Engine turns on randomly in EV mode
Discussion in 'Prime Main Forum (2017-2022)' started by m8547, Oct 8, 2018.
  1. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    This weekend I had the engine come on unexpectedly in EV mode. I had about 17% charge remaining, it was 37 degrees outside, and I was driving at 71mph. I hit the cruise control on button, and the engine immediately started. Any idea why? The cruise control might be a coincidence.
    I've learned that going down hill at high speed will cause it to switch from regenerative braking to engine braking, presumably because the battery can't take that much charge that fast.
    And I know running the front defroster will turn on the engine.
  2. fuzzy1
    10,674
    Were you on a steep downhill at that time? If so, about what slope %?
  3. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    Not this most recent time. It was flat.
    On Fremont Pass it's something like 7% grade at 65mph for a few miles. It pretty quickly switched to engine braking, even after I went back to D mode.
    I've also seen it in Boulder Canyon which has 10% grade in one spot, but the speed limit is only 45mph there.
    On Mt Evans I was able to get something like 70% charge on the way down. The battery was drained at the top, but from there I was able to drive over 60 miles in EV mode, coming from 14,000 feet back to 5,000 feet. The speed limit is 25 or 30 most of the way down from the peak.
  4. Tideland Prius
    16,659
    didn’t @bwilson4web determined that CC did engage the engine for some reason? He was the first to notice this behaviour
  5. bwilson4web
    16,499
    I wasn't first but once I could reproduce it, I helped measure the limits.
    Tideland Prius likes this.
  6. bisco
    52,695
    prime does not have a strict ev mode like volt
  7. Trollbait
    12,789
    Doesn't the manual give a list of potential reasons for the the car to exit EV mode, or I'm thinking of the non-plug one for EV operation?
  8. bwilson4web
    16,499
    PriusChat supplies the missing Appendix and performance, mph vs MPG charts.
  9. benagi
    benagi Active Member
    525
    280
    Utah
    I have 5500 miles on mine and the only time the ice comes on is when I run the traction battery down or I put it in HV mode.
  10. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    Was the front defroster engaged?
    In the following situations the gasoline engine may operate in order to exhaust heat from the engine coolant via the heater even in EV mode.
    • The outside temperature is extremely low
    • is operating
    benagi likes this.
  11. bb4srv
    bb4srv Active Member
    140
    107
    2018 Prius Prime
    Technology
    My observations, the ICE will engage even in EV only mode:
    1) using front defroster only (not the dual defrost and foot) when outside temperature is cold, around less than 10C
    2) downhill and using regen braking to slow down if Traction Battery at 90%+
    3) long downhill using regen braking, when the energy produced from regen exceeds the Traction Battery charge rate
  12. TroyF
    TroyF Junior Member
    30
    Grove City, PA
    2018 Prius Prime
    The downhill engine-on situation is very frustrating. My commute is 26.1 miles in hilly terrain. In the summer and fall (no AC and no heat) I can drive all EV from my house to work with 8 to 17 miles remaining on the battery. The last three miles is mostly downhill at a steady grade. I can add three or four miles of regen during that last downhill.
    Now the frustration... As the weather has cooled to near freezing and below, I find that even with several miles of battery remaining, the ICE kicks in partway down the long hill. Why is this? I usually approach the crest of the hill at the lowest speed that traffic will safely allow - sometimes 25mph. It is four lanes (two each way), so there is room for faster cars to pass and they can slam on the brakes all they want to at the bottom where the speed slows to 35mph. I let the car gradually increase in speed until about 40mph, and then brake to keep the speed steady, or slowly reducing speed to the limit at the bottom. But in this cooler weather - again, with heat off, the ICE turns on partway down. And then it stays on for the remaining few miles until I park, wasting all that gas and having to heat the engine all the way.
    I have tried going slower, going faster. Some days I have driven partway in hybrid mode so that the engine is already warmed, but the ICE still kicks on MANY (but not all) times with the temps cooler. I don't use the defroster, and usually not even the heater, and ICE still starts.
    Any engineering reasons? And why does the ICE not start in the warmer temps (seemingly)? And is there anything I can do to avoid the ICE starting such as turning on some electrical accessories, braking differently, etc.?
