First prime in the dealer for a serious repair?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by thm8d, Mar 3, 2017.
  1. thm8d
    thm8d New Member
    Garden Grove, CA
    I turned on my car this morning and had a check engine light. I figured I would drive to work and scan the car once I had time. If it was serious, the dealership is less than 5 miles from me.
    Right before lunch, my coworker had came and told me my car was leaking gas. I didn't believe him so I had went out and inspected it.
    Well, he wasn't lying. I had a huge puddle of gas under my car. I immediately unplugged my car and drove it straight to the dealership.
    Now we shall await their call and see what the verdict is.
    Car information:
    2017 Prius Prime advance
    2,2xx miles
    Purchased on January 8th
  2. BlueMagnet
    BlueMagnet Member
    50
    26
    San Bruno, California
    2023 Prius Prime
    SE
    So sorry to hear about the leaking gas. It sounds very serous.
    What did the dealer say was wrong with your car?
  3. Mendel Leisk
    41,064
    There was someone else here with a fourth gen that had gas overflow. I forget the outcome and particulars, but IIRC he might have topped up a bit (beyond the first shut-off of the pump) and had been driving through mountainous terrain, ie: he mighta filled at one altitude, had the overflow at another altitude, higher/lower. Maybe search threads.
  4. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Also curious about the outcome???
  5. thm8d
    thm8d New Member
    Garden Grove, CA
    I got my car back today.
    Toyota had inspected my car and said they had 2 master technicians take a look at my car. They didn't find a leak anywhere in the system.
    I'm a certified master technician myself, so I'm aware of the possibilities.
    Before anyone goes and ask, why I didn't inspect it myself and figure it out.. why? I have warranty for a reason lol.
    First off, my CEL was P0445 Evaporative system leak(Large)
    As soon as I saw my CEL on, I checked the gas cap and it was tight. Being that I am well experienced I would never leave the gas cap loose.
    The dealership had performed a smoke test to try and find the leak. Could not find any leaks.
    They gave me a call this morning and has said that my gas cap was loose. (Could not be since I checked it already)
    They also said that I probably had filled the tank and could've overflown into the filler neck.
    I don't see how it is possible since I had already driven over 150 miles and then the leak occurred.
    Personally, if I was in their shoes.. I would fix whatever leak there was and said the same thing. As I would not want to hurt potential future purchases and have an angry customer with a brand new car.
    If there was no repair performed, then we shall see if the leak will presume
  6. huskers
    2,544
    2,487
    Nebraska
    Could you have parked in a spot where a car before you had leaked gas or could someone playing a joke on the new car guy have poured gas under the car?
    priuscatprimeguy likes this.
  7. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    lol, yeah and they probably won't stop
  8. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    Mendel is right this is at least second report here (other was Gen4 Prius)
    Gen4 seems to have a different system including something like a gate valve that closes off the tank.
    With winter gaso higher in butanes maybe some vapors can evap and condense or push liquids out of the filler neck.
  9. huskers
    2,544
    2,487
    Nebraska
    Would that not show on the side of the car?
  10. Mendel Leisk
    41,064
    Yes. If anyone can recall enough of the title (of that other thread) to search and link it, that'd be great. The poster was concerned about paint damage below the filler.
    In this case there's no mention of gas running down from filler cap?
  11. vince22
    vince22 Active Member
    205
    249
    califorinia
    there has been a couple times i purposely top off my Gen4 Eco just to check if can I reach 800 miles in a full tank but never had any CEL in results, maybe just go lucky...
  12. Toptimus
    Toptimus New Member
    Bay Area, CA
    Ok, maybe not a serious repair, but I had a flat yesterday, with just 600 miles on the car. Successfully used the tire repair kit to get going again.
    New cartridge is $100, plus I need a new tire (sidewall damage).
    Next time, I'll just use the included Roadside Assistance and get a tow. Charging $100 for the little bottle of liquid is somewhere between ridiculous and criminal!
  13. Mendel Leisk
    41,064
    Was the sidewall damage incidental? Trying to understand how the goop would seal, with sidewall damage.
    If it was just a nail in the tread, I would:
    1. Put on spare, drive home.
    2. Plug-repair and pump up the flat tire, reinstall.
    Without a spare:
    1. Remove flat tire, plug repair, pump up, reinstall.
    jerrymildred likes this.
  14. Prodigyplace
    12,470
    11,724
    Central Virginia
    I do not think the dealer found anything then either. :(
    Interesting fuel issue, 2016 Three Touring overflowing | PriusChat
    wjtracy and Mendel Leisk like this.
  15. Mendel Leisk
    41,064
  16. Toptimus
    Toptimus New Member
    Bay Area, CA
    I think the sidewall got damaged while I slowly continued to drive for half a mile to get off the freeway. Probably not the best idea...
    The puncture was actually not at the sidewall.
