Foam panels under trunk?
Discussion in 'Prius c Main Forum' started by Emahjin, Mar 25, 2012.
  1. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    I've considered removing the foam on my C (and SO's Accent, considering there isn't even a spare tire in there) to make room for luggage on trips.
    The only potential problem I recently thought of: is there a structural reason to leave the foam in place? Does it help protect the traction battery and back seat in rear-end collisions?
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Nope, no structural issues by removing it. Did you take your spare tire out?
  3. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    My impression is that it simply fills the space left by the fact that you have a "spacesaver" spare whereas other markets (*ahem*) get a full size spare. I assume our luggage area deck board is at the same height... but I have no foam.
    minkus likes this.
  4. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    You have a full size spare? :cry:
    ChinchillaGirl likes this.
  5. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    Correctomondo. Now I look at it, it seems you guys don't get the little under-deck storage trays either side of the wheel either.
    minkus likes this.
  6. fourenty
    fourenty Member
    47
    26
    Endwell, NY (near Binghamton)
    2024 Prius
    Limited AWD-e
    OK, no reason to rub salt on the wound :)
    ChinchillaGirl and Rob.au like this.
  7. minkus
    369
    125
    Cleveland, OH
    No, I haven't taken the spare tire out. GF's Accent has more trunk space and is the road trip car. If I do take something out, it'd only be the foam unless I was feeling particularly risky. I feel like the spare might also provide some sort of accident protection, though, even without the foam.
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    ah, gotcha. read it as your C didn't have the spare, not the accent.
    minkus likes this.
  9. mahout
    mahout Active Member
    655
    116
    NC
    Wish I could post photos but I can't right now. Basically we used 6 or 8 1" and 2" deep plastic 'boxes each carrying specific tools - metric sets wrenches, screwdrivers, gages, calipers, specialties, etc ' The boxes have lock clasps and are light enough to be reomoved easilty as needed. There is also a air pump and numbers of metrics from 4mm to 28mm. I called it our rolling machine shop and several of the locals have done the same.
  10. mahout
    655
    116
    NC
    these must be part items available from Toyota.
  11. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i feel like im missing out, since other places are getting the full spare.
    anybody think of mounting like an amp in that location or something?
  12. steveoknievo
    steveoknievo Member
    225
    79
    17
    Heck I thought it was cool that we got a spare at all.. Other small sized cars don't even go that far.. I was looking at a Chevy Cruze and all that was there was a can of Fix-a-Flat.. It's not like our "full size" tires are really "full size" anyway ;)
    ztanos likes this.
  13. NewPriusC
    NewPriusC New Member
    17
    Can u post the pics pls. Thx!
  14. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    The Hyundai Elantra gives you a "Tire Mobility Kit" - can of sealant and a DC air pump. No jack, tools or tire.
  15. steveoknievo
    steveoknievo Member
    225
    79
    17
    :ROFLMAO: That's too funny. People don't realize that using sealant in the tire pretty much renders it useless outside of getting you to a gas station or tire shop to replace it.. Good luck getting that sucker to balance.. The fact that the Prius C actually has a spare tire was one of the (many) reasons I opted for this over competition.
  16. Prius4mpg
    Prius4mpg New Member
    PA
    TIP:
    Cutting styrofoam make a mess that will continue to make a mess. But if you heat a knife over a flame, and then cut through foam, it melts the remainder in place.
    About to pick up a '16 four with no spare. Hoping to add a donut spare and modify the foam accordingly.
