Electrical or software problems on my Prius Prime
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Civic4982, Dec 12, 2016.
  1. PennyH
    PennyH Junior Member
    Indianapolis
    Per 11" Navigation Manual: p 280
    ● If an iPhone is connected via Bluetooth® and USB at the same time, system operation may become unstable.[/QUOTE]
  2. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    And many of you should know that using not approved cable for IPhones will result in many problems..same applies to Android Big Smartphones
    Another thing is to make sure if you are using usb connect to car Radio...make sure you are in off state with Bluetooth......
    No matter how device are smart this day's if you don't read about limitations you will always have issues
    priuscatprimeguy likes this.
  3. GLouderback
    GLouderback Member
    Lower Merion PA
    Only have had one issue in the month and a half and 1400 miles, and that was the console doing a reboot as I was driving along with the nav system in use. Everything came back up except my destination which I had to reprogram back in. Wasn't touching the screen at the time. Just driving along.
    We all should be aware that there will be software upgrades to fix many of these problems. Just like on any computer operating system. Most of these problems will be intermittent and therefore won't be seen by the service department. I suggest waiting for the bug fixes.
    #43 GLouderback, May 13, 2017
  4. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    No, No, No! You are "beta testing" one tomorrow.
    jtv likes this.
  5. William Redoubt
    1,228
    1,173
    I just waved bye bye to the warranty period (over 36,000 miles in 14 months) with only 1 issue: bad 12 volt battery (just replaced under warranty). I jumped the car with a handful of flashlight batteries, and now have a small LI jumppack ($40).
  6. jburke313
    jburke313 Member
    48
    North Shore, Massachusetts
  7. Bec Work
    Bec Work New Member
    Yes. I've had my 2017 Prius Prime Advance for about 3 weeks and the voice recognition was working when I gave it a music command but now it says I have a usb error and check iPod sub connection. Voice recognition works for all the other commands just not the music. Any suggestions to correct this?
  8. alexey00
    alexey00 New Member
    US
    70 miles, battery pack was dead..
    140 miles check engine/airbags
  9. primer
    primer New Member
    My Prius prime advanced, while driving down the freeway also went blank. Two of us in the car. Coasting to exit and it restated like it had been turned off. Very scary as Toyota doesn’t know why. Just can’t drive it anymore.
  10. primer
    primer New Member
    I was told the port is fro data only- not charging as it has the q pad for phone that can charge that way. The cable port is for data only. ( certainly ly not what sales rep told me since there is only one cable port )
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,153
    Tampa, FL
    You were told wrong. I've used mine for charging many times. However, since my iPhone is normally connected by bluetooth, I don't use the data port with it since that can make the system unstable (p. 108 and 280 in my Nav manual).
