt replacement. I'd have to tell the dealer no thanks for now. If it's original, it's probably due for replacement. If it's a typical rebuild, you'd be better off replacing it anyway.
    As for the TSB: It's kind of strange to me that the TSB is dated May 28th 2009. Would make sense to me that a 2009 Prius (yours is 2009 right?) would have this 'improved' ecu and hardware. I would be VERY surprised if a 2009 didn't have the 47092 battery ecu. The other one, you could probably get from ebay for a hundred bucks if desired. I was wrong, they're all over ebay for 40 bucks.
    TOYOTA: SOME VEHICLES MAY EXHIBIT A M.I.L. ON CONDITION WITH ONE OF MORE OF THE FOLLOWING DIAGNOSTIC TROUBLE CODES (DTCS): P0AC0; P0A1F; P0A7F; P0AFA (HYBRID BATTERY PACK/SYSTEM). IMPROVEMENTS HAVE BEEN MADE TO THE HV ECU AND BATTERY ECU HARDWARE TO CORRECT THESE CONDITIONS. *PE
    #8 TMR-JWAP, Apr 3, 2020
  9. cpd
    cpd Junior Member
    ATLANTA
    Also forgot to add. The guy said the pins were burnt. I asked for photos. He went to the tech. Coming back he said they couldn't provide because they put the covers back on. And it was that there was gunk all over the connectors. Not that the pins were burnt.
    Sounds like an obvious case of just clean the connectors, and the ECMs are fine. But they might still be able to know more based on techstream.
  10. cpd
    cpd Junior Member
    ATLANTA
    Are those both ECUs I could replace myself? Are they plug and play or can I order them preprogrammed? Also are they reasonable accessible?
    I'd start by cleaning any relevant wiring connections, first.
    I'd also add. The hatchback door leaks and the spare wheel well fills with water. I figure the moisture could be adding to corrosion or some similar issue.
    #10 cpd, Apr 3, 2020
  11. cpd
    cpd Junior Member
    ATLANTA
    How about a mediocre visual inspection? I can send you some pictures if you tell me what you want to see.
  12. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    The HV battery ecu commonly gets corrosion on the pins where the #2 wire frame plugs into it. So this wouldn't be a surprise to me. I have seen it be bad enough that a pin or two breaks off on the ecu side. This ecu is relatively easy to replace and requires no programming at all. Just a chop and swap/plug n play or whatever you want to call it.
    The HV Control ecu is located behind the glovebox and on the far passenger side. I've never swapped one on an operable car, but have removed them from salvage cars. A bit more of a PITA. It is also my understanding that the HV Control ecu needs to be programmed with the cars VIN, and a previously used ecu CAN be rewritten with a new VIN
    #12 TMR-JWAP, Apr 3, 2020
  13. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    You may want to check the dealer reported "vehicle mileage", TSB/recalls, and maintenance/service history at https://toyota.com/owners
    Check for mini-vci cables on Ebay (unless you only support Bezos), then try sorting by US sellers, as one might be available more locally.
    If you have the time and tools, use this guide to get you towards the HV battery and related ECU : 2004 – 2009 Toyota Prius Plug-and-Play Car Harness Installation Instructions | Hybrid Automotive
    Optional: You can also inspect and clean the HV battery fan while working through the process (step #23).
    Once you have all of the trim and stuff out of the way and the HV battery exposed (and after taking all safety precautions in step #6 and #13, and any others you may need), take a look at the HV battery ECU and connector by remove the hybrid battery junction cover (step #14), neither one should NOT look like this : 2005 179km Wont go to Ready Mode | PriusChat
    Or look like anything that might be fired and pictured in this thread (a gen1 thread FYI) : https://priuschat.com/threads/the-battery-fires-at-ecu-sense-connector-thread.151412
    If bored, open up the HV battery cover, and look at the corrosion around the bus bars and wires, and then create a game plan from there.
    There are a bunch of threads here that can help identify where the leaks are, and how to seal them. Here is one to get you started.
    #13 SFO, Apr 3, 2020
  14. cpd
    cpd Junior Member
    ATLANTA
    Alright guys. I got the prius home from the dealer. It randomly started and ran again.
    For the interesting part.
    1. I definitely need a new battery computer. It's, literally, toast.
    2. Pretty confident I need a new computer connector. Is it possible to just replace the connector and keep the wires?
    3. I also may need a whole new wiring set anyway. The whole array is pretty corroded. None of the connector tabs look corroded all the way through, but many look like they've lost some diameter.
    4. The weld up near the door lift was leaking on both sides. FIXED. That was the easy one.
    I'll take some recomendations from you guys on what to replace, and try to order some parts later this week.
    SFO likes this.
  15. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    Never seen toast that looked like that. I think you meant it's, figuratively, toast and then you could leave the word figuratively out, as we all know that's what you mean. Even if you meant it is burnt like toast, the word is still figuratively. (Sorry, been inside a while now, I couldn't help myself.) ;):sneaky:(y):)
    All joking aside, most likely the actual ECU is ok, but no guarantees. You would need to replace the plug on the harness, the connector on the board and two (or maybe 4) of the pins within the plug (the remainder can be moved over from the old connector), which I'm not sure whether that is easier said than done, in terms of actually getting those parts. You could look through the EWD (electrical wiring diagram) (more info) to find the plug, connector, and wire pins.
    A less elegant, but easier, way would be to buy a new Wire Frame No 2 from Toyota and a second-hand ECU off eBay/Amazon or an auto wrecker yard/pick-n-pull.
    I hope that helps and good luck.
    #15 dolj, Apr 15, 2020
    SFO likes this.
  16. cpd
    cpd Junior Member
    ATLANTA
    Thanks for the info. Looks like I'm going to order a harness, and ECU.
    Based on the corrosion, do I need to replace the wiring harness on the other side as well? Or am good with just the one.
  17. dolj
    dolj Senior Member
    8,217
    4,187
    The new harness should be all you need for the front side and the wiring. On the rear side, you just clean up the connecting plates and terminal nuts and reuse them.
  18. cpd
    cpd Junior Member
    ATLANTA
    Great news. Thanks!
    I ordered a new ECU and wiring harness on Ebay today. They should arrive next week.
  19. cpd
    cpd Junior Member
    ATLANTA
    Alright guys. The saga continues.
    I got the computer and wiring harness installed today.
    The good news: The car starts and runs! It's started no problem several times. I took it on a drive, 10 miles, 50/50 highway/city, and my mpgs are up to 54 from 40 average before. So it's clearly working much better overall.
    The bad news. The triangle light is still on. The other lights that were on (break, CEL, etc, there werre a bunch) are gone. I don't get any codes with my standard code reader (before or after the drive). I still don't have a techstream setup, so I'm not sure if I need that to pull the triangle light codes. Or maybe I just have to reset the triangle light.
    Anyways, what do you guys think?
    Unrelated: I went ahead and cleaned the fan light you guys said. It wasn't that bad.
  20. dolj
    dolj Senior Member
    8,217
    4,187
    You should have cleared the codes after your work, they won't necessarily reset by themselves. You are at a loss as you obviously cannot read all codes wit your std reader, so you are not going to know what it is worried about and means you cannot make a judgment call as to whether the codes are something new to worry about or just residual from before your work. If the triangle is still on, you can use your reader to clear all codes and see if any come back. If they don't then you could assume that they are from before your work. If they do not clear or come back after, then you will need to get your Techstream running so you can read them with the knowledge you are starting with a clean slate.
