Failing battery, inverter, both?
Discussion in 'Gen 2 Prius Technical Discussion' started by respun01, Oct 1, 2019.
  1. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    It is not an urgent job, next week will be fine as long as you're not hammering it. Good luck with it.
    I eagerly await your report, it is always nice to have a conclusion.
    respun01 and Raytheeagle like this.
  2. strawbrad
    953
    1,007
    I think you are on the right course of action with replacing the inverter coolant pump. That should take care of most of the problems you have.
    The P3024 code seems to be separate issue. It's unusual to get that code without a P0A80 code. It's also too big of a coincidence that the old HV battery and a NEW dealer installed HV battery produce the same code. The battery ECU is reused when a HV battery is replaced. That suggests a faulty battery ECU is a likely source for the P3024 code. It's possible the original battery had not actually failed. This would be a very rare situation.
    Run a forced charge and discharge test while monitoring the block voltages with Techstream. Pay close attention to what block 14 is reading.
    dolj and respun01 like this.
  3. respun01
    respun01 Junior Member
    25
    The thought had crossed my mind that the battery ecu may be causing the P3024, but I wasn't sure how to go about testing it. Could a bad or corroded sense wire cause a false bad block as well?
    I will try out the charge discharge test once I get the inverter pump sorted.
    Thanks for the feedback strawbrad.
  4. strawbrad
    953
    1,007
    The new battery came with a new wiring harness so that is not a common part between the two batteries. For more info on the sensing wires read this thread.
    The battery fires at ECU sense connector thread | PriusChat
    If the P3024 persists after replacing the inverter pump you could try replacing the battery ECU. I can't think of another way to test the ECU.
    respun01 likes this.
  5. respun01
    25
    Ok, that makes sense that it would be a new harness. I’ll probably go ahead and get a battery ecu off eBay while I’m at it. I’ll take a look at the old unit to see if there’s any visible damage.
    I’m definitely going to give that thread a read, interesting stuff from the looks of it.
  6. respun01
    25
    Replaced the inverter pump and it looks like flow is more or less the same. Sitting still after a short drive the inverter, mg1, and mg2 temps are sitting around 115f (46c) in 60f (15.5c) weather. When driving, temps are going up to 150f (65.5c) very quickly, but will come back down after 30 seconds or so.
    I’m wondering if these temps sound reasonable, or if I may have an obstruction.
    Edit: Scratch that, I went to try and bleed it again in case I missed some air, and it looks like it’s flowing pretty good now.
    #26 respun01, Jan 30, 2020
  7. respun01
    25
    Here’s the new pumps flow, for anyone interested.
  8. dolj
    dolj Senior Member
    8,645
    4,395
    Yes, that is looking good.
  9. tallman
    tallman Junior Member
    60
    wv
    My pump is running , probably not moving that much
  10. respun01
    25
    Got the new battery ecu installed, the original looks perfect, no corrosion or obviously burnt components on the board (not to say it couldn't still be malfunctioning).
    I went ahead and did a battery test as described by the hybrid assistant app, and these are the resulting graphs. I started the test with 80% soc and the app lost connection, by the time I got it reconnected it was down to 75% soc so I hope the results are still usable. It was bouncing between 12 and 14 amps during the test.
    I also logged a 90ish minute drive with torque, and the block deltas jump up kinda high, I'm not sure if that is normal during regular driving or not.
    #30 respun01, Feb 13, 2020
    strawbrad likes this.
  11. strawbrad
    953
    1,007
    Your results are a good example of how a new battery performs. Don't read to much into big a delta V while driving. The voltage readings for the 14 blocks do not all refresh at the same time. While driving the delta V tends to be a measurement between the first and last refreshed block voltage readings. At the steady state discharge of the test the readings are more accurate. It's the rapid change from discharge to charge and the lag in measurement that cause a larger delta V.
    Only time will tell if replacing the battery ECU will make a difference.
  12. respun01
    25
    Ok, that makes sense, I can definitely see how that would cause high deltas. I guess it's time to start taking it out for longer drives now.
    Fingers crossed!
  13. respun01
    25
    Last week I was monitoring with the Dr Prius app and everything started lighting up yellow and red. It took me a minute to figure out what was going on, but it looks like all 14 blocks are charging as high as 19.5v during regen braking and sometimes when coasting. I haven’t been able to find if this is normal operation, I’m guessing not though.
    I also did another discharge test a couple days ago, and I think block 14 is having trouble now. Is this looking bad enough to be throwing a code yet?
    I spent most of the day today driving around trying to get it to throw the code again, but no luck yet. I found an empty road and accelerated to 50 and came to a firm stop several times, and it may have been my imagination but I thought I smelled burning electronics/plastics.
  14. strawbrad
    953
    1,007
    Now that does not look like a new battery!
    You could try the flip side of the discharge test with a forced charge. Keep an eye on what block 14 does.
  15. respun01
    25
    Aha, I'll definitely do that tomorrow!
    After running the car around 600 miles trying to get it to throw a code I did another battery test, and comparing to the data I posted yesterday, I'm not sure what to think. Block 14's internal resistance has varied from 2 to 11 milliohms difference from the other blocks, and the max voltage delta has gone from 0.2v to 1.7v back to 0.7v.
    I doubt it's the case, but could a loose bus bar nut cause fluctuation like this?
  16. respun01
    25
    Ok, and here's a force charge. Everything seems to stay relatively close, unlike the discharge.
  17. strawbrad
    953
    1,007
    Everything about this is odd and unlikely. The two end bus bar nuts are installed when the battery is put in the car.
  18. respun01
    25
    Here’s a final update to this thread.
    tldr:dealer replaced the battery at no charge, and everything is fine.
    In early July my Prius finally threw some codes for me (p0a80, p3000, and p3024), and I was finally able to get it to the dealer without clearing the codes. They confirmed the battery was faulty, replaced it, and gave me a loaner car for the couple days the repair would take. There was no charge for any of this, and the manager of the dealership confirmed for me that the new battery is warrantied for 3 years. It had been about 15 months since I originally had the battery replaced.
    It’s been running great ever since. Next project is to figure out why when my gas gauge shows 1 pip left, I can almost never get more than 6ish gal in the tank without the pump kicking off.
    Anyway, thanks again to everybody.
    strawbrad and bisco like this.
  19. prnico
    prnico Junior Member
    27
    France
    Hi. Congrats on the fix. Sorry to hijack slightly but l read this whole thread and I notice that my inverter coolant flow/activity is about the level of yours *before* you replaced the pump. Did you notice whether after changing the pump and purging the circuit your inverter temperatures were any lower? (My pump has already been changed by the previous owner and as far as I can tell everything is ok)
  20. respun01
    25
    Honestly I don’t remember much of a change, but I’ll check what my temps are running when I get home a little later today.
