Every warning indicator is ON--2006 Prius
Discussion in 'Gen 2 Prius Main Forum' started by dslomer64, Jan 5, 2018.
  1. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    I'm hopeful it isn't as bad as it looks. In addition to "Red Triangle Of Death" (RTOD), we have anti-skid, brake, ABS, VSC, and check engine warning indicators shining.
    My wife learned about RTOD long ago and pulled over immediately(damn it!!) and called me. I asked her how she noticed RTOD. Because the car started slowing down, she says.
    Deja vu all over again from a few years back. Same symptoms. I hoped I would fire it up and see no RTOD or any more than check engine light. [Since that episode, I had Toyota replace injector coils, which is what a later spate of check-engine-light on-and-off cycles finally (supposedly) showed in the codes.]
    No such luck. RTOD still on, as was brake, ABS, and check engine. I powered down. I called Toyota for advice. Bring it in if you think it's okay to drive, was counter guy's advice, since you're only a few miles away.
    I told the guy I thought I could drive it. Then I powered up and noticed whichever indicator(s) hadn't been on were now, since they were now equally-spaced. And I'd never seen VSC and one other (brake, the manual says). So I said I don't think I'll be driving it there.
    I tried to lock it: key fob wouldn't work. I had noticed fuel gauge was on one bubble, flashing furiously. Wife said it's been doing that a few days. She's sure there's plenty of gas in the tank because the bubble began flashing the day after she filled up.
    Came here after Googling "2006 Prius all warning lights lit" turned up several hits. Each one except the first I looked at made it sound 12V-battery-related. That would be reasonable. And acceptable. It's been below 0° F the past few nights and highs in the teens. And at least 4 years since it was replaced.
    The other one, though, suggested hybrid battery. I'll take the "consensus", please.
    Most said they were still driving, but with no warning lights on except sporadically. No one seemed particularly concerned.
    A couple said key fob wouldn't work.
    I looked under the hood and saw nothing calamitous-looking. Oil level fine. Coolant, too.
    If it will start and doesn't sound out of the ordinary, how's about driving 3.5 miles to Toyota? I know, ya pays yer money and ya takes yer chances.
    Any other advice is welcome, too.
  2. frodoz737
    frodoz737 Top Wrench
    4,807
    2,561
    33
    "Because the car started slowing down"...and all the other symptoms.
    I'd have it towed.
    dslomer64 likes this.
    52,863
    test the 12v volt, if it's good have the codes read at toyota. might be the hybrid battery, how many miles on her?
  4. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    It has about 170k on it. Replaced battery at least 5 years ago. Well maintained. It's been towed to dealer.
    I'd hoped the lights would be dimmer. They're not exactly bright, but I'd hoped for really, really dim to encourage me to believe it's the 12V battery. I didn't replace the battery until the day after it was totally dead to my total surprise at midnight, 35 miles from home, and no wife or daughter answering their phones.
    Ran fine until I got where I was going, leaving no reason to suspect doom awaited me.
    Tonight was pretty different. Absolutely nothing would come on that other night. Had lots of light tonight: whole dashboard, dim but useable headlights.
    Whatever. I almost hate to get the call tomorrow about what's wrong.
    #4 dslomer64, Jan 5, 2018
  5. bisco
    52,863
    pleasure, all the best!(y)
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Anytime you lose/disconnect the 12v battery, the fuel gauge blinks one dot. If she is totally confident you haven't run it out of gas, 12v circuit is most likely culprit. Crappy cold weather lately..probably 12v failure.
  7. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Bisco, thanks for the hope. She did not run out of gas, 100% sure, short of having gaping hole in tank, which I think is safe to assume is not the case.
  8. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Well, I'm at Toyota. They said it's out of gas. Codes for that, battery, starting, etc. They've gone to get gas to make it start.
    Wife bought on two separate occasions 12/28 and 1/2 a total of $10 worth of gas and said once it spewed out. She did this because maybe as far back as 12/28 the single last fuel bubble was blinking. Of course I only found this out couple days ago when I asked if MAINT REQD light was on.
    Toyota insists no gas in car but only because of codes and symptoms.
    The mechanic said not to worry.
    Right.
    I'll keep us posted.
    valde3 and Rph74 like this.
  9. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Well, this is unbelievable. Despite what my wife said, she ran out of gas.... And needs new battery, as some suggested. I'm waiting while they install it. I replaced one once and knew it would be unusual, but i'd've paid them the $100 I saved in a minute had I known how hard if would be.
    I hope this ends the weird saga. Not 100% confident it will.
    If anything changes, I'll be back.
    Thanks for the advice and encouragement.
    Raytheeagle likes this.
  10. bisco
    52,863
    apparently, you're having fuel bladder problems, are you familiar?
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    12 volt battery’s and there infinite mystery’s.
  12. uart
    uart Senior Member
    4,220
    1,212
    Australia
    It looks like there was a little bit too much guess work there regarding the fuel level. :)
    Still you are lucky that your wife stopped as soon as she noticed the reduction in power (corresponding to running only on the HV battery). Some people continue to drive until the HV battery is so depleted that it damages it, and then you're up for a new HV battery as well. It looks like you've probably dodged that bullet. :)
  13. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
  14. dolj
    dolj Senior Member
    8,648
    4,400
    Wellington, New Zealand
    There is no such thing as "Brake Actuator Assembly failure lights" and there is not one shred of information that points to Brake Actuator Assembly failure. So why post misleading information? Did you even read this thread? It's not the first time you have posted such red herrings.
    Further, if it was true, why rub salt in the wound by telling the OP he just missed out on a warranty fix. Sheesh.
  15. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    If the OP car is fixed, he/she is good to go. If the problem comes back, this is what I might suspect as a follow-up item.
    I do not understand your attitude except I did miss Post-9 that there was a tentative finding. In the USA we have quite few cases of the Brake Actuator issue, and we are just getting into the non-coverage period. My post included the warning lights and documentation for the problem I cited.
  16. dolj
    dolj Senior Member
    8,648
    4,400
    From the documentation:
    Each one of those lights could have hundreds of codes associated with it, so that combination of lights could be thousands.
    It is just that you seem to leap to the conclusion that the brake accumulator is failing/faulty with no evidence (apart from lights on). It would be just nice to think about it for a bit and see if the evidence supports your conclusion. That all I'm saying.
  17. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Sorry I took so long to reply, bisco. I'm not familiar with problems with fuel bladder, but whatever, there have been no problems since. Almost a year.
    She ran out of gas. Unthinkable. But I did once. At 2am.
    I assume a somehow-blocked fuel bladder inlet would make gas spew out, but have no clue about why it might only happen once nor how to fix it.
    But we'll be selling the old beast in 2019. No doubt CHECK ENGINE light will be on. I surrendered well over $1000 but well under $2000 in two separate CHECK ENGINE events to no avail. It just keeps running. For another 3 to 6 months, please!
