Exchanging rear camera on a pruis prime 2017
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by AFindlay, Oct 7, 2024.
  1. AFindlay
    AFindlay Junior Member
    Vermont
    I bought my car second hand knowing the rear-camera image was very blurry around the edges. Cleaning the lens cover did not help. I hope to buy a new camera and replace it myself. Does anyone know if I need specialty tools to do this?
  2. sylvaing
    sylvaing Senior Member
    1,219
    517
    My 2017 rear camera was all scratched up/hazed when I bought the car last year. I polished it with Meguiar's ScratchX 2.0 scratch remover (which also removes the headlight yellowing in just a minute or two) using a pad and a drill.
    This is after and before the polishing. Try this first and make sure you never remove dry dirt by rubbing your finger on the lense. I have a small bottle with ONR in summer and windshield washer in winter and a microfiber cloth that I keep the car to clean the lense.
  3. Leadfoot J. McCoalroller
    8,278
    7,782
    Pennsylvania
    2018 Prius c
    In terms of specialty tools about the most you would need is plastic prybars to remove the interior panels without damaging them.
    Cheap at harbor freight, and in a pinch you can substitute clean popsicle sticks or chopsticks.
  4. AFindlay
    Vermont
    Thank you! I will try out the popsicle sticks first.
  5. AFindlay
    Vermont
    I will have a closer look at the lens, but I am fairly sure it does not have scratches.
  6. CarCarCarCar
    CarCarCarCar New Member
    amazon is great for cameras
