Engine rattling / shaking after filling from spare fuel tank - P3191
Discussion in 'Generation 1 Prius Discussion' started by jamesprius, May 16, 2020.
  1. bisco
    51,983
    techinfo.toyota.com
    or you can look here in the tech section for free sources
  2. jamesprius
    jamesprius Member
    142
    17
    San Jose, California
    2001 Prius
    I
    I see a tech section for Gen 2. Is a there a tech section for the Gen 1? It's strange it seems Gen 1 forum is inside the Gen 2 forum and there is no dedicated top level subforum for the Gen 1.
    51,983
    yeah, gen 1 never got any love
  4. jamesprius
    jamesprius Member
    142
    17
    2001 Prius
    I
    Something we can take up with the mods? Doesn't seem like it'll be hard to do.
  5. bisco
    51,983
    people have been asking for years. the further away we get, the tougher it will be i suppose. it never hurts to ask.
  6. jamesprius
    jamesprius Member
    142
    17
    2001 Prius
    I
    Just sent a help message.
  7. bisco
    51,983
    there is also a website question thread
    jamesprius likes this.
  8. jamesprius
    jamesprius Member
    142
    17
    2001 Prius
    I
    WHCSC and bisco like this.
  9. Q*bertZ
    Q*bertZ Member
    155
    39
    greenville south Carolina
    2002 Prius
    No, this is (see picture) Taken from under the car in front of the passenger side back tire.
    If you have bad gas in it, it is not going to combust. ICE will run like garbage. I tried running straight injector cleaner fluid in mine. injector fluid will not run an ICE by itself. it needs new GAS.
  10. Q*bertZ
    Q*bertZ Member
    155
    39
    2002 Prius
    sorry it took me twelve days to reply.
  11. Q*bertZ
    Q*bertZ Member
    155
    39
    2002 Prius
    P3191 always means the engine does not start.
    You know you put bad gas in it. Get the bad gas out of it.
    cheapest and easiest thing to try is: Clean mass air flow sensor.
    Here are some help full pics 20200611_094545.jpg 20200611_094523.jpg 20200611_094454.jpg 20200611_094429.jpg I found on the web
  12. Q*bertZ
    Q*bertZ Member
    155
    39
    2002 Prius
    I thought you said the engine was not running. This will let you see if 1. the fuel pump is working ( you are correct, gas will not get to the engine if it comes out in the pan under the car.) 2. you can inspect the gas in the catch pan under the car for water and flammability. ( i wouldn't be smoking when you do this).
  13. ttou68
    ttou68 Active Member
    351
    211
  14. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    Jet fuel is kerosene. Or, did you mean AvGas aka 100LL?
  15. ttou68
    351
    211
    Yeah, that! LOL
    Or racing fuel.. back in the day, we refer her fuel as racing fuel..
  16. jamesprius
    jamesprius Member
    142
    17
    2001 Prius
    I
  17. jamesprius
    jamesprius Member
    142
    17
    2001 Prius
    I
    Won't you have the keep cranking the car to get the pump to run?
  18. jamesprius
    jamesprius Member
    142
    17
    2001 Prius
    I
    I was thinking it might be easier to disconnect the fuel line from the front of the car then engage the fuel pump somehow. I think it can be done by shorting the C Opn relay based on what I've seen.
  19. jamesprius
    jamesprius Member
    142
    17
    2001 Prius
    I
    So I think I found the quick disconnect line. It's surround by the different components so I couldn't really get a grip around it. I also didn't want to put too much pressure and break something. Is it supposed to disconnect at the red line or blue line in this pic?
    Not sure why they put it there. Can't really fit my hand in there to disconnect it. Might need a special plier to push and pull and the same time.
  20. jamesprius
    jamesprius Member
    142
    17
    2001 Prius
    I
    Also pulled the EFI relay. Not sure if I'm supposed to short the orange or yellow leads to energize the pump.