  13. bwilson4web
    16,499
    We mapped it out and apparently 50F is the threshold and an SOC above 90%. Below 50F these unexpected, engine-on events become more frequent. There is a workaround.
    As soon as you find a safe place, pull over and power-cycle the car. It will come back to READY in EV mode and proceed. Agreed, it is a pain. As for engineering reasons, your guess is as good as anyone else.
    ps. Earlier works:
    TroyF likes this.
  14. juhjuhjuhjames
    juhjuhjuhjames Junior Member
    49
    seattle
    Wish there was a way to force pure EV mode. I probably have the shortest commute here (7 miles one way) and even with only a couple hills, during this past winter, ICE will kick in somewhere along the commute. Mind you, this is with one or two bars of heat (not defroster) with temps never reaching below 30.
    I know weather definitely plays a factor. During the summertime, I'd drive the same commute on pure EV while going 70/75 on the freeway
    TroyF likes this.
  15. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    Drain the gas tank.
    (although I have no idea what happens)
    TroyF and benagi like this.
  16. TroyF
    TroyF Junior Member
    30
    Grove City, PA
    2018 Prius Prime
    Lol. That would be an idea, but getting back home at the end of the day would be a challenge. :)
  17. TroyF
    TroyF Junior Member
    30
    Grove City, PA
    2018 Prius Prime
    I appreciate the parameters and advice. In terms of SOC, my remaining miles is about 8 to 10 at that point, so about 30% remaining.
    The power cycle that you mention may help too, although one day I had a stop at the top of the hill before the last three miles, and turned the car off. When rolling gently down the hill a few minutes later the ICE still came on. Temps were around 25F that day. So temperature seems to be the biggest factor in my observation.
    These days, in the cold winter months, I now put the car in Hybrid mode when I leave the house. That way I can use the heated engine for heat and to maintain SOC for part of the first leg of the commute. I return to EV mode somewhere mid-trip, although the ICE still turns on down that hill sometimes. On the return trip, I do the same thing, using Hybrid to warm the car, then return to EV when I can arrive at home with nearly expired SOC. I register about 75mpg using this method on a 54 mile round trip.
    Thanks for the responses to my question.
  18. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    You better have a code reader handy if it's anything like my Gen3. Car (not going to say who was driving, but it wasn't me) was getting VERY low on gas and was about 1/4 mile from the house and a fully charged battery. Gave it a little too much gas and the engine tried to start and failed. This then threw a code and the car wouldn't start until the code was cleared. What a royal PITA as the reader I had wouldn't clear the particular module (for whatever reason). I ended up having to get it towed ($80) to the dealership (who charged me $150 for diagnosis). They said that I was lucky I didn't destroy the car... which I *guess* could happen if I was going fast downhill and overrevved the transmission without the ICE being able to run. Obviously we have a much smaller likely hood of that happening unless you're going over 80 when you run out of gas. Still very annoying. Ended up buying a much better code reader so that would never happen again.
  19. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Here is a copy from the manual:
    ■Gasoline engine operation in EV/EV auto mode
    Even if there is a sufficient amount of electricity remaining in the hybrid battery (traction battery) and EV driving range (→P. 199, 215, 222, 239) is being displayed on the multi-information display etc., EV driving (driving using only the electric motor) may be canceled and both gasoline engine and electric motor are used depending on the situation (EV driving will be returned to automatically after EV driving becomes possible again). EV driving may be canceled automatically in the following circumstances:
    ●When vehicle speed is more than approximately 84 mph (135 km/h).
    ●When power is needed temporarily, for example when the accelerator pedal is depressed firmly or when accelerating suddenly.*
    ●When the temperature of the hybrid system is high. The vehicle has been left in the sun, driven on a hill, driven at high speeds, etc.
    ●When the temperature of the hybrid system is low.
    ●When the heater is switched on when the outside temperature is below about 14°F (-10°C).
    ●When the windshield defogger switch is pressed. (→P. 491, 501)
    When the system determines that the gasoline engine needs to be started. The gasoline engine may also operate in circumstances other than those listed above, depending on conditions.
    *: When traveling in the EV auto mode only​
    driver4773 likes this.
