First flat tire on my Prime
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by BiomedO1, Sep 5, 2021.
  1. BiomedO1
    BiomedO1 Senior Member
    4,310
    2,260
    Left Coast
    Got my first flat today; luckily it was in my driveway. Is there a jack and lug wrench in the 2021 Primes?
    I just used my garage tools. Now I'm going to get serious about getting a spare tire, highway plugs, and possibly tools from a late model Corolla. If I was on the road, this would've ruined my day.
    I noticed the OEM tire was pretty flimsy, with thin sidewalls. I was also surprised to find no anti-seize on the lug studs. It was at the dealership two months ago for the 5K tire rotation.
  2. pharmdtg
    pharmdtg Junior Member
    PA/FL
    2020 Prius Prime
    There should be a tool kit in the back cubby where the charge cable is stored.
    52,484
    yes, there is a jack, fix a flat and compressor
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    The jack is located underneath the rear driver passenger seat;).
    I bought a spare tire that I carry around just in case :).
    Lucky you found the opportunity while in your driveway(y).
  5. Mendel Leisk
    42,014
    Woah Nelly: you've got a scissor jack and lug nut wrench in there.
    I'm surprised you were surprised: you're not supposed to use anti-seize; the torque spec is 76 foot/pounds with clean/dry threads.
    That's a tire plug-repair kit? Good idea. Also worth having: a small bottle of soapy water, chalk or wax pen (for marking plug location), gloves (especially for winter), reflective vest (triangles, cones, etc), pliers (for pulling stuff out of tires), a smallish square of plywood (to put under the scissor jack on soft ground or gravel) and last but not least: someway to inflate the tire, preferably without using the #&@?! included compressor with goop. Dead simple and very reliable, is a lowly floor standing bicycle pump. We're off on a minor road trip tomorrow, and taking one along.
    #5 Mendel Leisk, Sep 5, 2021
    jerrymildred likes this.
