Ethanol Restrictions Lifted
Discussion in 'Fred's House of Pancakes' started by Starship16, Oct 9, 2018.
  1. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    If this is old news, Moderator can delete.
    In boon for farmers, Trump lifting restrictions on ethanol - WPSD Local 6. Is this good or bad regarding our Prius engines? Year-round sales of 15%. Are some of you already using that blend?
  2. ETC(SS)
    7,555
    Not old news, but "the usual suspects" will probably want it moved to the kindergarten.
    It's been debated many, many, many times in the more 'moderate' portions of this forum, but one unexpected benefit for the temperance movement is that sometimes DE-regulation can be a good thing.
    Example:
    Allowing states (like my beloved Indiana) NOT to have alky in their fuel.
    YMMV
    Starship16 likes this.
  3. Starship16
    1,348
    1,455
    Beach Christmas
    My intentions were not to start a political discussion, but I understand your point.
    I was just curious if anyone is already using that 15% ethanol blend in their Prius. And does the lifting of restrictions mean the gas can now contain more than 15%? How high can they go? How does it affect our engines?
  4. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
  5. Starship16
    1,348
    1,455
    Beach Christmas
    Thanks. I need to find the Ethanor 101 website and study up.
    Is ethanol bad for your car?
    Gas mileage decrease. One of the bad things that happens with ethanol is that your mileage will actually decrease. The New York Times stated that E10 gasoline, which is the gas we use in America, actually gives you 2-3 miles per gallon less than gasoline. E85 is a flex-fuel with 85% ethanol loses 7-8 miles per gallon.Feb 22, 2017
    Pros and Cons of Ethanol in Gas | AxleAddict
    #5 Starship16, Oct 9, 2018
  6. Trollbait
    12,829
    Check the owner's manual; it will state what percentage of ethanol says is safe for your car.
    A short summary of the issue. The law that instituted the ethanol mandated set the total volume to be mixed into the nation's gasoline supply instead of a ratio of amount to the amount of gas being actually used. So when gasoline use actually dropped, overall percentage of ethanol to be used in gas increased. On top of that, there wasn't much government support in increasing the number of E85 stations so flex fuel cars could actually get it.
    So the law was mandating more ethanol in the fuel supply than could be met by staying at E10 and the current fleet of flex fuel cars used in E85. That had the ethanol producers pushing to make E15 the minimum.
    In my experience, ethanol in gas just means small engines actually need to be maintained better than what most are use to, which is far from what the manufacturer recommends. My mower with B&S engine is now 17 years old, and its restarting difficulty stems from a dirty air filter.
    Can't stay much about how much the efficiency drop is, because E10 was the only thing available since I kept real track of it.
  7. Starship16
    1,348
    1,455
    Beach Christmas
    Thank you Trollbait.
    It says "up to 15% Ethanol." And Toyota recommends the use of those gasolines because they allow for reduced emissions.
    #7 Starship16, Oct 9, 2018
  8. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    That's a bit questionable....wonder why they say that?
  9. Starship16
    1,348
    1,455
    Beach Christmas
    I don't know. I got that right from the 2016 online owner's manual. I guess there will always be questionable issues about ethanol. And what if someday they raise it to 20 or 25 percent?
    Can't do much about it I guess. Whatever is in the Chevron or Mobil or Shell pump, goes into my Prius tank. :LOL:
  10. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    I've been running 15% ethanol since the 3rd fill-up in my fuelly stats.
    Orange C (Toyota Prius C) | Fuelly
    You'll notice a wild swing in the mileage for the first couple tanks. I'm not sure what caused those initial wild swings as my driving never changed. But it has leveled out now and hovers just above 53 mpg. My average before using 15% was between 53 & 55. So yeah, I've seen a slight drop, but it's minimal and to me worth the 6-10 cents cheaper a gallon.
  11. ETC(SS)
    7,555
    I'm thinking that @bwilson4web did a deep dive on this issue, but I do not remember seeing an x-y representing the cost in MPG.
    As far as Priuses being 'certified' for E15, this surprises me not in the least.
    Priuses are built abroad and it's more or less a 'world' car.
    They even put the steering wheel on the wrong side of the car so that they can sell them in parts of the world where people drive on the wrong side of the road.
    I can report that I personally do not observe very much of a delta between E0 and E10, and I would expect that the energy density (-3% for E10?) might begin to express itself in real-world driving at 15% hooch....as in you would not need to use a set of calipers and a laboratory grade driving course to notice a difference.
    One thing is for dead-bang certain.
    If the price delta is 6-10 centavos per gallon, then there's a 100-percent chance that people will be buying corn.
