EV button and its effect on the HV battery
Discussion in 'Gen 2 Prius Technical Discussion' started by dolj, Sep 24, 2016.
  1. eman08
    eman08 Active Member
    360
    192
    US
    I don't think there is no real data with all the back and forth in this thread. It's looking more like back and forth debates rather than being helpful after getting Belittled by a "Narcissist" in this thread.
    52,891
    you don't think there is no real data? you may be right, but i have not seen any. in the absence of proof, i generally go with experienced opinions.
  3. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    It depends on what you call "real data"
    If you mean scientific double blind documented experiments, I haven't seen any such reports.
    However, there is experiential data which we see time and again typically from noobs who overuse the EV button and wonder why they do not get 60+ (usually 70+) mpg figures. I thought this was well and truly "put to bed" a long time ago, but maybe only in the Gen II forum. Take a look here in the Gen IV forum: Is my EV damaged? | Prius Chat to see the misunderstanding continues. Of particular interest is post #11 by john1701a, a long time respected Prius owner.
    I have my theories as to why using the EV button is to be avoided, if, your aim is better fuel economy. I try and pass these on.
    I try and use simple ideas and concepts, but that has its pitfalls when you're essentially trying to explain an intricate and complex system.
    The poster, to whom ema08 referred, raised some interesting points, points I thought worthy of further discussion, but he thought otherwise.
    If I am wrong, I don't mind people telling me as long as they are prepared to back up their statement(s) with logical and factual data.
    52,891
    i meant battery longevity. i thing mpg's are a given, and easy to prove out.
  5. dolj
    dolj Senior Member
    8,655
    4,406
    Oh, right. That's what interests me too.
  6. 09Prius2
    09Prius2 Member
    201
    88
    FL
    I don't understand the purpose if the 2nd gen doesn't even have the button. I would love to have one, but I don't, so whats the use?
  7. eman08
    360
    192
    US
    Don't really need the button as you can do it with your foot. Just Glide on electric with the yellow arrows.
    Data Daedalus likes this.
  8. dolj
    dolj Senior Member
    8,655
    4,406
    Only the North American Gen II didn't have it fitted (don't know why), but all the components were there behind the scenes, so could be easily retrofitted, which some did.
    The purpose was to suppress the ICE starting in the warm up cycle, if you want to reposition the car on the driveway/garage, sit in the car for a bit or that sort of thing. Also quite fun to sneak up behind people in parking lots who are not paying attention.
    #28 dolj, Sep 25, 2016
    Data Daedalus and bisco like this.
  9. bisco
    52,891
    i routinely move my wife's hycam in and out of the garage with the ev button. it's nice not having the engine fire.
  10. 09Prius2
    09Prius2 Member
    201
    88
    FL
    How difficult is it to install?
  11. bisco
    52,891
    not hard. you pull a connector from behind the glovebox, and instll it in a couple of the pins. half hour at most.
  12. 09Prius2
    09Prius2 Member
    201
    88
    FL
    Wow. Well I would like to have that. Alot of times the engine cycles on when completely unnecessary.
  13. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Are you aware of allowing your engine to reach "SC4" status (or something to that effect)? This is usually achieved on the Gen 2, when the engine has warmed up sufficiently; if you come to a halt (say in congested traffic), the engine will continue to run while your foot is on the brake pedal - keep it there till the ICE shuts off by itself.
    You will now be in SC4 (someone correct me if I'm using the wrong expression - I'm no genius ).
    Now the Prius should be running at its most economical, and even when the ICE is running, it should be at its most economical.
    A lot of Prius 2 owners appear to be unaware of this. I suspect, if the vehicle doesn't go to SC4, then the engine will keep kicking in when it doesn't really need to
    iPhone ?
  14. bisco
    52,891
    i will say, i never felt the aftermarket switch worked as well on my 2004 prius as the switch in my wife's 2013 hycam.
    i don't know if the parameters are different, but i feel it's much easier to get hers into ev mode to move the car in and out of the garage than it was the prius. a lot of times, i would pull the switch on the prius and get the two beeps meaning ev mode was not available.
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I agree and yet disagree.
    Of course when you have a system where a battery is charged by a gasoline burning engine then you can trace the creation of any and all "momentum" created back ultimately to the engine. Even if coupled with an energy storing and momentum aiding HV battery.
    Hence the statement:
    But I would argue The Prius and HSD is a pretty clever system. Yes, at the heart of it's energy creation there is a Atkinson Cycled combustion engine, but the vehicle does gain energy from some pretty ingenious avenues.
    The regenerative brakes, take energy that on any other vehicle would simply be wasted, and returns it to the HV battery. That usually wasted energy comes from momentum originally created by the entire system, including the engine, but not always exclusive to the engine.
    Think Braking down a hill, and the reason Toyota provides "B" on selection knob. The Prius does capture energy, situationally. If the momentum created is being created by gravity, then it can "capture" energy arguably NOT being created by the engine firing, so much as the car traveling downhill from the pull of gravity. -Thank You Regenerative Brakes.
    One can argue it's a bit of a momentum and energy capture "shell game" as you have to burn gasoline to reach the top of hills, but still...it is energy being created based on the situation not exclusively the engine.
    Once you pass 40 years old, the term going down hill takes on a lot of negative connotations. Not so much when you are talking about a Prius and HSD.
  16. bisco
    52,891
    the correct statement would be that 'the prius wastes less energy than most cars'. all the energy comes from gasoline.
    Data Daedalus and dolj like this.
  17. The Electric Me
    9,083
    5,801
    My contention is however The Prius is ALSO designed to "capture" energy.
    And there IS a situation...coasting down hill, where that energy captured is being created primarily by momentum and gravity NOT burning gasoline.
    You can argue that what comes down...must also go up...so it "shell games" back to firing pistons and fuel consumption. But to deny the energy capturing capabilities of the regenerative brake system is to not be looking at the capabilities of the entire system and the reality of downhill coasting-gravity and momentum.
    We'd all get fantastic gas mileage if we could just drive downhill everywhere....all the time....
    I propose the building of countless hills and solar powered automobile elevators.
    My campaign slogan?
    "When I get to the bottom, I go back to the top of the slide, where I stop and I turn and I go for a ride, till I get to the bottom and I see you again".
    I think you can see why I'm not a politician. Nor an engineer.
  18. bisco
    52,891
    i agree that you are capturing energy, and storing it in the battery, which would otherwise be wasted. and it burns me when i'm going downhill or braking in a non hybrid.
    but the only time you can do that, is after you have burned gasoline to get up that hill.
  19. The Electric Me
    9,083
    5,801
    Yes. And I said exactly that...
    But my point is aimed specifically at the statement that ALL energy in a Prius is created by burning gasoline.
    Created...arguably yes...Captured? No.
    albeit a very specific scenario...some energy is captured while coasting down hill, and that energy is primarily created by the force of gravity not the burning of fossil fuel.
  20. Tideland Prius
    16,683
    For someone who helps people, you sure don't seem to be patient enough to help people. My hybrid technician was happy to talk through the things he was doing with my Prius for service and took the time to explain the process.
    #40 Tideland Prius, Sep 27, 2016