    If we presume that there's a verifiable 5% decline in MPG (2MPG more or less) where's the break-away cost?
    I just paid $2.55 per....up recently from $2.38 because of market forces, but some people live behind the curtain and pay more than $3.
    Anybody want to take a stab at the math?
    I can do it, but I like to witness changes in outcomes based on different presumptions......;)
    Merkey and Starship16 like this.
  12. Trollbait
    12,829
    Did you go from 'pure' gasoline to E15?
    Ethanol is like biodiesel in that it is a better fuel system cleaner than the petro fuel. This could cause problems in older engines as the years of crud coming loose clog things.
    So that cleaning action when switching to ethanol could be the cause of the swings, and/or the car's computer adjusting to the different mix.
    I did similar math when trying premium(all was E10) in the Sonic. In rough numbers, the 2mpg increase in a car that averaged 37mpg broke even in terms of price per mile when the cost difference was 25 cents. At the time, regular was around $2.40, and premium was usually 40 cents more.
    E15 comes here, I expect to not have the choice of using it or not.
  13. ETC(SS)
    7,555
    Hmmmmm.....that's interesting.
    I wonder why?
    Is it a state regulation thing or a marketing thing?
    ....inversion layer?
  14. Rmay635703
    Rmay635703 Senior Member
    2,702
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    My Volt gets better MPGs on e15, (summer months) This is over 2 years of data.
    The 88 octane fuel is also over 20 cents a gallon less than regular 87 where I buy it.
    my only guess is because of the slightly higher octane which the Volt likes gives me a couple extra MPGs
  15. Trollbait
    12,829
    Major metropolitan areas, and some states, ethanol free is simply not available; it is E10 or push. Some of is state(E10 only in NJ), and some of it is EPA. The closest station pumping ethanol free gas to me is an hour out of the way. So if E15 comes here, it could be mandated as the minimum.
    That is my guess too. Note that when mixing E10, refineries can make the regular gas lower octane now, so that it is 87 with the alcohol.
  16. Starship16
    1,348
    1,455
    Beach Christmas
    $3.86 here in Cali-Forn-Eee-Ah. Some stations are over 4 bucks. Two million truckers would give their left *** to be paying only $2.55. :eek:
    The E10, (how long have we had it???) doesnt affect the mpg of my car. My gas mileage acrually went up 2 or 3, but I think that's because I switched to a different oil 2000 miles ago. Who knows. I dont know. Bring on the E85! :LOL:
  17. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Went from E10 to E15. "Pure" gasoline isn't even available around here unless you drive to a boat dock or marina. That's a good 60 miles away for me. I have ran it before - but even with "pure" gasoline, the increase in mpg's was negligible. (1 tank though - so hard to say for sure) E15 only recently became widespread around here when all the local gas stations had to install new pumps that would utilize the chip on peoples debit/credit cards. Up until then, E15 was always out there by the diesel pump. Now it's on all the pumps.
    As for the problems in older engines. There is a sticker on each pump which is pretty hard to miss - warning you not to put it into a vehicle older than 2001 and that doing so is a violation of Federal law and will damage your vehicle.
    You mentioned in a later post that refineries can mix it at 87 octane? I've never seen E15 at 87 octane - ever. It's always been 88 for as long as I can remember.
  18. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,603
    Taylors, SC
    A total contribution to global warming, destruction to the natural environment to subsidize corn farmers. Why does one think that one of the first presidential primaries is in Iowa.
    It is well known that Methanol (wood alcohol) is the better less costly option converted from methane (natural gas) which can be had from garbage dumps. Ancient dumps from Roman times is still producing it. The "cleanest" use of coal would be conversion to methanol.
    Prior to 2000, nearly all alcohol blended fuels were made with gasoline and methanol. It was called Gasohol in California. Ford developed many vehicles using it, until politicians advocated ethanol that is more expensive to make than gasoline.
    China prohibits making vehicle fuels from food stuffs.
    The price of non-ethanol gas is higher, because it is an artificial marketing too.
  19. bisco
    52,855
    no ethanol free around here either, afaik
    87 is around $2.75 at best. not that i care, i'm running mostly on electrons. haven't filled up since may
    dubit likes this.
  20. ETC(SS)
    7,555
    I'll sponsor you for a free membership to the political sub-forum if you really think you want that, but I was hoping for some real data for a cost average.
    The Meth-heads (IMHO) always jigger the numbers a little bit when the subject of E>1 comes up but strangely enough big earl hasn't chosen to capitalize on this "better less costly option" and captured methane from all manner of human waste just never seems to be able to scale up.
    Clean coal is like "clean diesel."
    They struggle furiously to be "as clean as x"
    ah.....YMMV
